Thanks for the replies,
Yes I never thought of the IWG plumbed into DP causing the flow issues.
Either way, I will install a cutout valve in my Downpipe so It should solve the flow issues. Was thinking otherwise I have to go 4" exhaust like GTSoy said.
Geoff, yeah you guys have been great through my build (also ran a 7163). I am concerned about running EWG as both space and heat are an issue for me. This is a dedicated track car (more time attack) now and only at Sepang F1 Circuit which sees 52 degrees °C track temp.. I have seen a few EWG struggle with heat due to placement in Evo X. I would much prefer an exhaust cut out in downpipe over twin EWG setup. for my IWG I have never had an issue holding boost flat up top.
I recently changed to the 4 port boost control and twin port IWG turbosmart unit (which got me the 2bar @ 3,90rpm in 4th gear) and holds flat to 8000rpm.  to be fair I have slightly different gear ratios to a stock EVO (sequential 6 speed)
Shooting for 650whp (on a mainline) with the next round of tuning.
Rob
hi rob,
I agree with your decisions here.  For my personal projects, I prefer IWG for the exact reasons you outlined.  The Exhaust cutout near to the turbo will help.  But be careful to choose a high quality cutout (i have seen many fail).  also you may find 3.5" is suitable and 4" does not offer any benefit
Of course the 4b11T is backpressure sensitive so the 4 port solenoid with a twin port IWG is a good way to get boost where you want it.  Long term I believe the electronic stepper actuators may prove to be an ideal control system
Edited by Full-Race Geoff
Hey guys, I have a EFR 9280 with a 1.45 a/r exhaust side. I have a RB26/30 block with Hypertune cam covers in a R32 GTR. What manifold are you guys running that fits this turbo on this car? I'm currently talking to Full-Race but it is not clear if the exhaust side will clear. Jon said that some modification might need to be done to the cam covers, which is not acceptable to me. Any ideas?
Edited by minesskyline
On 4/6/2020 at 6:40 PM, Robo said:
 8374 , my setup is sleeved block 2.2ltr (4 cyl obviously) with direct port meth injection, sequential 6 speed, head work, oversized valves and makes over 600awhp on a mainline dyno  peak power is 8500rpm and I get 2 bar of boost by 3,900rpm in 4th gear. Car weighs 1280kg after stripping it (with roll cage) and being built for Sepang F1 circuit.
what boost pressure? did you have at peak '600awhp' power
Hey there,
I had exactly 2.0bar, it was completely flat all the way across the upper rpm range. This peak was at 8,500rpm where we stopped the run.
in other news, I have just finished my side cutout in downpipe:
Edited by Robo
52 minutes ago, Robo said:
Hey there,
Thanks for that ;)
oh be careful with those type of flex joints, customer of mine had one fail in his car a few weeks ago they collapse in on them selves to about 1/2 the normal diameter under sustained load at high heat.
On 4/18/2020 at 9:21 PM, RICE RACING said:
Thanks for that ;)
Thanks for the heads up,
This one is double layered and has been on there for over 4 years now, will inform the workshop.
Rob
here is a photo of the 1.45 a/r EFR9280 on our manifold installed in R34. I do not know for fact - but I suspect R34 RB26 valve covers may have more clearance than R32/R33
RB20 valve covers may fit also (a friend installed them on his 26, looks really cool actually) and smaller than RB26
Thanks for that. I have Hypertune cam covers, so not sure if the dimensions on these are smaller or not, but I know they are lower. Aren't the position of the shocks different than a R32 GTR? Would Full-Race be willing to allow me to return the manifold if it doesn't fit? I asked Jon this question but I haven't received a response yet.
On 4/18/2020 at 10:27 PM, Robo said:
Hey there,
Thanks Rob,
We are going to slap on one of these 8374 Full Race kits to a built 2.2 on EVOX, not going for internet records just increase the specific power while keeping some response, will let you know how it goes ;)
On 04/05/2020 at 10:44 PM, jshimer23 said:
Finishing up a RB3026 build with Full Race 6258 twins setup. Kelford 272 cams, 4.375 gears.
Green line is E85 and 28psi. Red line is pump 93 and 20psi.
Any idea where the little dip from 4,4-4,6k rpm comes from?
Making 50% of max power by 4500, that's amazing.  Tempting me to switch from my 8474 to twin 6258s
Is anybody able to take measurements of the EFR9280 compressor, I'm seeing if I have enough clearance on my engine to run and test it compared to the 9180 which I have on me which fit fine on a 6boost T4 in a R33 GTR engine bay
Edited by RB335
    • PayPal is a safe, online payment system that enables businesses and individuals to safely send and receive money, making it an indispensable tool in both personal and professional contexts. However, many users wonder how to send money on PayPal? Don't be alarmed if PayPal is new to you - all the steps can be found by visiting merchant sites with links marked "Pay or send money". Once clicked, select payment method, amount, and add message or note for recipient(s). Upon successful transaction completion you will receive an email containing details of transaction. Let’s start by understanding how PayPal works, how money transfers from banks to PayPal and using various payment methods. Moreover, to transfer money between PayPal and bank, head to the Wallet section and click "Add Account", selecting either "Transfer within seconds with debit" or "Transfer between 3-5 days with bank", and following any instructions shown on screen until completed successfully.   How to Send Money Over PayPal: The Basics Before sending money through PayPal, first create an account. Here is how to set-up a PayPal account: ·         Click “Sign Up” on either the PayPal website or app to enter your basic information such as email address or name into their system. ·         Link your bank account, debit card or credit card directly with PayPal so you can fund transactions directly using these accounts. ·         Verifying your PayPal account will enable you to send and receive more funds. Typically, PayPal requires that you verify your credit card or bank account by making small deposits into it. ·         Once your PayPal account has been established, you can send money through it.   How Do I Send Money to Someone on PayPal? After creating a PayPal account, you can easily send money through it. Here is how to send money to someone on PayPal: ·         First of all log into your PayPal account ·         Once on your dashboard, click on "Send & Request Tab." ·         After this enter the recipient's email or mobile phone number. ·         Enter the amount you wish to send to someone. ·         At last, recheck all the details and click "Send Payment" to complete your transaction if everything looks in order.   How Can I Send Money PayPal for Goods and Services? PayPal provides a safe method for individuals and businesses alike to transfer funds online, both personally and commercially. When paying for goods or services there are additional protections in place both for buyers and sellers. PayPal Buyer Protection offers you peace of mind when paying for products or services with PayPal. In the unlikely event that there is an issue with a transaction, if there are any discrepancies you may dispute it and be eligible for a possible refund. You need to follow the same steps to send money, but select Paying for Services or Goods when prompted. In fact, this extra layer of protection will keep your account safe from fraudulent attacks.   How to Transfer Money to PayPal from Bank? Here is how to transfer money from PayPal from bank: ·         Log into PayPal using either its app or website. ·         Click "Add Funds" in the Wallet section, and add money directly from your bank to your PayPal account. ·         If you have linked your bank account with PayPal, select it under Funding options to select it as your funding option. ·         Enter the amount you would like to transfer to PayPal from your bank balance. ·         Click Add Funds. It typically takes several days for funds to arrive on your PayPal account.   FAQ How can I send money PayPal? Log into your PayPal account, select "Send and Request," enter in your recipient's phone number or email address, select the amount due, payment method of choice and click on "Send Now" - quickly and safely sending money via PayPal is now an efficient method of money transfers!   How do I transfer money to PayPal from a bank? Log into PayPal and select "Add Funds" to transfer money from your bank to PayPal. Select your account number, input an amount, and confirm it. Though the transfer may take up to several days for completion.   How do you send money to someone on PayPal? Simply log into your PayPal account, select "Send and Request", enter the recipient's phone number or email address, select the amount to send, and click "Send Now".   How can I receive payment through PayPal? Senders can easily accept payments with PayPal by providing your PayPal email address and being notified via email when a payment has been completed. When funds appear in your PayPal account, they will appear instantly!
    • At least yours have parkour down pat. One of mine will still trip over his own shadow and fall over... He's a special type of cat... Ha ha ha
    • The question then becomes - was there any fluid coming from that hole before you did the rebuild ?    You may not have noticed, of course.   Depending on how you did the rebuild, the possibility has to be considered that somehow (cleaning ?)  fluid entered that hole and is now being 'forced'  out by small movements of the proportioning valve.   From the factory, there's actually a small rubber plug in that hole but with age and under-bonnet heat it's quite common for it to 'go missing'.  That rubber plug is designed to allow the venting process but also to prevent 'stuff' getting to the area (prevent corrosion, etc).   The plug is also not available as a spare part AFAIA. Personally I wouldn't race and buy a new master just yet but keep an eye on the area to see if the 'leak' continues.   If you're concerned about brake fluid damaging nearby paintwork, cable tie a piece of suitable absorbant material over the hole and remove/monitor occasionally.    Operation of the proportioning valve and the brake master itself won't be affected, but also keep an eye on brake fluid level, of course. In terms of a new master, the genuine part is getting expensive, unfortunately.  Amayama is showing AUD900+.   I was searching recently and there's an aftermarket part available from Japan made by 'Parts Assist': https://zenmarket.jp/en/yahoo.aspx?q=BNR32%2bBM50&p=1 Whether it's any good I have no idea, although in my experience Japanese aftermarket stuff is pretty good quality-wise.   The above site allows overseas buyers to purchase stuff more easily from Japan but there are fees and shipping costs, of course.   The original Japanese seller page is here: https://auctions.yahoo.co.jp/jp/auction/p1197401228 Copper/Nickel is fine but I still prefer bundy tube and it's also cheaper.
    • Your chihuahuas look weird!
