Thanks for the replies,
Yes I never thought of the IWG plumbed into DP causing the flow issues.
Either way, I will install a cutout valve in my Downpipe so It should solve the flow issues. Was thinking otherwise I have to go 4" exhaust like GTSoy said.
Geoff, yeah you guys have been great through my build (also ran a 7163). I am concerned about running EWG as both space and heat are an issue for me. This is a dedicated track car (more time attack) now and only at Sepang F1 Circuit which sees 52 degrees °C track temp.. I have seen a few EWG struggle with heat due to placement in Evo X. I would much prefer an exhaust cut out in downpipe over twin EWG setup. for my IWG I have never had an issue holding boost flat up top.
I recently changed to the 4 port boost control and twin port IWG turbosmart unit (which got me the 2bar @ 3,90rpm in 4th gear) and holds flat to 8000rpm.  to be fair I have slightly different gear ratios to a stock EVO (sequential 6 speed)
Shooting for 650whp (on a mainline) with the next round of tuning.
Rob
hi rob,
I agree with your decisions here.  For my personal projects, I prefer IWG for the exact reasons you outlined.  The Exhaust cutout near to the turbo will help.  But be careful to choose a high quality cutout (i have seen many fail).  also you may find 3.5" is suitable and 4" does not offer any benefit
Of course the 4b11T is backpressure sensitive so the 4 port solenoid with a twin port IWG is a good way to get boost where you want it.  Long term I believe the electronic stepper actuators may prove to be an ideal control system
Edited by Full-Race Geoff
Hey guys, I have a EFR 9280 with a 1.45 a/r exhaust side. I have a RB26/30 block with Hypertune cam covers in a R32 GTR. What manifold are you guys running that fits this turbo on this car? I'm currently talking to Full-Race but it is not clear if the exhaust side will clear. Jon said that some modification might need to be done to the cam covers, which is not acceptable to me. Any ideas?
Edited by minesskyline
On 4/6/2020 at 6:40 PM, Robo said:
 8374 , my setup is sleeved block 2.2ltr (4 cyl obviously) with direct port meth injection, sequential 6 speed, head work, oversized valves and makes over 600awhp on a mainline dyno  peak power is 8500rpm and I get 2 bar of boost by 3,900rpm in 4th gear. Car weighs 1280kg after stripping it (with roll cage) and being built for Sepang F1 circuit.
what boost pressure? did you have at peak '600awhp' power
Hey there,
I had exactly 2.0bar, it was completely flat all the way across the upper rpm range. This peak was at 8,500rpm where we stopped the run.
in other news, I have just finished my side cutout in downpipe:
Edited by Robo
52 minutes ago, Robo said:
Hey there,
Thanks for that ;)
oh be careful with those type of flex joints, customer of mine had one fail in his car a few weeks ago they collapse in on them selves to about 1/2 the normal diameter under sustained load at high heat.
On 4/18/2020 at 9:21 PM, RICE RACING said:
Thanks for that ;)
Thanks for the heads up,
This one is double layered and has been on there for over 4 years now, will inform the workshop.
Rob
here is a photo of the 1.45 a/r EFR9280 on our manifold installed in R34. I do not know for fact - but I suspect R34 RB26 valve covers may have more clearance than R32/R33
RB20 valve covers may fit also (a friend installed them on his 26, looks really cool actually) and smaller than RB26
Thanks for that. I have Hypertune cam covers, so not sure if the dimensions on these are smaller or not, but I know they are lower. Aren't the position of the shocks different than a R32 GTR? Would Full-Race be willing to allow me to return the manifold if it doesn't fit? I asked Jon this question but I haven't received a response yet.
On 4/18/2020 at 10:27 PM, Robo said:
Hey there,
Thanks Rob,
We are going to slap on one of these 8374 Full Race kits to a built 2.2 on EVOX, not going for internet records just increase the specific power while keeping some response, will let you know how it goes ;)
On 04/05/2020 at 10:44 PM, jshimer23 said:
Finishing up a RB3026 build with Full Race 6258 twins setup. Kelford 272 cams, 4.375 gears.
Green line is E85 and 28psi. Red line is pump 93 and 20psi.
Any idea where the little dip from 4,4-4,6k rpm comes from?
Making 50% of max power by 4500, that's amazing.  Tempting me to switch from my 8474 to twin 6258s
Is anybody able to take measurements of the EFR9280 compressor, I'm seeing if I have enough clearance on my engine to run and test it compared to the 9180 which I have on me which fit fine on a 6boost T4 in a R33 GTR engine bay
Edited by RB335
    • EMU Classic. For what I need it to do I see no reason to upgrade. Link and Haltech would both cost an extra chunk of money for a lot of unutilized features
