Surplize modapuckers lol
This happened today, driving back from work like a normal person. Doesn't happen when I drive like a complete knob, or launch it at 4k.
Anyhow tried off and turning it off and on, that didn't help ?
20190927_182351.thumb.jpg.89d2e9fbac9571962b60dbe4603e8d16.jpg20190927_182355.thumb.jpg.5b249c4220d6e9f137a7d4c7b2e7435f.jpg
So headed out to pick up the missus in this shit box, and spanked the limiter, she didn't like it.
  • Haha 1
1 hour ago, r32-25t said:
Typical German car
Lol yeah but considering it's not even 1.5 years old with 17xxx kms on it, it's a joke!
Modern German cars have a system built into the BMCs and CAN that turn on one of a set of random errors each 18 months for the life of the car to ensure you get rid of it and buy a brand new one just after warranty finishes.
  • Like 1
  • Haha 3
It’s why as cool as I think the golf r is I’d never own one, I’d look at either an sti or the Hyundai i30N
  • Like 1
Man my back is sore lol. A fixed bucket seat, semis, several solid suspension arms, rock hard suspension but yeah ended up doing over 450km today. 1.5 tanks of fuel later ?
Good drive with @PLYNX and my mate in his R33.
Okay, admittedly it was pretty fun and first time I've actually stretched the new setup with a lousy tune. Shoots flames, 11:1 afrs, lazy 10 to 12 degrees of timing but it is wanting to light up 255 Nankang AR-1 semi slick tyres. Still need to swap out thr gate spring to a softer spring, running a 4 port solenoid and with a 1bar spring there's very limited resolution, kept spiking and hitting engine protection.
  • Like 7
I'm sorry I missed the run.
I've spent the day yelling at people and driving back from sunny Singo
Glad your beastie got to stretch its legs.
What's next for the 33, back in the garage for a spell?
Umm no idea to be honest, I said I'll try go once a month with @PLYNX but knowing my life, even that would be hard to achieve.
And here's a dose video and some gate, wallah swear to god I didn't use the photo illegally (didn't talk or text or use social media) lol
  • Like 2
43 minutes ago, Murray_Calavera said:
What spring are you planning to swap to and what max boost are you chasing?
0.5 bar and will run up to 2 bar.
At the moment trying to command 1.3 to 1.4bar is very challenging. Every 1% to 2% change in duty cycle is jumping 0.1 to 0.3 bar of boost. By dropping the spring you end up with higher resolution. Just some idiosyncrasies with running a 4 port. Running a 3 port but across both ports on the gate is a simpler solution which allows decent control too, but I wanted to try out a 4 port setup, so here I am lol.
1 hour ago, ActionDan said:
Can't for the life of me think why it would be showing signs of fatigue or damage ;)
Well it's there to use right? lol.
1 minute ago, ActionDan said:
"The brightest candle burns twice as fast"
That's why people run boosted engines, to get twice the atmospheric pressure :)
Another solution I've come up with for another car I tune which granted, we've not tested yet - and I don't know how flexible the Halaltech is with settings and available outputs, but we're running 2 MAC valves and running one of them against a fixed PWM look up table to "bring up the base pressure", then use conventional boost control to drive the second one as an effort to retain 3-port style table granularity but give a 4-port style boost range.
Interesting, is that similar to how anti-phasing works? I hear that terminology thrown around a bit however given we aren't in race cars or F1 cars I've never bothered to read further nor investigate further.
4x port was already going into another level for me haha...
    • Hi. This is just my curiosity because iam sure the tuner figure something out...but either way i want to ask. The "problem" is that the Nistune ECU (Stagea FW and RB25DET NEO from Stagea) sees many times the speed than the speedo does(he says the speedo show 120 km/h - correct speed and the ECU shows like 510km/h ) I told him that this car/tranny getting speed from rear diff. If iam not mistaken the RB25DET NEO "need" to see tranny speed sensor? (my tranny has the plug for it). So couple of "question" If he connects/wire the speed sensor to the tranny...are the signals gonna intervene and if...what if he disconnects the rear diff one and the speedo stops working? Or the "new" sensor from the tranny "take over" and will not going need the one from diff? As i said i know he figure/get that done...iam just curious to know what are the solutions 🙂
    • Your IACV is set to idle too low. You need to adjust it via the screw Duncan mentioned. From memory it should be 650rpm with the valve electrics unplugged. What is it trying to idle at with the IACV plugged in?
    • Ahhh, I need the whole head unit. I definitely needed to roll back through and review your setup, ha ha! Neat setup they have going on. I just need a full double din head unit. But I want good and responsive. I might have to review what the likes of pioneer have out these days.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
