Surplize modapuckers lol
This happened today, driving back from work like a normal person. Doesn't happen when I drive like a complete knob, or launch it at 4k.
Anyhow tried off and turning it off and on, that didn't help ?
20190927_182351.thumb.jpg.89d2e9fbac9571962b60dbe4603e8d16.jpg20190927_182355.thumb.jpg.5b249c4220d6e9f137a7d4c7b2e7435f.jpg
So headed out to pick up the missus in this shit box, and spanked the limiter, she didn't like it.
  • Haha 1
1 hour ago, r32-25t said:
Typical German car
Lol yeah but considering it's not even 1.5 years old with 17xxx kms on it, it's a joke!
Modern German cars have a system built into the BMCs and CAN that turn on one of a set of random errors each 18 months for the life of the car to ensure you get rid of it and buy a brand new one just after warranty finishes.
  • Like 1
  • Haha 3
It’s why as cool as I think the golf r is I’d never own one, I’d look at either an sti or the Hyundai i30N
  • Like 1
Man my back is sore lol. A fixed bucket seat, semis, several solid suspension arms, rock hard suspension but yeah ended up doing over 450km today. 1.5 tanks of fuel later ?
Good drive with @PLYNX and my mate in his R33.
Okay, admittedly it was pretty fun and first time I've actually stretched the new setup with a lousy tune. Shoots flames, 11:1 afrs, lazy 10 to 12 degrees of timing but it is wanting to light up 255 Nankang AR-1 semi slick tyres. Still need to swap out thr gate spring to a softer spring, running a 4 port solenoid and with a 1bar spring there's very limited resolution, kept spiking and hitting engine protection.
  • Like 7
I'm sorry I missed the run.
I've spent the day yelling at people and driving back from sunny Singo
Glad your beastie got to stretch its legs.
What's next for the 33, back in the garage for a spell?
Umm no idea to be honest, I said I'll try go once a month with @PLYNX but knowing my life, even that would be hard to achieve.
And here's a dose video and some gate, wallah swear to god I didn't use the photo illegally (didn't talk or text or use social media) lol
  • Like 2
43 minutes ago, Murray_Calavera said:
What spring are you planning to swap to and what max boost are you chasing?
0.5 bar and will run up to 2 bar.
At the moment trying to command 1.3 to 1.4bar is very challenging. Every 1% to 2% change in duty cycle is jumping 0.1 to 0.3 bar of boost. By dropping the spring you end up with higher resolution. Just some idiosyncrasies with running a 4 port. Running a 3 port but across both ports on the gate is a simpler solution which allows decent control too, but I wanted to try out a 4 port setup, so here I am lol.
1 hour ago, ActionDan said:
Can't for the life of me think why it would be showing signs of fatigue or damage ;)
Well it's there to use right? lol.
1 minute ago, ActionDan said:
"The brightest candle burns twice as fast"
That's why people run boosted engines, to get twice the atmospheric pressure :)
Another solution I've come up with for another car I tune which granted, we've not tested yet - and I don't know how flexible the Halaltech is with settings and available outputs, but we're running 2 MAC valves and running one of them against a fixed PWM look up table to "bring up the base pressure", then use conventional boost control to drive the second one as an effort to retain 3-port style table granularity but give a 4-port style boost range.
Interesting, is that similar to how anti-phasing works? I hear that terminology thrown around a bit however given we aren't in race cars or F1 cars I've never bothered to read further nor investigate further.
4x port was already going into another level for me haha...
    • Wanted to add some of my R33 GTST  R34 GTR wheels, 18x9 ET30 with 255/35/R18 PS4S'   BBS RE-V7 029 18x9.5 ET22 with 255/35/R18 PS4S' Needs a bit of camber
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
