40 minutes ago, ActionDan said:
Where can I get one?
https://burubado.com/collections/stickers/products/please-do-not-abusing-of-the-motor-sticker
Could ask for foil sticker, so it's like the one pictured
Lockdown dis dat, anyhow after 3 months of shit just sitting in boxes I decided to do something.
Probably the last time I do something for a while too, my back is sore and my hands are dirty now 😅
Was on the market looking for a used one, wow.. people are wanting like $300 for an used condenser, ended getting a new one for $650.
  • Like 2
14 minutes ago, Unzipped Composites said:
Haha... I threw my condenser in the bin when I stripped the car down, imagining that second hand they were worth 3 cents and a mouldy apple core.
It's covid tax, it has ruined the JDM market.
Long gone are the days of running R33 S2 for $5k to $7k 😔
That's why I chose to go to town and respray and send its mum.
  • Like 1
14 hours ago, r32-25t said:
Where did you get the condenser from?
Amayama, worked out cheaper than local because I bought a bunch of stock seals, gromets, interior bits and bobs.
Vega Motorsports guy has them for GT-Rs at a reasonable price.
Just had a look at r32 ones are almost $1200 😞
  • Sad 1
Can we get thread back on track please.
How are you sydney carnts getting 22c feed in tariff, im in newcastle and did the ring around to every company last year and the very best i was offered was 12c. My solar is about 6 years old now though, are you only getting such a good rate because you got Origin to do a complete solar install?
I can't even imagine getting 50+c a kWh lol
Have a look at AGL, apparently they're doing 20c for the first year!
I'm only getting 22c FIT because I'm going with Origin's Solar system (which is overpriced compared to others, but the only way to get the 22c FIT).
17 minutes ago, ActionDan said:
I just got an email saying I can no longer get 10.2 it's now dropping to 6.7... what the f**k.
Time to go shopping!
Yeah I will, hard in Vic, they all vary so much.
The current mob does a 69c day charge and off peak rates all weekend 😕
In good news, I have found some used Tigo's going cheap :)
  • Like 1
Update, here's a full day's worth of data. Pretty nice sunny day, barely any clouds in the sky.
6.6kW system with 17x 390W JA Solar panels (cheap shit) and a 5kW GoodWe inverter (also cheap shit). Origin didn't really have flexibility with their package choices but after reading into it and also the warranty plus Origin's guarantee of craftsmanship I was sold, especially with the 22c FIT.
We have a North facing double storey house with a colorbond roof. Means theoretically we would get better sunlight coverage.
@PranK what is it with these 250px max width thumbnails? Lol.
1233411653_Screenshot_20210704-222920_SEMSPortal.thumb.jpg.6c4c3765e9769a830d1570eabbffe370.jpg
  • Like 1
would be great if there was a newer nissan you could buy the bits from. i need the whole AC assembly apart from the bit under the dash essentially. im looking at a fortune if i want AC back in my car (which i do)
  • Like 1
    • Ok guys thank you very much. GCG highflow it is then 🙂
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
