On 23/8/2022 at 10:01 AM, Dose Pipe Sutututu said:
2 Step Comp dis dat... funny it's not even "2-step", it's actually anti-lag with a secondary RPM limiter but hey it's cooler to just say "2-step".
Muricaaaaaaaaaaaaa fk yeah.
Same same. Mine is the rolling antilag as well. But I was just sitting still for filming purposes. What I like best is mine is activated with the snow button but makes 🔥 the opposite
  • Haha 2
On 23/08/2022 at 11:04 AM, Kinkstaah said:
2 step is.. just a limiter while the car is not moving 😛
but the silly americans expect it to also shoot flames and make bang bang noises
Just my luck, same with All Jap Day.
Car gods are giving me a sign, don't race your car. Just hard park it and stand next to it only.
  • Sad 1
Man it's annoying, I just want to go racing:
  • All Jap Day, NSW floods, moved to 19th of November
  • Luddenham, NSW probably might flood and hail
  • Wakefield Park, closed after 1st September
Farken.
Farken.
Weather looking good up at Morgan Park, QR and Lakeside........
  • Like 2
I will be doing a track day in the next few months when my net kit arrives
(New Pulsar G30-770 turbo, high mount mani, turbosmart 45mm gate, custom dump and screamer pipes).
Aim is 400-450 HP out of my stock RB20DET :)
Should be fun at 1100kg (Ish)
Will have to T up a track day together :)
  • Like 2
we need more tracks here in NSW :(
  • Like 1
Definitely man!
It's super hard for me to get a day off from work and family duties. When I do, it never works out!
Farken.
All I see here is more time for DCT conversion not lack of track time
  • Like 1
  • Haha 1
Car did not blow up 😆
ABS died, plenty of lock ups after lol. Then cluster died, no tacho so just banged the limiter instead, then wideband sensor decided to die and read 35:1 AFR and engine protection kept triggering lol.
Post up footage soon.
Managed a 1m00.2s, my mate did a 58.1s in the car but he's been to Luddenham several times.
  • Like 2
Yay no need to pull motor out.
So Nexus, IC7 and new sensors??
Where is the wideband sensor? I have actually been putting them further down stream these days so not coping all the heat.
  • Like 1
I like the IC7, just not the casing.
Sensor is after the 2nd bend on the dump, about 20cm before the cat is.
Theoretically that should be far enough from the turbo.
Oh yeah, it was a day hosted by Garmin to test out their hardware 🙂
  • Like 3
Great got it out, how did you find the garmin? So when next day booked?
Is it an older sensor? 4.2 or 4.9 ,interesting its failed.
Ic7 is a big unit, if did something smaller like the Aim would be better and not as intrusive.
Better than the Q Starz unit I had back in the day. Tell you delta, reads out lap times so you don't need to look, then the opportunities screen is mega good.
Acts like a personal coach, shows you what speed you should be going at, how to take lines, etc.
Just waiting for the in car footage from the unit in my car and I'll post it up.
Not too sure when the next track day was, today's one was super last minute. I do have All Jap Day on the 19th of Nov, but that's more "power cruise" than actual racing. There are 2x sprint sessions but that's it.
Sensor wise, I have no idea. It's the first gen Haltech canbus wideband, will need to unplug it and have a squiz at some stage, maybe next year I'll sort it out 😂
  • Like 1
I guess it is aimed at track day not racing, easy to install and use but not the sort of functionality you get out of a proper logger like IC3 or motec stuff
    • And now the washer bottle looks like an orphan. You're going to have to spend money on a wrinkle black painted fabbed ally one of those. Oh, and the brake MC res. That won't look any good after you've gotten rid of the washer bottle. You going to need to go back to work to keep up with this?
    • You're going to need all that and more to keep them from rubbing at the rear anyway, is my guess.
    • Looking at it now the battery clamp needs some love..  LOL One day, but not tomorrow, tomorrow I'm strictly a spectator, the only testing for me tomorrow will be on the coffee and food at the Cafe
    • I purchased some (used but new to me) Yokohama A050 Mediums to try out for the first time and fitted them up to one of my sets of Rays TE Fortesst's. Sizes are 235/45R17 front and 255/40R17 rear. They are very chonky compared to the same sized AD09 on the same sized rim. Some fiddling will be needed to make them fit. How much camber do these like as a general rule? I imagine more than the rear camber of -1.5' I typically run. So my plan is to target -3.8 front and -2 rear
    • If you want to test it under temperature, I think you should enter the One Raceway day tomorrow with Duncan!
