On 23/8/2022 at 10:01 AM, Dose Pipe Sutututu said:
2 Step Comp dis dat... funny it's not even "2-step", it's actually anti-lag with a secondary RPM limiter but hey it's cooler to just say "2-step".
Muricaaaaaaaaaaaaa fk yeah.
Same same. Mine is the rolling antilag as well. But I was just sitting still for filming purposes. What I like best is mine is activated with the snow button but makes 🔥 the opposite
  • Haha 2
On 23/08/2022 at 11:04 AM, Kinkstaah said:
2 step is.. just a limiter while the car is not moving 😛
but the silly americans expect it to also shoot flames and make bang bang noises
Just my luck, same with All Jap Day.
Car gods are giving me a sign, don't race your car. Just hard park it and stand next to it only.
  • Sad 1
Man it's annoying, I just want to go racing:
  • All Jap Day, NSW floods, moved to 19th of November
  • Luddenham, NSW probably might flood and hail
  • Wakefield Park, closed after 1st September
Farken.
Farken.
Weather looking good up at Morgan Park, QR and Lakeside........
  • Like 2
I will be doing a track day in the next few months when my net kit arrives
(New Pulsar G30-770 turbo, high mount mani, turbosmart 45mm gate, custom dump and screamer pipes).
Aim is 400-450 HP out of my stock RB20DET :)
Should be fun at 1100kg (Ish)
Will have to T up a track day together :)
  • Like 2
we need more tracks here in NSW :(
  • Like 1
Definitely man!
It's super hard for me to get a day off from work and family duties. When I do, it never works out!
Farken.
All I see here is more time for DCT conversion not lack of track time
  • Like 1
  • Haha 1
Car did not blow up 😆
ABS died, plenty of lock ups after lol. Then cluster died, no tacho so just banged the limiter instead, then wideband sensor decided to die and read 35:1 AFR and engine protection kept triggering lol.
Post up footage soon.
Managed a 1m00.2s, my mate did a 58.1s in the car but he's been to Luddenham several times.
  • Like 2
Yay no need to pull motor out.
So Nexus, IC7 and new sensors??
Where is the wideband sensor? I have actually been putting them further down stream these days so not coping all the heat.
  • Like 1
I like the IC7, just not the casing.
Sensor is after the 2nd bend on the dump, about 20cm before the cat is.
Theoretically that should be far enough from the turbo.
Oh yeah, it was a day hosted by Garmin to test out their hardware 🙂
  • Like 3
Great got it out, how did you find the garmin? So when next day booked?
Is it an older sensor? 4.2 or 4.9 ,interesting its failed.
Ic7 is a big unit, if did something smaller like the Aim would be better and not as intrusive.
Better than the Q Starz unit I had back in the day. Tell you delta, reads out lap times so you don't need to look, then the opportunities screen is mega good.
Acts like a personal coach, shows you what speed you should be going at, how to take lines, etc.
Just waiting for the in car footage from the unit in my car and I'll post it up.
Not too sure when the next track day was, today's one was super last minute. I do have All Jap Day on the 19th of Nov, but that's more "power cruise" than actual racing. There are 2x sprint sessions but that's it.
Sensor wise, I have no idea. It's the first gen Haltech canbus wideband, will need to unplug it and have a squiz at some stage, maybe next year I'll sort it out 😂
  • Like 1
I guess it is aimed at track day not racing, easy to install and use but not the sort of functionality you get out of a proper logger like IC3 or motec stuff
    • I'm not a big fan of the Cometic gaskets either, as above the head and deck need to be like a mirror (can't remember the RA) so Kamieri sounds like a good idea.  FWIW a mate of mine hordes old motor stuff and has some blank unground Nizmo cams for one of these in his supply if random shit if you're interested.
    • This is aem disk setting in aem tuner and still 180 dgree off or ignition on exhaust cycle is it from cas it self as cas seems wouldn’t fit in cam shaft if wrong position and wiring been verified any ideas
    • Oh yeah that would work excellent. Should be the same diff housing & everything. Shoot me a text or call me 260-750-2246 -Cody
    • Oh right, I didn't realise it was your car. Please do! Makes me feel better about mine. I also have a big scrape on the front left bumper where someone presumably used the wall to guide the car into a parking spot  But somehow all the funds go towards mechanical things and the cosmetics stay forever unfinished... Interesting, I don't think I have seen it before. But after seeing @PranK's rusty roofline on the BMW I'd probably leave it alone. Wouldn't want water to get in there.
    • Thanks mate, thought you might know the answer.
