Why are Americans so stupid?
Ordered an injector harness, selected I wanted EV1 connectors and then I get sent an OEM replacement harness!
  • Sad 1
Wiring Specialties you stupid fat American pricks.
Alibaba 50c adaptors ftw.
Just now, Ben C34 said:
Fire up that front loader, that will cheer you up. Full speed spin cycle
Good plan, I'll go hang a big shit and get that quick wash cycle on with the rpm set at 1400
  • Like 2
9 hours ago, MBS206 said:
Mate, don't talk shit about these guys, they're the Wiring Specialists.
Lol, no they're just cheaper than the wiring specialists here in Sydney.
I am pretty sure over a decade ago they contacted me on Nissan Silvia asking for my wiring diagram I put together for RB20 swaps in S13s. Anyhow, looks like their warehousing/pick and pack guys cooked up the order. They're sending me a new harness, fking anti-climatic day yesterday.
If I had a wild, open cheque book build the car would go to Benny at Benchmark Solutions for wiring.
52 minutes ago, GTofuS-T said:
the little baggies of coke covering the rims weren't a dead give away?
I can't work out what they were on this phone.
It actually looked like two plastic bags with white rags in them!
And if someone has that much coke, they aren't driving a VY commodore...
Edit: wait, that's a picture someone has printed and placed the baggies on top of yeah?
f**k me, I is dumb Ha ha
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
