Clutch upgrade
Hi all
i am deciding on my clutch to support my max 500 bhp at flywheel.
i have seen numorous brands, what brand will you pick or well known?
would you also install a lighted flywheel?
i have seens clutches from stage 2 to 4.
is there any harm in installing stage 4 if I don't need it?
i think stage 4 is 500 bhp and above
finally would you have a go yourself to replace it? Is it a tough job if you are one man ?
i was thinking i could get a transmission support
https://www.sau.com.au/forums/topic/468306-clutch-upgrade/
This isn't need for speed, ignore the whole stage 1,2,3 crap
Call NPC Performance clutches. Aus made (use some exedy stuff) and do a good product. I have their lightned flywheel and 10" sprung button clutch in my car, had it for years and has always been great, pedal feels resonably light
They also do a twin plate if you want to go all out
  • Like 1
https://www.sau.com.au/forums/topic/468306-clutch-upgrade/#findComment-7800986
Please Google first and then post here if you still need more help. Usually Google will point you to a number of SAU posts as most subjects have been exhaustively discussed over the years...e.g.
which clutch for modified Skyline
or...what clutch for 300kw RB
or.. how to replace clutch on Skyline R34
etc
also scroll down to
Tutorials / DIY / FAQ  and see what help is available there.
Warning: doing a clutch by yourself can be dangerous so read all the instruction carefully so you don't get pinned by the car or have a gearbox fall on you !
https://www.sau.com.au/forums/topic/468306-clutch-upgrade/#findComment-7800988
1 hour ago, stranger12 said:
I looked at exedy and extreme but again some dealers sell it with stages attached hence why i asked
Nobody who knows anything about clutches uses the word "stage".  Same with cams.  The only thing that comes in stages is the mail in the wild west, 175 years ago.  Oh, and nitrous.
  • Like 1
https://www.sau.com.au/forums/topic/468306-clutch-upgrade/#findComment-7801009
Stage 3 nitrous or 3 stage nitrous?
:D
https://www.sau.com.au/forums/topic/468306-clutch-upgrade/#findComment-7801099
Sorry to jump in this topic like this. Does anyone know what power rating a nismo 30210-RSR40 clutch kit is rated for rb25. Maybe this would also be good for his application. I have one sitting here but have no idea what power it can handle.
https://www.sau.com.au/forums/topic/468306-clutch-upgrade/#findComment-7803987
From GTR UK:
Standard Nissan cover produces 900 KgF Clamp force
Nismo 30210 RSR40 produces 1050 KgF
Nismo 30210 RS581 produces 1200 KgF
https://www.sau.com.au/forums/topic/468306-clutch-upgrade/#findComment-7804000
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
