Attended Wilby Motorsport Park for Round 4 of our series, round 5 is also there in 6wks or so.
It's a very short course with laps ranging from 32-40sec. It's a bit agricultural, but the vibe is fairly relaxed.
I went on my old 235 RS-Rs to see if I could have a class win on those and save the AR1s. I forgot to turn the camera on which is shame as I almost died a number of times in that first session, to be fair it was cold but my god the lack of grip was hilarious - did a 37.7 or so and was .7sec behind the class leader and not overly confident I would catch him - swapped back to the AR1s after the first session.
Ran a 36 flat in S2 then squeezed a few more tenths out of it to run 35.7 in S3 which was good enough fro a class win and a top 10 outright finish. Sat out S4 as the 2nd place car had mechanical issues after running a mid 36 and 3rd was too far away to catch me - was nice to pack up and be home earlier.
Tried a new breather setup which looks like a hot mess due to piping length etc, but is finally keeping oil in the car with only minimal oil accumulating on the lip above the firewall from the breather.
It's now 2 stage with rockers/balance pipe all Tee'd and into 1 port on a baffled can with sump drain, outlet from that can feeds another baffled can with an filter to Atmo.
I now have the rev limit warning set 6700 rpm as torque starts falling away then anyway and it limits how much oil is being pumped to the head. Oil surge is still evident on quick direction changes, but I'm guessing it's always had it.
If I manage to win the remaining 3 rounds I'lk have had 10 straight wins in my class, which will be a fitting send off for the CA, if it doesn't die first.
Bought a balancer for the SR and have been looking at clutches and manifolds - went ATI in the end. Was told my shipment of the main group of parts (pistons, rods, head gear, studs etc etc) is just about ready to ship and my head studs were just picked up from Mazworks - they're only ARP, but apparently they have a custom length that bottoms out properly that people swear by so I grabbed those.
Started test fitting the passenger seat, just need a few locking nuts etc.
As always, here's a hotlap in 1080p and 60fps including a little B roll footage.
Edited by ActionDan
I'm still trying to get some objective reviews.
It's difficult as nobody locally specialises in SR20 and that makes it hard to walk into a workshop and get a feel for the place.
I'm also keeping in mind I'd always wanted to do it myself, with assistance from a meticulous mate of mine who builds motors as part of his work (albeit diesel), but the cost of getting it wrong adds up quickly.
I realise there's rarely, if ever, a warranty on a built motor though.
All very good points. If your buddy knows what he's doing and sticks to the recommended clearances, shouldn't really be an issue but i see where you're coming from and for the sake of an extra K or 2, may be better to just pay up.
If you decide to use a workshop, ideally you would want one with ample sr20 experience. Not sure if you have a local sr expert up there. There's a couple of shops here in Melbourne that pretty much specialize in them.
Rob from Sabbadin automotive and Donny from forced motorworx both come to mind as SR gurus and have built that many they could probably do it with their eyes closed.
They're the sort of guys id be considering if it was my engine. Food for thought, im sure you'll work it out by the time the rest of the parts turn up.
Bit more than 1-2k really given some of the quotes I've had (though they include assembling/clearancing the head, all machine work etc).
The only person who's jumped out at me so far as having genuine SR20 Circuit experience (rather than street/drag focused) is DM Motorsport, the one who owns that SuperGT S15. He claims to have acquired the testing data for SR20 race engines with the car and a few other insider secrets. He has shared a few things so far that line up well with some of my own research into weaknesses/how to avoid etc but he is far from cheap and he's in Sydney. He's given me a reference, but as with any business, I'm sure that reference will only have good things to say.
Sump is here. Got the aeroflow one, plenty of capacity, trap doors etc.
Image result for aero flow SR20 sump
A bit of stuffing around with harness lengths and the inner eye bolt position on the inner mount but got there in the end.
The side holes are smaller on this seat and don't allow the buckle to fit through the hole nicely which is an issue as the lower strap portion is too long and sits too close to the eye bolt to be tightened safely on the inner.
I ended up having to mount the eye bolt further forward and on the seat mount itself rather than the rail. It seams to snug up nicely but we'll see how it goes at the track.
Sits a bit higher than I'd like but I sit high in a seat compared to mates, should be fine for the missus, will test later.
Total weight is approx 13kg vs say 20-22kg or so that the Falcon's Autobarn buckets are.
  • Like 1
  • 3 weeks later...
Chipped away at the donor, think I found what happened to it lol
Bores all look good, that is a deposit on the bad cylinder, not pitting etc.
Head is in very good nick and will be sold off.
Got an awesome new work light for my birthday, thing is ridiculously versatile, cant wait to use it.
Main shipment of bulk parts is on the way from NZ!
Did half a track day yesterday, packed up early as I had set a decent time in first session and spent the second mostly off the track.
Really struggling to get the brakes up to temp and working, even with the ducts covered.
Taking me 2-3 laps (35-37s laps so only short track) to get them warm.
Only have a small tyre window by that stage as they are going off sooner as they age.
Attacked a witches hat and had to bend the winglet flat. I was going to lose those in the V3 splitter anyway.
We found out the the trailer I borrow had damaged stub axle..
Thankfully that happened at home 0_0
Class win, no PB.
I will get this setup through to the end of this season then go from there as i may end up with 5 stud/different brakes yet.
I have new project mu rotors and pads on the shelf, in 4 stud, so may use those yet.
You got tyre hookups yet?
    • This sounds like someone who would have owned an R33 in their past... It's okay, I'm 100% picking up what you're putting down Mark.
    • Just back on what was raised about jacking off the the tow/tie down point on the front of cars. I've used it plenty. I've also watched it on a car where you could see it move the front end of the car. It was like the front end/whole car being tweaked and twisted a bit. I will say, I struggle to find good jacking points on MOST cars. The ones that have good points, I then normally struggle to find a jack tall enough to make the car change height!   One of my go to points for either the jack, or the axel stands though, is either a suspension pickup point, OR a subframe to chassis major bolting point. I actually think its the subframe on my R33 that has a bit of a bend in it, from being jacked in the middle too. However, it could have been one of my many other cars I've had over the years! Or it could also be the from me jacking it up, and the fact the top of the front radiator support isn't there, so it can allow the front of the car to move and bend etc.
    • My apologies. I forgot we were talking about weird beard M series stuff. Had been talking elsewhere with someone about an R33 with similar subject and got confused.
    • Nope, I don't like the look of ND RF, or any ND really, I don't like their faces or arses, why, because of their "modern" lines, the NC, whilst "modernish" has a more rounded shape that I like Well, that's how my overly judgemental eyes see it anyway
    • Should be more than fine, especially the overall fuel pressure would never exceed 3.5bar (assuming that thing never gets more than 0.5bar of boost in stock form). According to the chart, it's 11amps.
