Attended Wilby Motorsport Park for Round 4 of our series, round 5 is also there in 6wks or so.
It's a very short course with laps ranging from 32-40sec. It's a bit agricultural, but the vibe is fairly relaxed.
I went on my old 235 RS-Rs to see if I could have a class win on those and save the AR1s. I forgot to turn the camera on which is shame as I almost died a number of times in that first session, to be fair it was cold but my god the lack of grip was hilarious - did a 37.7 or so and was .7sec behind the class leader and not overly confident I would catch him - swapped back to the AR1s after the first session.
Ran a 36 flat in S2 then squeezed a few more tenths out of it to run 35.7 in S3 which was good enough fro a class win and a top 10 outright finish. Sat out S4 as the 2nd place car had mechanical issues after running a mid 36 and 3rd was too far away to catch me - was nice to pack up and be home earlier.
Tried a new breather setup which looks like a hot mess due to piping length etc, but is finally keeping oil in the car with only minimal oil accumulating on the lip above the firewall from the breather.
It's now 2 stage with rockers/balance pipe all Tee'd and into 1 port on a baffled can with sump drain, outlet from that can feeds another baffled can with an filter to Atmo.
I now have the rev limit warning set 6700 rpm as torque starts falling away then anyway and it limits how much oil is being pumped to the head. Oil surge is still evident on quick direction changes, but I'm guessing it's always had it.
If I manage to win the remaining 3 rounds I'lk have had 10 straight wins in my class, which will be a fitting send off for the CA, if it doesn't die first.
Bought a balancer for the SR and have been looking at clutches and manifolds - went ATI in the end. Was told my shipment of the main group of parts (pistons, rods, head gear, studs etc etc) is just about ready to ship and my head studs were just picked up from Mazworks - they're only ARP, but apparently they have a custom length that bottoms out properly that people swear by so I grabbed those.
Started test fitting the passenger seat, just need a few locking nuts etc.
As always, here's a hotlap in 1080p and 60fps including a little B roll footage.
Edited by ActionDan
I'm still trying to get some objective reviews.
It's difficult as nobody locally specialises in SR20 and that makes it hard to walk into a workshop and get a feel for the place.
I'm also keeping in mind I'd always wanted to do it myself, with assistance from a meticulous mate of mine who builds motors as part of his work (albeit diesel), but the cost of getting it wrong adds up quickly.
I realise there's rarely, if ever, a warranty on a built motor though.
All very good points. If your buddy knows what he's doing and sticks to the recommended clearances, shouldn't really be an issue but i see where you're coming from and for the sake of an extra K or 2, may be better to just pay up.
If you decide to use a workshop, ideally you would want one with ample sr20 experience. Not sure if you have a local sr expert up there. There's a couple of shops here in Melbourne that pretty much specialize in them.
Rob from Sabbadin automotive and Donny from forced motorworx both come to mind as SR gurus and have built that many they could probably do it with their eyes closed.
They're the sort of guys id be considering if it was my engine. Food for thought, im sure you'll work it out by the time the rest of the parts turn up.
Bit more than 1-2k really given some of the quotes I've had (though they include assembling/clearancing the head, all machine work etc).
The only person who's jumped out at me so far as having genuine SR20 Circuit experience (rather than street/drag focused) is DM Motorsport, the one who owns that SuperGT S15. He claims to have acquired the testing data for SR20 race engines with the car and a few other insider secrets. He has shared a few things so far that line up well with some of my own research into weaknesses/how to avoid etc but he is far from cheap and he's in Sydney. He's given me a reference, but as with any business, I'm sure that reference will only have good things to say.
Sump is here. Got the aeroflow one, plenty of capacity, trap doors etc.
Image result for aero flow SR20 sump
A bit of stuffing around with harness lengths and the inner eye bolt position on the inner mount but got there in the end.
The side holes are smaller on this seat and don't allow the buckle to fit through the hole nicely which is an issue as the lower strap portion is too long and sits too close to the eye bolt to be tightened safely on the inner.
I ended up having to mount the eye bolt further forward and on the seat mount itself rather than the rail. It seams to snug up nicely but we'll see how it goes at the track.
Sits a bit higher than I'd like but I sit high in a seat compared to mates, should be fine for the missus, will test later.
Total weight is approx 13kg vs say 20-22kg or so that the Falcon's Autobarn buckets are.
  • Like 1
  • 3 weeks later...
Chipped away at the donor, think I found what happened to it lol
Bores all look good, that is a deposit on the bad cylinder, not pitting etc.
Head is in very good nick and will be sold off.
Got an awesome new work light for my birthday, thing is ridiculously versatile, cant wait to use it.
Main shipment of bulk parts is on the way from NZ!
Did half a track day yesterday, packed up early as I had set a decent time in first session and spent the second mostly off the track.
Really struggling to get the brakes up to temp and working, even with the ducts covered.
Taking me 2-3 laps (35-37s laps so only short track) to get them warm.
Only have a small tyre window by that stage as they are going off sooner as they age.
Attacked a witches hat and had to bend the winglet flat. I was going to lose those in the V3 splitter anyway.
We found out the the trailer I borrow had damaged stub axle..
Thankfully that happened at home 0_0
Class win, no PB.
I will get this setup through to the end of this season then go from there as i may end up with 5 stud/different brakes yet.
I have new project mu rotors and pads on the shelf, in 4 stud, so may use those yet.
You got tyre hookups yet?
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
