That's a big turbo dude, but no doubt it be like warp speed on boost being a 1300hp odd turbo. What sort of power realistically are you targeting ? Sounds like your goal posts for power expectations have moved quite a bit now.
I too second the Samsonas band wagon 🙃
  • Haha 1
Power? I don’t even know anymore? In my head it’s still the same, 500kw (which is what the old setup made) for street, that felt perfect. The 7675 will probably make that on 20psi.
for drags/roll racing??? Whenever the turbo taps out?? Lol
Id expect somewhere between 750-800kw on the higher boost settings.
I’ve locked in a set of IDX 2600 injectors to take care of fuelling
samsonas seems the popular choice by most
  • Like 1
On 11/4/2022 at 2:32 AM, r32-25t said:
Be interesting to see how it goes and what it drive like. I’m starting to think you’ll be on the road be for me
Knowing my luck will be a laggy pig.
I doubt I’ll be on the road before you, I feel like I’m going backwards
  • Like 1
Same, I just found more that needs replacing and I’m still no closer to having an engine as far as I can tell
We’ll my motor is being stripped and going back to machine shop next week, so back to having a bare block like yourself. Lol
  • Sad 1
If it makes you feel any better I've only done 1070km on my new engine in 18 months- 120km of that at full 600kw+ tuned.
So goes to show you that you can complete your end goal and then be like....what's next ?
Sometimes it's better to just get the car on the road without holding yourself up on the minor obsessive / compulsive details to make things perfect, as it doesn't necessarily make you drive the car any more frequently.
Yes, we don’t get to enjoy these nearly as much as we should. Yes I am being obsessive/compulsive, I want it done and finished, I would like to have it to a point where I can just take it out (with confidence) and enjoy it.
There is a big difference between not having time to drive it, and not driving it, because you don’t trust it will make the trip or it’s just plain not enjoyable to drive. It’s been a long time since I’ve had the confidence to take the car on a decent drive.
The only one in the industry who I trust, no longer does mechanical work, so I’m left relying on shops who more times then not, do not deliver on their promises. So I try to research and talk to as many owners and people in the industry that I can, to hopefully make informed decisions of what I use to put the car together.
It would probably help if I just set 1 goal for the car, trying to make it ‘versatile’ has been the most difficult part.
Im not stupid, I’m well aware that I have selected a turbo that screams ‘straight line warrior’ and a gearbox that’s all ‘street’. Not a good match, obviously.
Really, a 6466 on the 2.7 with the getrag would make the best street car.
It’s probably what I should be doing, but it won’t give me the top end I’m chasing, I want one boost setting in the car that’s completely nuts, the 7675 will give me that, but at what cost??
The 6875 was supposed to be the great compromise, decent response, good top end, now I’ve been convinced to go 3 steps in one direction. And it wasn’t one shop or person who convinced me, I spoke to numerous people, friends and other GTR owners.
Some are telling me massive loss in response, other say it’s not that bad? I don’t know???
I’ll be talking to the machine shop on Tuesday in regards to options in getting static compression up, want to try to run somewhere between 10 and 10.5-1. Let’s just see where we end up 🤷🏻‍♂️
  • Like 1
I think you need to really define your goals first before committing on things. I feel that these days it's too much about who can make the most power, post up the biggest numbers (hence the use of hp instead of kW), etc. Go for a drive in a few big powered GT-Rs, drive it to the city and back and really understand what you want in your car.
Write down road goals, then select the parts to suit. You'll probably come to realise that massive turbo you want may not suit your goals, needs and/or requirements. At the end of the day, you still need to remember you have a whole 2.7L (unassisted, no VCT or VCAM) of displacement to move that turbine wheel.
Probably not a like for like example but for my car but to put things into perspective. I wanted everything on before 4.5k RPM, 4k worth of usable RPM and close to or a bit more than 500kW at the wheels. Car needed to be competitive at the race track, crack the 200km/h goal down Wakefield Park, with also enough power to go have a cheeky crack at the drag strip and do a high 10. I easily could have listened to everyone else and go a big fk off turbo and make the car a pile of lag to drive but I didn't - also helps I'm a stubborn karnt.
So in conclusion G40-1150 twin scroll the lot, and BMW DCT swap 😎
  • Like 1
Now you're showing off.
That's more than all of us combined lol.. my car is done, I've driven it 4x times (includes yesterday) in 3 months. Still haven't tuned it, even Alex from Birrong keeps asking when I'm coming in to use his dyno lol.
The number of people who have told me I should be aiming for 1000hp because I’m spending so much on the engine is insane, I keep telling them it wouldn’t drive like what I want and I’d end up hating the car
  • Like 1
Damn straight, you'll hate the car!
Sure if you went to Roll Racing and the strip weekly it wouldn't be so bad, but you don't and it's a street car too.
On 18/04/2022 at 11:23 AM, TezGT-R said:
This is exactly what I'm doing with a 3.2
Should be fun when it's finished.
You'll cum your pants each time you drive.
At least your prostate will be healthy 😂
  • Haha 1
Thanks for the input mate, I appreciate it. I probably need to be more stubborn like yourself. I had a long chat with R32 25T about it the other day. The man I’m using, who will be setting up the motec is considered one of the best in the country and is heavily involved in many time attack, circuit and targa cars.
My goal for the car is for it to be set up as a targa/circuit car, that can be driven on the street.
I think I’ve said this before but I want a turbo that can comfortably make 450-500kw in street trim, but have enough head room to make decent power when turned up. When I saw the stats on the G40, seemed like the perfect option, I discussed this with him and was advised the 7675 would likely outperform the G40 in all areas, and he didn’t just talk, sent me dyno sheets and engine specs of what he had done and what results were achieved, and they were very impressive.
on a 2.7, but running 10.5-1 comp it made 1000nm of torque at 4600rpm, it then holds 1000nm to 10000rpm, topping off a peak power figure of 800kw at the hubs.
All this at a lazy 34psi of boost.
We had a long chat about turbo choice, but if I can achieve the above, that would be insane, with the ability to turn it down for the street.
I was told a proper set up 6870, not 6875 as he had no data on that turbo as he won’t consider anything not twin scroll. It would be more responsive, from memory was somewhere to the tune of 600 odd rpm, but you would only notice this on your first hit, getting the turbo on, once on (between gear shifts) getting off/then on the throttle, they found virtually no difference in response.
I will be talking to my machine shop tomorrow in regards to getting compression up to at least 10-1.
  • Like 1
7675
Targa / circuit car with a 7675, so an 8 second 150mph + targa / circuit car ?
Sounds reasonable
On 18/4/2022 at 2:37 PM, BK said:
Targa / circuit car with a 7675, so an 8 second targa / circuit car ?
Sounds reasonable
I can’t wrap my head around it either, but have to be guided by the best in the business.
im in the rabbit hole, just got to keep digging till I get to China! Lol
don’t worry, there will be an Albins going in before you know it, it’s the logical next step
  • Like 1
I’ve bought, the same turbo and manifold that’s in this car, same ecu, pdm and software package.
And the same man will be setting it all up for me.
and there’s a few more that have made the change, I’m not exactly the Guinea pig here, last piece of the puzzle is to get the static comp of the motor up, which I will be doing so I don’t end up with a donkey.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
