Got a couple of more deliveries today, steering rack was done and dropped off for coating, should be good to get the front subframe in the car in the next couple of weeks. Be good to actually start putting it back together.
  • Like 2
On 22/4/2022 at 7:52 PM, r32-25t said:
Must be nice to have forward progression
Just getting stuff done/ ready, forward progression will be when the front end is back in. Active we’re really good, got the rack turned over in 24 hours, wish all the shops were that efficient
On 23/04/2022 at 8:37 PM, Old man 32 GTR said:
Picked up an uncut bonnet today.
Absolute bastard 😤
If that was under 2k I'm impressed. The old man is bugging me to change our white 32 back to stock but everyone wants a pound of flesh for them 😡
On 23/4/2022 at 11:38 PM, BK said:
Absolute bastard 😤
I paid $2700 for it, I remember when bonnets were under 1k, some are asking 4K+ for them. All you can do is put the feelers out and see what pops up, I did a WTB add on the FB GTR groups, got about 4-5 responses, so they are out there, but like you said, pound of flesh, some want 2 pound! Lol
Twin scroll manifold, with pulses split to the gate, looks the business!
Silly to go single scroll these days, not sure why go many big setups still do this when you have beautiful manifolds like that!
On 07/05/2022 at 12:46 AM, r32-25t said:
Only reason is because a lot of turbos aren’t available with twin scroll housings any more
Blame Murica, they're too busy doing twin turbos on everything they can find.
And from an educated guess, they're the world's greatest consumers of turbos and soon RBs lol.
Well with a 7675 strapped to it, I’ll need all the help I can get to get it on boost.
  • Like 1
On 27/03/2022 at 8:38 AM, Old man 32 GTR said:
That is all suitable, They can even do plastic parts, he showed me a fuse box cover from a VL he did, looked brand new. I’ve given him a few plastic parts, I’ll post them when I get them back.
Thanks for the info.
Received my first batch of Cerakoted parts today and they look so nice and OEM.
This will become an addiction. Bye bye bank account balance.
  • Haha 1
Awesome, amazing what they can do and makes a huge improvement on the look of the car.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
