Car Price Changes
Hi,
Just wanted to get another person's input as i'm not sure the reasoning. What is with so many cars these days listing their price and increasing it by large increments a few hours/days after listing. Like most individuals who follow the cars will know it has increased and many especially on carsales have notifications for price changes. Anybody have any clue?
Regards,
Peter
  • Like 1
https://www.sau.com.au/forums/topic/471829-car-price-changes/
No idea man but the 32 gtr I got this year was advertised at $36,999 in November last yeah then the price went to $39,999 in march this year, I went and had a look at the car in may and mentioned the price change, we haggled for abit and I still feel like I got it for a good price but I wish I haggled with him prior to the $$$ increase in march lol
This is someone trying to make a quick buck, this car was sold the new owner has listed it for 120k.
One guy also bought 2 33gtrs both of which I had looked at.
The new owner then advertised them a week later for 10k and 15k over what was previously asked
AND they have now both sold!
I think the OP is referring to the same seller, i.e. "increasing it by large increments a few hours/days after listing." and it's probably because they've under priced it originally, had 10 people instantly say i'll buy it at the asking price and realise they might be able to get more.
  • Like 1
Interest and people putting money on the table are different things. I see these cars which have a random price increase and then still sit on carsales for months on end. Not many R34's move from what i've seen unless they are priced realistically as it seems importing it better value for money for those cars at the moment. Also a big flood of dealer imports atm overcharging massively
23 hours ago, 21PC said:
Car Price Changes
Hi,
Regards,
Peter
Your on the money there Peter, I have seen heaps of these prices going all over the shop.
The white R32 in Victoria was put on Carsales the other day for 33k and an hr later it was 39,900..
Another is a silver one in nsw was 39,990 then went down to 35,x00 then up to 36,800 for a month and now it's back at 39,990 haha.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
    • I got adjustable after market rear camber arm to replace the stock one's because got sick of having to buy new rear tyres every few months. Can anyone please let me know what the best adjustment length would be. I don't have the old ones anymore to get measurements. I'm guessing the stock measurement minus a few mm would do it. Please any help on replacing them would be fantastic I've watched the YouTube clips but no-one talks about how long to set the camber arm to.
