I feared that might be the case. Though Garrett say suits 1.4-3 litre engines...assuming they're not talking about Group B rally cars lol...scaling that up, a pair of G25s in lightest trim could be good for a 26/30?
Are you willing to go balls deep with custom manifolds, head work and piping etc Birdy?
Even then still realize you are talking about a potential 1100hp setup so its going to be laggy lol
I actually had in my mind the sizes of the larger one (660) as the size of the smaller. Still, the 550 is the same size compressor/turbine as the -5, so barring the slight reduction in inertia from the webbing of the turbine disc being removed lag would be similar. Airflow would be greater but this could prove a challange to manage with restricted pipework etc.
Now, if the release a G20-440 or something like that.. that has -5 flow in a smaller size... that'll be a good candidate.
-5 lag on RB30 I can definitely deal with, particularly if it's going to be punching well above its weight. It's not unbearable on a 26. That would fill the middle ground that make people want -10s but scared off by the lag.
  • 1 month later...
  • 1 month later...
Yeah for sure Disco..
There's already plenty of turbos in that size range that we run on our RB's... things like 2510, 2530, 2860, 2867, 2871 etc etc etc... yes they chock a little but they all perform well on low level RB engines.
As Disco said^ if these things flow the numbers Garrett are claiming, they'll be in the billet 3076 range on an rb25..
1st results in I've seen/heard of [emoji106]IMG-20180222-WA0012.thumb.jpg.02280bcd8cf4811760fdc56f9eed05ab.jpg
  Just read the comments, it's the G-25 550 on a forged 2L engine on 99ron and using the .72 a/r rear housing.
This is looking very promising. Imaging what the G-25 660 on an RB25 with the same or next size up housing might be able to achieve and than add e85 to the equation [emoji848]
We might see GTX3076 high boost type power with response like a HKS Gt-Rs...
Here's the Facebook link -
EDIT: f**k....just noticed it's in flywheel HP [emoji17]
Interesting - thanks for that .
I think we can safely say that either of these G25s could do a lot better than a GTRS on an RB25 particularly in the upper turbine housing sizes . The $64 question is what happens to turbo response with big housings on G25s .
I know its early days but the T25 or V band mount option is going to be a deal breaker for some . At least EFR offers a T3 mount plus integral waste gate on their B2 (I think it is) frame  turbos . I did search to see what was available in 3" V band to T3 adapters - but they won't be a compact arrangement . Having stainless steel means at least fabricating changes is a bit easier .
Given the release time on the G series Garrett is taking a long time to get them out there - and even longer to release info on the slightly larger versions supposedly in the pipe . I'm hanging out to see what the next turbine size up is capable of - and I'm guessing it won't have to be very much larger to be just what many roadies want for a street RB25 . EFR chose 58mm for their medium sized B1 units , if Garrett does something similar then they should be able to achieve GT30-GT35 type performance with hopefully better turbo response than either of these .
Time will tell .
A .
  • Like 1
I feel like I'm missing something, why are you guys implying this is a disappointing result?  I doubt that's on kill, it's not on E85 and it's not given anything away to the GTX3071R (which is a very proven performer on RB25s) but picked a lot up in spool - despite using the bigger housing, which would be more suited to the 660 compressor on a 2litre.
Where has it gone wrong?
Edited by Lithium
    • Echo the awesome sentiment 👍 Definitely a car worth saving. Looking forward to seeing updates as well.
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
    • The maxpeedingrods turbo is cheap and bolts on to stock parts. I think you just need a bigger silicone coupler for the intake. Its a cheap china turbo, but it's been running on mine for almost 3 years at 16-19 psi.
    • What do they look like right after you've tried to start it with everything connected? Also post photos of what they actually look like.
