15 hours ago, Komdotkom said:
What does everyone think about PSR vs Garrett? I've got a genuine G30-770 but would probably get away with a G35-900 because I've got a sequential.
Are the real ones worth more than double the price?
Mate i've used PSR turbos for years now and have never had an issue with them, the wheels measure the same as the real thing and i've seen them make the exact same power on the dyno pretty much back to back. Its upto you whether you'd want to spend the extra cash.
My opinion is they aren't worth double at all.  Have used a good number of Pulsars with builds I've been involved with and tbh at least speaking for myself, Garrett aren't losing money they'd be getting if Pulsar didn't exist as for genuine Garrett money I'd probably be buying something other than Garrett.
We've used Pulsar 6262G (G35 900 equivalent) on an RB26 with a twin scroll hotside and it picked up 40wkw at the same boost over the old twin -5s and the improvement in transient response over the twins changed the car - this is before you factor in the amount of further headroom of the G35.  Have also used one on a 2JZ drag car which has run 9.6 @ 141mph not even trying, from what we've seen so far it'll potentially go 8s when we turn it up
Crazy results for what is basically a NZ$1500ish turbo.
Thanks gents, I think I'll get a PSR and see how it goes. I saw an interesting video in YT where a guy stripped one and the bearings were similar to the GTX series instead of the newer G series, but for 40% of the Garrett price I suppose there has to be some sort of trade off!
  • 2 months later...
Hi all,
Still trying to decide on a turbo/manifold for my built RB25. I'm leaning towards a G30-770 1.06 T4 twin scroll but I'm confused about reverse rotation/standard rotation. Is it possible to run either on an RB? I was keen on an Artec manifold but as they only make V-band for the G-series, what other options do people recommend?
2 hours ago, BiZbAiRd said:
Hi all,
T4 twin scroll G30-770 is about perfect for around 600whp rb25/6. In my experiences twin scroll set up spools at least 500rpm quicker and has quicker transient response than single scroll set up. Use Sinco or 6 boost t4 divided/twin scroll single wastegated manifold, as they have proper divided wastegate pipe for full benefit of divided/twin scroll set up while only using single wastegate thus cheaper than most other t4 divided manifold which uses 2 wastegates.
For an rb, reverse rotation turbos allows shorter exhaust pipe to turbo which should make quicker spool/response, but there are fewer available reverse rotation turbo options. Artec made reverse rotation manifold as quick response based on shorter exhaust pipe to turbo and G35s as biggest turbo size to fit. Afaik, no comparison test were done between Artec reverse rotation quick response set up vs proper 6boost/Sinco twin scroll set up which use longer exhaust pipe to fit standard rotation turbos, so no proof if Artec reverse rotation set up spools quicker than proper twin scroll standard rotation set up.
For bigger turbos, G40 and up, Artec made only standard rotation manifold with longer exhaust pipe to turbo needed to fit standard rotation turbos on rb. Most other exhaust manifolds are only for standard rotation turbos which has much more turbo options, either small or big.
Did a boost leak test today, turbo is a Garrett G30-660. I suspect I have some pinhole leaks in my welded hard pipes but didn't even get that far as the system wouldn't even hold more than 5 psi, with a huge air leak audible from the rear of the compressor housing. Turbo wouldn't have done more than 5000 k's. Hoping it's just the 6 housing bolts needing tightening but wouldn't mind getting a new o-ring compressor housing seal to have handy when I pull the turbo off, but can't find any listings outside of the USA. I'm assuming any turbo repair shop could get me one but anyone know any online sellers in Aus that have these?
1.06 A/R is the only option for G series T4 twin scroll, is it to big???
There are industrial o-ring suppliers all over that would probably have what you need, so long as you know the dimensions and material.
Depends on your hp target/if you want to max your turbo, in my experience a twin scroll housing will spool like a much smaller single scroll housing, with little to no loss of peak hp. If you want quickest spool, Pulsar sells 0.85 t4 ts housing for g30 and g35 at less than half price of Garrett's housing.
  • 8 months later...
Hard to find reliable dyno results that help my selection
Thinking G30- 660 twin scroll 1.06
Problem is my current setup isn't imo terrible. This is the genuine flog it at the track tune so there is a few kws in it but pulled for track safety
Non VCT RB25DE home built and has baby 256 Poncams, 60mm throttle body. 90mm exhaust and decent ARC cooler with Emtron KV8
Would like to break 400rwkws on 20-21psi and want a bit more through the 4,000rpm range. New setup needs to beat attached dyno which hits 200rwkws at 4,100rpm
For reference, maybe irrelevant to most but, no compressor housing o-ring in the G-series, it is metal-to-metal flange seal. My leak was elsewhere.
Indeed it would be google, as it would certainly bring up the image result if I had posted it. I have hardly driven that car for a long time now but once the current upgrades are done and the engine is back in the car, will be headed back to the tuner and will post the result. I would estimate around 8% increase over the previous setup.
On 17/05/2025 at 7:08 PM, Roy said:
Twin 2860-5s
Oof.
One of my mates has an R34 GT-R that he initially was a "I want to go twins for response and convenience" on his stock 2.6 with Kelford 272 cams, but his friends are pests and were always in his ear about their place being in the bin.   Eventually one of the 2860-5s decided to add it's own input and force his hand, so he conceded and went for a Pulsar 6262G ("G35 900") with T4 0.85 hotside.
Here's an overlay of the results, same cams, same stock bottom end, same boost, same fuel, just from a pretty tidy 2860-5 install to a Pulsar turbo on a 6boost maniifold on BP98.   Worth mentioning here, it may seem like a dead horse thing but the dyno plot doesn't tell the story of how much better it is to drive - transient response has completely changed the car, he used to have flat foot shifting to stop it having to wind up again on gear changes even at >7000rpm... now it builds boost faster than that even short shifting.   It's 100% transformed the car before you even consider how much better it holds on:
Pulsar and Garrett aren't the same, but from our experience if you're just looking for a better drive and the ability to make the same or more power I think the divided G30 770 would probably be the smallest I'd go to.
  • Like 1
  • Thanks 1
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
    • Bloody apprentices! 🙄
