Just wanted to share with everyone some concrete information regarding replacing boot struts on R33 skyline, specifically the GTR but I am sure the information will be transferable. The reason I am posting is that there wasn't much information regarding pressures & the ability to remove the strut from the bracket (requiring drilling).
What I did ended up costing me $110.
Below is a picture I pulled from another thread, this is the part of the strut that is hard to remove. Very hard, but not impossible. What we did was use my 10mm spanner and wedge it in between the ball and the strut, then slowly work the it off. It looks like it's going to snap the strut and it ends up destroying it, but that's ok because new ones are cheap.
This is what mine looked like in the end.
_l_YlkhMrhBQ8EuTW0y2zCoronteQxKCJER7sheMowcDwPIacsgt8UsL1x21IK-aTNXtvJXg3_kDwKUO7ncCs5DhF97OgP03zCT2utJVgpasCM6swm6c6yBZghppOjRhrCDRNymusekRCAFCSLVeDDiJm-IyBLP34tFaLLj8iCNpO2l6-UBwXrdBHA8BrnRC2PnUvzFoIlPfql9mXz8kCw2L9ytvHw6U1scTkSBwqeMqsIX3wNksn_sPAbpZy7Kvlh3mOQGX7KphM2zUYUYY7fQyb_6DonTPI7HHveh-rqFTAxWNHIakGcNYvps9VAVQj_mvLAeoAlYLLJc-G9y9JH0t6EtBHhm5yN24o8_VHlDPboaZSpn4JoPdTUqAsb1Bh6kMrn--BwO5A_lftYEt7veVc8Mlg_eRZDr1nmb-pRaFW7WM8t08Ovg1xyN9jqbzhrRYS7wM9y4AxFwLHATXOaDlynuPHkZcUgY0ibAGwO6JeF_uLZs7dOxy4wcKj_m3rfQvjU6XJDkOfYiD5s24OyPnXqpZlMiQAxzc1wHM3VbEVKYgpPWqY3Ai_QBEcx5qndaGyljSAFyMJYY8KCQYhf5Icq7Vf4hdq6ORlGA=w731-h974-noMO_Ysbf9qqSSN3mh_W5cj--ZVZTDnQEdrg71b3qAL6ClwNPe2BAzRm9ffXwQtLNShfvVSrGZb1awzrTs-3wsiEDqajZLPoN-XH-oo3yrhDvt5S_iPPMs7CTedRr8Y9WVnNO4f4jH3znvJrerLZKaR1GZUm0gc0JunMDdDGBD_5Lga0DDMfHnarSUZq363IDwK97xkihWKBzrJRQAwiFYQw5j1Z9Dnv164W7OSwGE4XGxZ2eHIXysSShGk4IjHd_zD9SavOpyaH66YFmaVk38ecHVh0F1n5WLR9v8cqwuRQWMUZFyBWKd4hFCiprRS1wRgHjT9Iq1NS14jwjcKH2J9ydIEwV-D0wFsaZ5iPU1TVRZbW64atB04SPiQLer1iaCjN8IQuaboBUJBroqU-fMS23BF47Nh-odqGUvevbRwZJlZq-y8SrFnzt4yEWXv_Gd9q3ynKsZF2BcZsbcgSnhLdmijitWj445px4bXxpp9G_r_3lYpT3DMNRp0q12ksFoBKJ-o1_dLONJpkt8z3TBNpHHgJpGpvqu1omhtPLvdPN8GYOocaBcbO6StAmCCNv8PSKanLGhsXMwgLBHVr5axmsFFRB284OaLppLBXg=w731-h974-no
We ended up putting 100nm of pressure in each cyl. It holds the boot fine with a genuine GTR spoiler. If I had to do it again, I would put 150nm in each to see if it holds any better, BUT that 100 works just fine.
Any questions please shoot them through.
Edited by sleptema
  • Like 1
https://www.sau.com.au/forums/topic/474449-r33-gtr-gas-boot-struts/
What's 100nm in real pressure units?  You have given units of torque.  Pressure is measured in Pascals or multiples thereof (like kPa, MPa, etc) or in psi for knuckle dragging 'Muricans.  Or in N/mm2 (equivalent to MPa) or in bullshit units involving the heights of columns of fluid such as water or mercury.
Yeah sorry guys, I was thinking about that this morning and realised how stupid I must sound aha. The guy who did my struts didn't correct me, I believe it would be newtons.
EDIT: Re-uploading pictures of finished product.
Edited by sleptema
  • 4 weeks later...
  • 4 weeks later...
Hi all,
I am also keen to know where I can buy these as I have been looking and found nothing except a few used struts on eBay.
Any help would be appreciated...Every time I need to use my boot at the moment I feel like I have my head in a guillotine!!
On 7/31/2018 at 12:02 PM, Ty1 said:
Where abouts did you get this done? And these are new struts yeah? or did you end up managing to reuse the factory ones?
I used a generic strut specialist. Old ones needed to be thrown out as there was no way they could be re-used. He just used the brackets from the OEM ones and adapted them to fit on the new struts.
I believe he just measured the extents of the struts and ordered accordingly, and put above mentioned pressure into them.
  • Like 1
  • 8 months later...
Hello
my Gas Strut were weak so I want to replace them.
This Topic pointed me in the right direction, thanks !
You can chosse this Model from Mercedes Part No.: 2218800329
It s from the W221 S Class Hood strut.
You can find them for around 14$ on Aliexpress. They are a little bit too strong so I recommend to buy some used ones.
I only replaced one and the Hod stays in any angle.
I recommend to tap an M6 in the Bracket and add a nut to secure the strut.
They are a 14mm  to short, so the Trunk opens 12 cm less. Adding a spacer will fix this
I also replaced the rubber bumper . They are from Aliexpress also.IMG_2323.thumb.JPG.afe41b4eae5716055d1b1a494c668e28.JPGIMG_2326.thumb.JPG.1e7e979e952d3c797bb5eeadcbb3328a.JPGIMG_2328.thumb.JPG.0afff9f21876085c3da8d913c770010d.JPG
Edited by Fastlane
  • Like 1
  • 3 weeks later...
So I did some research, cause the Mercedes Strut were to strong
The original USED Struts have 30 kg while pushing and approx.20-25kg while holding.
The new ones should be around 35kg-40kg
And i Find the perfect one again on Aliexpress
search for:IMG_2392.thumb.JPG.21d8a83675800d67e8a9bd41aebdf543.JPG 320Mm 400N Flap Spring Flap Fitting Gas Spring !
they match perfectly.
The Trunk lid will hold until 15cm before reaching the lock.
  • 2 months later...
  • 3 weeks later...
On 13/08/2019 at 1:21 PM, rych said:
I hate to necro this but when you use a 10mm spaner to wedge the strut out did you had to drill a hole to make new strut fit?
Nah, the strut guy just got a fitting on the new strut that fit over the 10mm ball joint.
  • 1 year later...
On 20/05/2019 at 8:47 PM, Fastlane said:And i Find the perfect one again on Aliexpress
Hopefully this is still correct years later because I’ve just purchased some. Cheers mate
  • 3 months later...
14 hours ago, joshuaho96 said:
I need a replacement for the trunk gas strut
https://www.ebay.com.au/itm/AUTOPA-Gas-Bonnet-Strut-for-Mercedes-W221-C216-S350-S450-S500-S63-A2218800329/254807343124?hash=item3b53b38014:g:5fMAAOSwBYteZbCj&frcectupt=true
here's the link on ebay for the struts, in stock in Sydney.
If you need any strange brackets or ends. Here's the link to a strange brackets or ends seller also local.
https://www.gasstrutaustralia.com.au/
I'm in the US, my concern is that the gas strut is too strong. The Alibaba generic one is said to be more appropriate, so I'm thinking of trying one of those first.
On 23/01/2021 at 3:09 PM, IM-32-FK said:
Don’t get replacement ones, you can get the OEM ones regassed. There’s a couple of places in Sydney that I know who do it.
Only if the seals are good. If they're not, which they probably aren't, they're a throw away. Just retain the top boot lid mounts to adapt to new ones.
  • Like 1
    • Update 3: Hi all It's been a while. Quite a lot of things happened in the meantime, among other things the car is (almost) back together and ready to be started again. Things that I fixed or changed: Full turbo removal, fitting back the OEM turbo oil hardlines. Had to do quite a bit of research and parts shopping to get every last piece that I need and make it work with the GT2860 turbos, but it does work and is not hard to do. Proves that the previous owner(s) just did not want to. While I was there I set the preload for the wastegates to 0,9bar to hopefully make it easier for the tuner to hit the 370hp I need for the legal inspections that will follow later on. Boost can always go up if necessary. Fitted a AN10 line from the catch can to the intake hose to make the catchcan and hopefully the cam covers a slight vacuum to have less restrictive oil returns from the head and not have mud build up as harshly in the lines and catch can. Removed the entire front interior just shy of the dashboard itself to clean up some of the absolutely horrendous wiring, (hopefully) fix the bumpy tacho and put in LED bulbs while I was there. Also put in bulbs where there was none before, like the airbag one. I also used that chance to remove the LED rpm gauge on the steering column, which was also wired in absolute horror show fashion. Moved the 4in1 Prosport gauge from sitting in front of the OEM oil pressure gauge to the center console vents, I used a 3D printed vent piece to hold that gauge there. The HKB steering wheel boss was likely on incorrectly as I sometimes noticed the indicator reset being uneven for left vs. right. In the meantime also installed an airbag delete resistor, as one should. Installed Cube Speed premium short shifter. Feels pretty nice, hope it'll work great too when I actually get to drive. Also put on a fancy Dragon Ball shift knob, cause why not. My buddy was kind enough to weld the rust hole in the back, it was basically rusted through in the lowermost corner of the passenger side trunk area where the wheel arch, trunk panel and rear quarter all meet. Obviously there is still a lot of crustiness in various areas but as long as it's not rusted out I'll just treat and isolate the corrosion and pretend it's not there. Also had to put down a new ground wire for the rear subframe as the original one was BARELY there. Probably a bit controversial depending on who you ask about this... but I ended up just covering the crack in the side of the engine block, the one above the oil feed, with JB Weld. I used a generous amount and roughed up the whole area with a Dremel before, so I hope this will hold the coolant where it should be for the foreseeable future. Did a cam cover gasket job as the half moons were a bit leaky, and there too one could see the people who worked on this car before me were absolute tools. The same half moons were probably used like 3 times without even cleaning the old RTV off. Dremeled out the inside of the flange where the turbine housing mates onto the exhaust manifolds so the diameter matches, as the OEM exhaust manifolds are even narrower than the turbine housings as we all know. Even if this doesn't do much, I had them out anyways, so can't harm. Ideally one would port-match both the turbo and the manifold to the gasket size but I really didn't feel up to disassembling the turbine housings. Wrapped turbo outlet dumps in heat wrap band. Will do the frontpipe again as well as now the oil leak which promted me to tear apart half the engine in the first place is hopefully fixed. Fitted an ATI super damper to get rid of the worn old harmonic balancer. Surely one of the easiest and most worth to do mods. But torquing that ARP bolt to spec was a bitch without being able to lock the flywheel. Did some minor adjustments in the ECU tables to change some things I didn't like, like the launch control that was ALWAYS active. Treated rusty spots and surface corrosion on places I could get to and on many spots under the car, not pretty or ideal but good enough for now. Removed the N1 rear spats and the carbon surrounding for the tailpipe to put them back on with new adhesive as the old one was lifting in many spots, not pretty. Took out the passenger rear lamp housing... what do you know. Amateur work screwed me again here as they were glued in hard and removing it took a lot of force, so I broke one of the housing bolts off. And when removing the adhesive from the chassis the paint came right off too. Thankfully all the damaged area won't be visible later, but whoever did the very limited bodywork on this car needs to have their limbs chopped off piece by piece.   Quite a list if I do say so myself, but a lot of time was spent just discovering new shit that is wrong with the car and finding a solution or parts to fix it. My last problem that I now have the headache of dealing with is that the exhaust studs on the turbo outlets are M10x1.25 threaded, but the previous owner already put on regular M10 nuts so the threads are... weird. I only found this out the hard way. So now I will just try if I can in any way fit the front pipe regardless, if not I'll have to redo the studs with the turbos installed. Lesson learned for the future: Redo ALL studs you put your hands on, especially if they are old and the previous owners were inept maniacs. Thanks for reading if you did, will update when the engine runs again. Hope nothing breaks or leaks and I can do a test drive.
    • No those pads are DBA too  but they have colors too. I look at the and imo the green "street" are the best.
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
