All,
i am running one pipe from rocker cover to catch can and one from can to intake pipe as per standard setup .
there are two breather holes on rocker cover one of which connects to the other on the rocker cover and then connected to intake manifold
i have a 3 port baffled moshimoto catch can so will just block one of the in ports.
my question is , do i gain anything by running two seperate pipes to catch can from rocker cover rather than following the existing standard setup?
2. There is also a pcv valve, can i either block it or run it to the can?
it goes from rocker directly to manifold
finally on rb25 neo, there is also a pipe from manifold to the intake and it is rubber sized around 30mm or so, what is that?
https://www.sau.com.au/forums/topic/476174-block-pcv-after-catch-can-install/
Nah no real gain if your car isn't breathing much, also if your motor is stock then the way you've described is more than enough.
I would leave the PCV connected, however once again if your motor breathes a bit then best to block it off to keep your intake manifold clean.
Some useless information, if you have a big HP setup, with a big build - some builders will have slightly larger ring gaps, this in turn creates a little more blow by of which makes it way up to the head and into the cam covers and out the breathers.
Mine is modified and have a three port baffle
two in and one out
connected the rocker together and one from there to in and one from out to turbo induction pipe
one is left black with no cap end so sucking air in, is that ok?
i don’t know the difference between the port on rocker and pcv
what are their differences?
could i connect the pcv to the other in which is currently left to suck air in?
Are you talking about the BOV plumb back pipe that comes from the blow off valve and goes into the intake pipe? or the IACV pipe that comes from the J pipe and goes into the IACV thats sits on the intake manifold? (can't remember what ID their pipes were).
Here's a pic of my catch can setup:
So what you described is correct. My catch can only has 2 outlets, but if you have 3 you can connect both rocker covers to the two ports without joining them like I did, then 1 outlet to the intake. I don't think it matters what ports you use because the turbo creates suction, so the 1 outlet port will be sucking and the other two rocker cover port blowing (:42_confused:). I've left my PVC pipe alone. I'm pretty sure if you block it, your ECU won't like it. (idk)
The PCV valve operates only under vacuum; Hence the name positive check valve, This "draws" vapor when the engine is under vacuum pressure (idle, light driving etc) into the intake manifold.
Once the vehicle has positive crank case pressure (boost) the PCV "shuts" and the positive crank case pressure then naturally through the rocker cover breathers.
Yes you can block it off. You will also have to block off the inlet manifold side too. This will effect how the car idles and vacuum pressure.
  • Like 1
I have a massive problem
with catch can, it is burning oil and blue smoke
i block it back to intake and put a filter on it but the engine bay is as messy as f**k
it is breathing badly so what you guys doing out there?
i can’t recirculate as it will burn and blue smoke and probably knock so only option is to air but then filter is socking wet?
I would agree with dose pipe.
a decent larger can will mask the symptoms, but if you are dealing with a lot of blowby on your engine it likely is a bit tired, or been hurt.
Just now, drifter17a said:
Thought of this but compression was 165 psi across all 6 and leak test was 10% at max so what part of motor is bad?
The fact there is heaps of blowby shows the rings aren't really doing a good job.
comp test while cranking doesn't really show what's happening when revving and making power, which in your case is heaps of blowby.
fit the biggest catch can you can
Compression rings and oil control rings are 2 separate parts.  Possible to have rooted oil control rings while still having reasonable compression.
And.....165 psi is f**king high, not normal, indicating either, wet cylinder walls or a compression gauge that can't be trusted.
update, pcv removed and redone the fittings and situation is considerably better with minimal oil
i bought a second 2 liter catch can
https://www.ebay.co.uk/itm/Universal-2-Litre-Oil-Catch-Can-Tank-Reservoir-with-Billet-Aluminium-Cap-Black/222719067847?hash=item33db1746c7:g:-lEAAOSwyXNaEqW1
i have a moshimoto 3 port so a waste to through it away so how i am planning to do it is 2 input from rocker to ins on the moshimoto then output from moshimoto to the newely bought 2 liter can and then output from that can to air .
so messiness should be minimised.
has anyone here got two catch cans or see an issue with such setup ?
Edited by drifter17a
    • You can’t see much on the other side as the lcd is there I don’t think it’s the same as the m33 beside it as the markings on top is not the same was hoping someone had a good quality photo or if they just happened to have the unit in hand, quickly take the cover off and take a photo to clearly show the marking on top to identify the diode   the unit is currently with an electronics repair shop so I can’t take another photo at the moment hopefully they are smart enough to know if it’s a zener diode or not
    • I'd be very surprised if you can buy new OEM mats. But if you can, I want some too!  Do you have links to the variations you found? Also, where are you located? I found that Nengun is happy to list items to purchase but when you do buy them you'll get an email that it's actually discontinued. As far as I know the variations in floor mats are different colour schemes as well as automatic and manual having a slightly different shape. The automatic ones fit into a manual car without issues, but I think you'd have trouble fitting the other way around. I have photos that show the shape difference if you care. FWIW I bought sets of used floor mats in decent condition at yahoo auctions.
    • Hi 🙋‍♂️. Just bought my Unicorn but the interior need some minor work so it would match my expectations ;). I noticed it is hard to get used oem floor mats in good condition so i started to dig if there's any chance to buy set of new ones. I found two websites - nengun and amayama and it looks like one can still buy factory new floor mats in Japan, but thers a small issue. Some mats (i assume genuine, oem ones) are marked as G4900 and these are "discontinued". The ones you can buy are marked as G4911 but i have no idea if these are also oem, made by other producer or some lower quality replacements that looks entirely different. Can anyone help? 😃  P.s. there is also some strange indication - 0V005, 0V015 and 0V505. Any idea what does it mean? Would appreciate any help with this 🙏
    • Hi, Marek here 🙋‍♂️. I finally fulfilled my longtime dream - recently bought Stagea and now waiting for it to arrive in Poland. There's only few of these in my country, and one of the owners  recommended mi this forum as a source of all the info i'd need since now i own one  so here i am.
    • Version 1 aluminium airbox is.......not acceptable No pics as I "didn't like the look.....alot" Even after all my "CAD", and measurements, the leg near the fusebox just didn't sit right as it ended up about 10mm long and made the angle of the dangle look wrong, the height was a little short as well, meh, I wasn't that confident that Version 1 was going to be an instant winner I might give Version 2 another go, there's plenty of aluminium at work, but, after having in on and off a few times, and laying in the old OEM airbox without the new pod filter and MAF, there may be an option to modify the OEM air box and still use the Autoexe front cover and filter.... maybe This >  Needs to fit in here, but using the panel, and not the pod, the MAF will need to fit in the airbox though> I'm thinking as the old OEM box and Autoexe cover that is sitting in the shed is just sitting around doing nothing, and they are relatively abundant and cheap to replace if I mess it up and need another, it may well fit with some modifications to how the Autoexe brackets mounts to the rad support, and some dremiling to move it get in there, should give me some more room for activities, as I don't want to move the MAF and affect the tune Sealing the hole it requires to stick it in the air box is simple, a tight fit and some pinch weld will seal it up tight  I am calling this a later problem though
