I support this from the firewall forward.
Actually I lie, there's a guy with a still streetable SS doing pretty respectable times at Winton, so as much as people on SAU bitch about Commos' being unable to handle, it clearly can be done to a pretty decent extent. Realise this is an auto so you won't be doing that... but still.
https://www.carsales.com.au/cars/details/holden-commodore-2005/sse-ad-6431803/
Smaller cams are better choices if you want the thing to be good at what it does best (i.e be a comfy cruiser around town), cam surge will ruin everything.
  • Thanks 1
Just did oil and filter change.
Pulled dipstick and noticed it was a little cracked, so....I wobbled it and it broke.
Dip stick is now about 1.5 inches to short.
Fill with filter is 5 litres, so I just dumped the whole 5 litres of Castrol Edge 0w 40 into its belly.
New dipstick is incoming, thanks to Ebay.
41 minutes ago, mlr said:
Bring on the broken stuff...
I have the full Holden service info pdf set, it is massive. When iam able to operate a computer correctly I will pm a Dropbox link to you. Few beers in so could get bad athe moment
  • Thanks 1
Just ordered new Ultima struts and FE2 height king springs $600 delivered (I pulled a wheel and the shocks looked like the originals from 2002, the FE2 springs will give me an additional 10-15mm height, helpful when doing Dukes of Hazards jumps), and some $20 spring compressors (again, I cannot find my old set, meh, $20, ppfftt) off Ebay to swap out the strut tops.
But tomorrow is coolant flush then full external clean, wash under the car as well as the paint, then polish, glaze then wax.
I'll also give some of the fixtures a squirt with penetrant in preparation for undoing suspension nuts and bolts, hopefully next weekend.
Psycotherapy and a bit of a work out.
… could I also get this? The VZ one is a fkin DVD and near impossible to find. I have the VY Series 1 one, but they... change stuff.
Mark if you want to be a real bogan now that you have a Commo you will have to install the mandatory bow tie badges.
My daughter who is not a car enthusiast always says "bow tie badges on a Commo would make baby Jesus cry" whenever she sees a Commo with them.
Go on you know that you want to.
LOL, Chevy badges on Holdens causes the AIDS.
In other news
Coolant flushed
Car is all clean and shiny
Decided to do the spark plugs.....but.....the first lead I pulled fell to bits
$130 later I now have
For
Jobs for tomorrow
Plugs and...leads
Trouble shoot inactive cruise control. i.e. "look at the fuse"
Pull door trim and see why the front inside passenger door handle doesn't work, well I know why it doesn't work, the handle is good but it seems to be missing a spring or something????, I'll most likely pull the trim off the drivers front as well to see what it is meant to look like.
Plugs and leads are done.
Also replaced the OEM heat shielding (masonite with tinfoil glued on) with real heat sheilding, held in position by 2 x OEM clips and 1 x cable tie (LOL, cable ties already)
Door was a cheap fix, just needed to reconnect the clip.
Getting to the clip on the other hand was a PITA, lots of jamming the phone inside and taking pics, then jamming my hand in and blindly fumbling around until the blue clip was reattached to the rod.
I want more sidewall.
I going "full bogan spec"
17 x 9 chasers with black caps.
I'll get some Hankook RS-4 255/40 17, should give me 20mm more sidewall.
Slight diameter change, 24.8 diameter, as opposed to the OEM 235/45 17 which are 25.1.
Should be 100kph on speedo and 99 on, ummm, the radar gun.
Will sell the 19" Simmons once the car is "full bogan spec".
  • Like 1
  • Haha 1
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
