Bullet got back to me with a HTV1900 kit available, 4-6 weeks wait though
Torque would be slightly over my threshold, but, at least it is more manageable than the HTV2300
I will have a chat to a shop tomorrow, Autotech Engineering, and see what they say
I've spoken to a few other local joints, AE seem to understand I'm not after big numbers so if I do go for gold I will most likely use them, and both Bullet and Harrop recommend them
Currently the price for drive in drive out is a hares dick under $15k
Lots of money to piss away on whooshy noises
LOL
And I'm currently trying to teach the kids to be responsible with their money
I'm an excellent role model......of what not to do
stop pussy footing around and go full bogan
https://www.aussiespeedshop.com/product/ls-1-gm-6v71-supercharger-kit-cathedral-port/
or maybe get into a job that lets you enjoy the noises. This was fun to rip around in at summernats a few years ago now.
LOL
You know you can buy a crate built motor that makes 350kw for less than that, yeah? And it's N/A?
Yeah, but then there's the install, and all the other stuff
Plus for 350kw it needs a fairly big cam, which screws drivablity and fuel economy, this would also require a larger stall, and stuff
At one stage I was looking at a crate LSA with a gearbox for $24k, then I would need to get it in and running > https://www.holmart.com.au/holden-hsv-vf-gts-lsa-430kw-6.2l-crate-engine-6l90
I decided this was the easiest option to get some semi reliable power whilst retaining drivablity and some economy, plus sweet whossy noises
I'm sure that someone with garage space and more mechanical aptitude could have done it for less, but meh, I just pay cash
Easier to just put a motor in?
https://www.pavtek.com.au/index.php/ls1-gen-iii-packages-mainmenu-21/235-ls1-383-efi-long-engine-with-cnc-heads-562-hp
383 means less cam, but you have an auto anyway. Why not 6.3L? No intake problems. Save yourself a few thousand too.
Not the only places that will build up a motor too. Quite a few joints around that will just supply you with a built ready to go LS1 with heads/cam/stroker that you can throw in and away you go.
Def cheaper than doing it incrementally with cam, then heads, then intake, or boost etc.
Boost is always going to be less reliable. And you have things like joiners, belt, IAT problems, fitment issues and casual illegal extra items in the engine bay.
I've pretty much sworn off ever going boost for those reasons. That said... pretty different application!
My very stylish and excellent quality under bonnet noise mat thong turned up
Fitted straight over the car builder foam stuff
My only concern now is will the blower fit, or will this stuff need no be recessed?
Before
20201221_124903.thumb.jpg.e42ddf9a3c8516f17835e5a4c77a5a99.jpg.987b3f87a9d2b078e903dda644d782a6.jpg
After
24 minutes ago, Kinkstaah said:
That is very nice indeed. I hope it doesn't need to be removed. That would be sucky.
I'm hoping it doesn't, we will see in a couple of weeks when the blower goes on
If it does I'll trim it nice and maybe cover the cut edges with pinch weld or something
I've seen a few Harrops that fit with the OEM liner stuff, I've also seen a few where the liner has been hitting the front edge of the blower
I've got my fingers crossed
Removed the OTR intake and replaced it with a "slightly modified" OEM airbox, and a new plastic radiator cover, used some 3.5" x 100mm stainless pipe to fill in for the MAF
I didn't like how the OTR blocked half of my radiator and sat hard up against the aircon condenser
Another "Because I had issues"
Do you have a means of logging your IAT after doing that? Heatsoak on the sensor is a big problem with OTR's, yet they also add power.
In my application it wasn't really an option and I had to buy a faster reacting IAT sensor from the USA as the GM one takes minutes to cool down to the air temp it's actually sensing.
LOL, yeah, I get bored and look for things to do
The sensor is back in it's OEM position, which is in a much better spot than where the OTR had it
I'm not really fussed on any additional power the OTR gives, I've opened up the bottom section of the OEM radiator and it has clean air from behind the grill
I was watching a LS getting tuned with a OEM airbox with typical "mods" to mine and a HTV2300, IIRC it was over 400kw, and at around 12psi, it won't be best practice, but it will be fine, I've gone for a larger pulley, so even less boost
If the car makes around 350kw with a fat tune I'll be happy
2 hours ago, Ben C34 said:
Get them to fit a throttle stop at the same time as the blower goes on.
I'm hoping my right foot has some common sense
Plus I believe I'll be making stuff breaking torque well before I get anywhere near full throttle
The tuner, Spiro, knows I want some form of reliability tuned into it, so, with a big, low psi pulley, and some crafty tuning, both with the fuel and the transmission, I'm just going to fill the transmission with some hopes and dreams and see what happens
  • Like 1
The thing is, the air temp sensor gets hot in traffic. Upwards of 70C. It took a good 15-20 minutes of highway cruising (!) to get it back down to about 35C. This is on a 25C day.
The stock ECU absolutely will pull fuel, timing, and knock. The air actually entering the engine is not 70C. Map sensored cars really soak bad, at least they think they are soaking bad.
v8 cars are way easier to manage traction that turbo cars. You won't need a throttle stop. I need way less traction control intervention with the v8 than I ever did in any of the turbo setups.
I'll look into the OEM AIT sensor more
As for air temps post the blower, I "assume" I will not be taxing the 2300 running low boost, I "assume",  hence, my actual intake temp should be well within an acceptable range, people run alot more boost on these than I will be, and the internal air to water coolers "seem" to keep up
The standard 85mm pulley runs around 10-12 psi, a smaller, optional 80mm pulley runs around 13-15 psi, and the smallest available, a 75mm pulley, runs around 16-18 psi, I'm going to have on hand the biggest pulley available, 90mm, in case it is required, to drop another 3 psi, going off rule of thumb.....all things being equal it is about a 3 psi variance for ever 5mm
Warranty gets voided when the pulleys are under 75mm, or over 18,000 rpm, I won't be running anywhere near that
Running the big pulley also extends belt life, "apparently"
I will keep a spare belt anyway, and 17mm??? spanner in the glovebox in case of a busted belt
But honestly, this is the tuners bread and butter, this guy has fitted a heap of these kits, I'm sure he will use all of his black magic tuning skills to sort me out
I have no idea IRT of the dark art of tuning
Disclaimer: Yes, I am using alot of assumptions and a few apparently(s)
My saving grace, and peice of mind, is people are pushing these things "alot" more than I will be
Mate, in the end I will cross my fingers, roll the dice, and hope for the best
Time will tell
This will also tick off owning a supercharged car off my bucket list
  • Like 2
New front wheel bearing hubs are on the way
Another case of doing stuff for the sake of wanting to do stuff, not because I need to
Meh, they are most likely the original 18 year old bearings
I shall rationalise it as preventative maintenance
The old window tint was a bit worse for wear and I was umming and arring about replacing it, or at least, removing it
After ringing around to see how much it would cost for a tint joint to remove it........I went onto ebay and got overnight parts from....China
With the $100 steamer it took about 1.5hrs from the start to the finish
No glue, no residue, after pealing it of all it needed was some windex
100x easier and cleaner than using a heat gun
  • Like 2
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
