So I got the head unit all installed this weekend:
Wireless CarPlay is the goods! I just need to wire up the reversing camera and the reverse input. I tidied
All weekend I have tried calibrating both the fuel level sender (in the IC7) and the vehicle speed (through the ECU), with no luck. The vehicle speed issue means I can’t test out the cruise control…
  • Like 4
13 minutes ago, Looney_Head said:
heads up for the cert, when i did mine, i had to have two loops due to how and where the center hanger was.
great work on the car, looking and sounding good. and solid power :)
Thanks!
Funny that. My cert guy was the one who said I needed 1… let’s see what happens.
  • Like 1
If he said you only need 1, you should be OK. But officially it's 2 on a 2 piece driveshaft.
There was some talk they were going to relax the rule a bit. Maybe it's starting to happen.
I certed my 30 conversion before the hoop rules came in, but want to do brakes which will trigger a re-cert. I'm hoping to squeak through
  • Like 1
Try this setting, the out of the box Haltech value is much higher and reads weird
Also if you're running the latest version of the firmware, there's a known bug with VSS doing a few thousand km/h lol
Yes, I did have the latest firmware, so I think that’s the issue! Also, no more haltech forum?? I joined that FB page too..
the fuel sensor issue on the IC7 also seems to be firmware related. For some reason the software isn’t updating it with the latest firmware…
27 minutes ago, soviet_merlin said:
What the heck? Did they completely axe the forums and all content? Intentionally? This blows my mind. If it was intentional it seems so incredibly misguided I can't even comprehend it.
It appears so!! I solved a lot of problems just searching on there..
On 23/5/2023 at 12:05 PM, Dose Pipe Sutututu said:
Hopefully easy fix!
And yeah, a bit sad they removed the forum. Facebook is a bit shit, same questions get asked every week.
Fixed the speedo issue. Funnily enough, my settings were around 5221 pulses/km and I think that was calibrated at 30km/hr. Verified the speed with a shitty app that lagged heaps, so probably wrong still haha but at least I’m not doing Mach 2 anymore.
played with the idle a bit, as the tuner had it set at 900. The DBW makes this super easy and super stable! I backed it down to about 750/800rpm and it’s rock solid!
just need to figure out the fuel gauge next!
  • Like 2
As part of my cert tomorrow, I had to update the HICAS lock bar, as there is some picky rules re. bars with welds. This is why I bought the PRP bar, it’s billet with no welds..
The bar itself is great but I feel there has been little thought on the actual application. I had to cut 10mm off the thread on the arms to get the toe adjustment anywhere near right. They say they are bringing out new arms for it but who knows Wel hen that’s happening.. I should have gone with a gktech full delete kit.
  • Like 1
53 minutes ago, WR33KD said:
You should have just run a non hicas r200 frame and arms and knuckles to suit, way less stress and it’s a way cleaner look under the back
Yeah, I will investigate this.
also, I will be getting a flex fuel sensor, so I will be getting me some of that ethanol you linked! Cheers!
  • Like 2
So the car failed the cert, however on really minor stuff:
  • Exhaust is 1.9 decibels too loud (was 91.9db at 3200rpm and needs to be 90)- im just going to put a restriction in the exhaust to get a pass. i may quit down the exhaust long term, just want to get a good feel for it first..
  • I need to put a cover over the fuel top hat (factory one doesn't fit because of FPG top hat). ill just have to modify the factory one to suit.
  • no airbag diagnostic light on the dash (as i now have the IC-7). i wish the IC-7 had more customisation here with different logos etc. but nope. I have ordered a little airbag logo light that i will install on the dash.
I should have this remedied next week and finally be legally back on the road.
Edited by R3N3
  • Like 2
  • 1 month later...
22 minutes ago, Dose Pipe Sutututu said:
Congrats!
How does it feel on the street?
Really good! The turbo whistle is much louder than I thought it would be. It’s so much rougher than I remember lol. Spending too much time driving the smooth Skoda with heated steering wheel and seats, 360deg camera etc..
I just need to do a road tune to get it 100% perfect
  • Like 1
20 minutes ago, Dose Pipe Sutututu said:
I totally get this, with the MK2 Tiguan.
Get into the R33 and it feels like a croc of shit.
Best thing is the wireless CarPlay head unit! I just need to get an amp and speakers.
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
