I've got 2 sets of wheels, both my track and street rears came up for replacement at the same time. I popped 120 treadwear NS2R on the track set and have been using them on the street.
So now I'm in an awkward spot, I really like them on the street, even in the wet but that rate at which they are wearing, I'll probably only get about 7500km of street use out of them.
So now I'm torn, do I just accept that wear rate or should I pop something like some RS4's on the street set, or maybe try the 180 treadwear version of the NS2R....
What wear rate are you happy to accept for street tyres?
I'm running Federal 595s on my street wheels ATM but that said I work from home and don't usually do more that 750ks per month so they last long enough from a time basis for me. I love them and also good in the wet. I used to run rs4s but couldn't get them in my new size and felt the same about them, even though they saw the track a few times they seemed to hold up quite well but I got rid of them before they died so I don't know how many ks they would have done.
How much street driving? Daily driver or weekender with odd week day?
My daily I'm happy with 15000km with odd fun day at a motorkhana/sprint. Currently on Michelin ps4s
Thought about going to nankang crs for track tyres?
It's a weekender + track stuff. It varies, but I'd say I do about 10,000KM a year.
I'm priced out of CRS completely. I got a quote for CRS when I was picking up the NS2R...
CRS in size 275/35/17.... $435
Can't get NS2R in that same size, but I paid $265 for 255/40/17
Here is a good apple / apple comparison.
https://sleekaspares.com.au/product/255-40r17-nankang-ns2r-semi-slick-tyre-120-180tw/
https://sleekaspares.com.au/product/25540r17-nankang-cr-s-competition-semi-slick-200tw/
I don't know how long the CRS would last on the street, even though they are "200 tw" they are a faster tyre then the NS2R, so I would expect they would have an even shorter life expectancy.
15,000km sounds pretty good to me. The more I think about it, the more I think that's where I'd want to be for my street tyres. I think it's bothering me that the tyres won't even last the year.
With a low use, high power car like my Stagea  I go the grippiest tyre without the noise and tramlining of a semi slick. The tyre might only last 15,000klm, but you don't really notice if it takes 5 years to get there. Plus, there's no point driving round on crappy tyres and spinning wheels every time you hit boost.
It is very hard to work out what a good high performance street tyre is though....every brand is happy to sell a super expensive "ultra performance" tyre, but where would you find an unbiased comparison of them?
  • Like 2
My next set of tyres on the gtr will probably be a set of ad09, I’ve currently got a set of ad08r on there and are being replaced because they’ve gotten to old not because they wore out
That's an odd size tyre and why expensive, better off going 255 IN 17s or step up to 265 in 18s.
Your in Brisbane area? Try keith4wheels at underwood. Pricing should be better on nankangs through him.
Another budget option IF you can find them is the nexen sur4g. Found them better than the ns2r on cars I've driven.
Found running square setups helps as I would rotate tyres more frequently to get the most out of them.
CRS is about 50% more expensive then NS2R in identical sizes, check out the links I put up.
Yeah I've been looking for sur4g for a while now, can never find any place that has them in stock. Also been looking for Valino and Zeknova tyres, again no one has stock for what I want.
I would run a square setup if I could get the same size to fit the front. Can't see that ever happening without cutting up the front guards and fitting flares, but I'm really not keen to do that.
Yep. I'll check out that tyre shop, see how we go with pricing.
I just got 17,500 kms from my RS4's. Was thinking about changing to NS2R's because RS4's seem out of stock... everywhere. This is through a few track days and running them at 36psi on the road when they are on road use.
Seem to still be the bang for buck performance champion. I was also interested in the NS2R/AR1/CRS options. Porsche guys have a lot of feedback on the CRS and compare it closer to a Pilot Sport Cup 2/2R and rate it on that level/better than that level and it seems to last longer. Some are faster on them than they are on AR1's, others give up a few tenths but the CRS is a much more streetable tyre than the AR1.
So realistically, the CRS is the next level step up/level up from Nankang, with a price to match - But still much cheaper than the same size in a Pilot Sport Cup 2/2R.
  • Like 1
I find it hilarious that Nankang CR-S or CR-1 are more expensive than AR-1.
I was planning on running them until I saw the prices and ended up with Hankook RS-4
So far, I must say I'm impressed with the Hankook RS-4 though, in 2nd I can put down all 438kW on the street! They performed well enough at Eastern Creek's GP Circuit too. Would be nice if Wakefield was open, could really push these tyres and compare them to the Nankang AR-1 tyres I had previously on the car.
Back on topic, 7500km to 10000km per set of tyres is a respectable number for life with a mix of track/street. When I ran Nitto NT01s all round (Taleb Tyres parallel import special) they would last about 5000km or less per set.
I think I'm going to need a detailed breakdown of your suspension components, setup and alignment lol.
I can't even put down 300kw on the street in 2nd. Say I'm cruising around 1500 rpm, then floor it in 2nd, around 5500ish rpm it will break loose.
I wonder how much of that comes down to the shape of the power delivery from the journal bearing turbo. Maybe if I went with the ball bearing centre, it would have had a more gentle power delivery.... I dunno.
I don't think it's anything fancy or special to be honest but here goes
  • subframe shifted up 10mm using the GKTech subframe kit
  • subframe all welded up/braced
  • Gktech diff bushes (front/rear)
  • HICAS Eliminator kit (i.e. delete the Nissan tie rod ball joint junk on the toe rods)
  • Camber arms, at -1.5 degrees
  • Traction rods at 15mm longer than OEM
  • White ARB on the softest setting
  • 2mm total toe in
  • 7kg/mm rear springs on MCA X-R dampers
  • KAAZ 2 way LSD
  • 265/35/18 Hankook RS-4
  • Over height isn't too low, there's about a 18~20mm gap between tyre and wheel arch (not a good measurement as my guards have been cut/welded)
  • Control arms are pointed ever so slightly downwards
I suspect my power delivery also attributes to traction, the car somewhat produces a linear ish ish power curve not like your typical exponential growth power curve lol. I get 1bar of boost by about 4200, 1.8bar by 4500rpm and it revs all the way out to 8600rpm. VCT enabled, big silly cams (no stock of the smaller ones at the time).
  • Like 1
Actually, I was going to suggest Dose might want to try it with 0 toe, I've preferred that in both rwd and 4wd R chassis.
With rear toe in you gain stability under power but lose "responsiveness" from the rear in slower speed turns. You do need to be comfortable with the way it responds....
Also you will get more tyre wear and theoretically less power to the ground as the tyres are not pointing forward.
  • Like 1
Do you have everything solid mounted/rose joined in the rear?
My zero toe might be a lot more toe out, then your zero toe. I've still got a lot of rubber bushes to delete in the rear.
Nah, it's all poly in the back of the race car, rose joints not allowed.
Also keep in mind that toe is static. Depending on how/if bump steer is set that becomes toe out under power with standard or standardish length upper front link.
I might try that next, I am just cautious as the rear end still squats quite a bit on noise, which naturally would toe the rear wheels out.
I spoke to my aligner and he said to still run a little bit of toe-in to keep the car stable on power, however I agree to your point it would make the car clock not as well.
50 minutes ago, Murray_Calavera said:
Hmm I think I really need to start running some amount of toe in.
I run zero toe in the rear, because exciting, but it really doesn't help for performance lol.
I used to run 4mm total toe in LOL...
this was actually also recommended by 2x different alignment shops (BT Motorsports in Smithfield and also Porters Suspension In Kirawee)
    • sold listed as a Tomei LSD 1.5 Way For 1998+ Nissan Skyline ER34 25GT RB25DE w/Open R200 https://www.ebay.com/itm/174006114594?campid=5338967980&mkevt=1&mkcid=1&toolid=10050&customid=&mkrid=711-53200-19255-0&loc_physical_ms=108689&loc_interest_ms=&campid=5338967980&mkevt=1&mkcid=1&toolid=10050&customid=71883f2ccc571356e0a757bc7adfdde2&mkrid=710-53481-19255-0&loc_physical_ms=108689&loc_interest_ms= it went in like butter all gears, alignment, back lash etc, rotation and clearances correct, and if rolling all rotates smooth and free when coasting down road , clutch in or out over 10 mph smooth... its the binding, clunking and jerking from a stop that is most concerning, also seems like its going to tear the tires off in 10 miles of normal road driving.
    • What 1.5 way? There's no such thing really as a 1.5 way, just different ways of explaining 2 ways with different ramp rates. HOWEVER. In any driving in a straight line your 1.5 or 2 or 1.7 way should have no clunking at all. With the clutch fully depressed the diff should be silent (unless it's welded but I'm assuming it's not). Something aint right here.
    • Clutch is a spec brand, new clutch system,( PP, flywheel, friction disc, etc. pull type) installed 100 miles ago, with no problems.
    • looking for some help and maybe some insight on others experience with a new LSD. R34 GT ran and drove beautifully, but always alot of grip loss due to the open R200 rear end, so I just installed a new 1.5 LSD way into the stock open R200 for a ER34. Simple. Everything seemed right. I test drove for the first time this weekend. as I started to back out the garage the first time slowly with tires straight it sounded and felt like I had a loose or half disconnected drive shaft...that was clucking around loose and shaking entire vehicle, and making it feel like the trans clutch was spontaneously slipping then grabbing very roughly while just letting out pedal slowly. I backed it out went to pull forward with the same noise, shake and slip grab feeling with hesitation, I turned the tires to back out more and then pulled ahead some same thing but worst because of added wheel resistance (which that I expected) puzzled … pulling it back in checking everything over and finding nothing wrong, I tried it the next day. same thing, couldn’t believe how it shook everything again making a terrible noise and making it feel like the trans clutch was slipping and grabbing, but I got it out of garage into the driveway, got it straight, drove forward and then reveres a few times in a straight line everything shaking , causing what felt like clutch slip and grab every time, sounded like right behind front driver tire and I could feel it in the floor board with my feet,... worst right when beginning to let clutch pedal out to engage slightly, shuttering and sounding terrible along the way…I managed to slowly get down the road, babying it the whole way, once I was rolling (out of 1st) seemed to be better and between shifts, then clutch felt closer to normal…not slip/ grab etc., but back down to any stop, straight road or turning, same thing. Made no difference if all tires were straight or if I was turning. All other gauge read out correct. with in 2 miles as planned I reached the empty parking lot and performed the break in procedure that came with lsd, essentially to drive in a figure 8 a bunch.  Did this, binding chattering, and shaking the car the whole way. I drove it back home seemed somewhat normal once I was in straight line and past 10 mph or so, and I know it will “bind” on corners and cause some tires squeal when turning especially from a stop, but when I begin to move it still causes what feels like the trans clutch to slip and jerk badly as well as shaking the entire car, and sounds terrible, that I didn’t expect. I used the fluid they supplied with LSD kit and did the breaking, planning to change fluid as they suggest after breaking, but wondering will it get smoother or less aggressive with use? maybe a 1.5 is just too aggressive for normal road driving?   I have a LSD that I put in my 71 cuda when I restored it, with amazing smooth , quite yet effective results. Different style LSD but that ones a joy to drive. maybe expecting too much from this R200?
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
