Hi!
I’m looking to replace my current turbo on my S1 RB25DET in order to make 600HP but maintain responsiveness. I’m looking at the HyperGear ATR43SS-3 in T3 .63 A/R or the Pulsar PSR3576 Gen2 T3 .82 A/R. I’m still learning how turbo sizes effect lag, response, and power band. I’m looking to see if anyone can share their experience with either of these turbos or can recommend another to meet my goal?
These are my mods:
• Running 91 octane most of the time and occasionally E85 on track days
• top mount twin scroll manifold
• 44mm external wastage
• 1300CC fuel injectors
• mishimoto intercooler M-line
• 3in intercooler pipes
• g-reddy intake manifold
• link g4+
• NZWiring trigger kit
• GTR R35 coilpacks
•  built bottom and top
• 4” down-pipe and exhaust
Edited by Eric0
Added type of engine
https://www.sau.com.au/forums/topic/485873-hypergear-vs-pulsar-turbo-rb25det/
30 minutes ago, Duncan said:
Hey Eric, it will help to put your location in your profile. 91 Octane is the lowest quality fuel available in Australia so I'm thinking maybe you mean US 91 not Australian
Hi! That is correct. 91 Octane US. probably similar to P98 AUS.
I’ll update my location
  • Like 1
93US is 98RON. 91 is a little on the low side to try to push to 600HP, but at least you can control boost to something more conservative when you're not on the good stuff.
Also, we should check. Is that 600HP at the flywheel? Or using the usual pony power yielded by US roller dynos?
 Gotcha! Thank you for the correction.
The goal would be 600 bald eagle (screech) pony power yielded on a roller dyno, but I’m more interested in responsiveness at low RPM and full-boost before 4000RPM.
well....I'm no turbo selection expert so I'll leave that to others, looks like you've got what you need from a supporting mods side though including the twin scroll manifold; that means you really want a twin scroll turbo to not waste the advantage, it will make the same boost/power a couple of hundred rpm sooner than a single scroll turbo
Awesome! Thank you for the confirmation. We’ll see if anyone has experience with HyperGear, Pulsar, or other turbo brands with good response and overall power.
After more research, I’m leaning towards the HyperGear ATR43SS3 ProR with .63 turbine. This a dyno graph from an RB25DET Neo with following mods:
• 1650cc injectors
• adaptronic plug-in ECU
• 600x300x81mm Intercooler
• 3in exhaust
• 4in downpipe
• R35 GTR Coilpacks
• twin scroll manifold
• twin 50mm wastegate
What do you think?
Honestly:
Buy a name brand turbo. Garrett or Borg Warner. Anything else you will be chasing "but why doesn't mine end up like the dyno graphs the sellers post?"
Buying a brand name turbo gets your result right where other people with the same turbo experience.
Also, 600whp in any country - expect your engine to become a consumable. If you're okay with that and can plan for that then all the power to you. Also consider your clutch will suck and your grip will be less than stellar.
Aim at 450whp. You'll have a better car and more fun actually using it, and it'll probably be faster for every scenario with the one exception being drag launching it on drag radials at a drag strip where you might be a tenth faster.
Sincerely,
Wiser, cooler heads.
2 hours ago, Kinkstaah said:
Honestly:
Sincerely,
https://www.youtube.com/watch?v=5Y3mHN8HbG
This is about 450 whp and it's keeping up with a modern GT3 RS. Obviously some caveats to that but I think our brains are all broken by modern car power numbers. It's really everything around the engine that needs to be up to scratch. This particular R32 last time had some random BBK on it and clearly it wasn't good enough because he switched it to AP Racing for this go around. I'm reliably surprised by how much the little things matter when you're modifying cars. Every last detail is critical.
Yep, like how people insist VCT does nothing, delete them OR say how twin scroll is a waste of time.
2 hours ago, GTSBoy said:
That video is gooooone.
Oops, guess I accidentally deleted the last digit of the video ID.
This one drives me nuts. VCT is such a big advantage for basic driveability and it costs very little to do. It's not like we're dealing with an E60 M5 with its dedicated high pressure VVT oil pump + hydraulic line carrying 1000+ psi and all that fun stuff.
I also see a lot of people speak poorly about EGR and try to delete it in modern GDI engines. The problem is modern GDI relies on cooled high pressure EGR to improve timing margin at high load + RPM. So unless you're compensating for it by raising octane you have to completely retune when it's deleted.
Edited by joshuaho96
  • Haha 1
5 hours ago, Kinkstaah said:
Honestly:
Sincerely,
This was amazing and something I feel like a lot of younger enthusiasts, like myself, need to hear. I've been observing a local dyno shop spitting out 650-800HP RBs but when looking at their graphs, the car is basically dead until 5-6k RPM when it skyrockets.
I’ve decided to change my goal and go for that 450whp mark and aim for quick spool, responsiveness, and practicality (I can't afford my engine being a consumable, haha).
Now, looking for the best suitable turbo for this application, I'm considering:
• Garett GTX3076R Gen 2 ( .62 or .82)
• Garrett GTX3576R Gen 2  ( .62 or .82), room for improvement later?
• HyperGear ATR43SS2 ( .62 or .82)
• Pulsar PSR3076  ( .62 or .82)
• Pulsar PSR3576 ( .62 or .82), room for improvement later?
Any recommendations? I know the HyperGear and Pulsar aren’t name brands but they’re sure budget friendly
If you had to pick between Pulsar and Hypergear I would probably go Hypergear.
  • Like 1
G25/30 Series. Nobody seems to run a BW EFR anymore, and not at a 320kw power level on 95 gas. I did back in the day on a RB28, I don't think anyone ever ran a 7163 on a RB25. That said, a G series is going to be much easier to fit being physically smaller which is more helpful than you might think.
The turbo is the only thing that really adds power to the car. It is the most important of all selections. Do not skimp on it. If it's a budget issue, save longer. The difference between a G series and these other options will be like 5% when all is said and done. What's an extra $1000 now when you look at it through the lens of all the $ already spent to support..... the turbo to do its job well.  I see it in LS worlds too, where they spend $50,000 on the motor to run 2x $300 ebay china turbos on the f**kin thing.
With engine consumables, well - they all are. Just less with less power. It's either already rebuilt...
.....or it's a 25 year old engine you are wanting to boost to (at least) 200% of stock power.
It would be very wise to consider what the plan is, and be ready for it, when something does go south. Don't be that guy with a just completed-now-broken-car because you didn't budget for things to go wrong, which is how a low of projects end up sadly.
None of the above. G30 660. Call it done. Or, BW EFR, or one of the other similar modern options.
In the BWs we're talking EFR 7670 with the twinscroll turbine housing. Sorta good for 650HP at the flywheel, which should be more than enough. Broadly speaking it's equivalent to the G30 660.
None of this is cheap like the OP's original options, though.
The PSR3576 is also a bit larger than the new power target would suggest using.
The ATR43SS3 was always a smaller choice than the PSR. 600 fly vs 750 fly. So they weren't ever comparable options. I would think the ATR43SS2 or 3 would do what is (now) wanted, especially if E85 is the path to making the target. Tao's own recco is for an SS2 on E85 for 340rwkW, which is almost exactly on target. The SS3 would have more headroom, but it really demands a 4" inlet. I would probably try Tao's reccomended turbo at <1/3 the price of the name brand stuff I suggested above.
Hi Eric i have been us the same turbo only internally gated Wolf 550 ecu with 660cc injectors kelford cams running on Australian 98 ron unleaded fuel with forged bottom end and Lewis ported and flowed stage 3 head at 473hp at wheels with 15 pounds boost for the past 9+ years and i have next zero lag and always fun to drive. I cant see any reason for you not getting the output numbers your wanting.
I’m starting to lean towards the Garrett G30-660 but wondering what exhaust housing I should select for the 450-550 power range with quick spool.
Any thoughts on this?
Edited by Eric0
Updated power goal
Okay!
I bought a Garrett G30-660 supercore!
I’m thinking of parring the G30-660 with a T3 .82 twinscroll. What do you think?
Any advantages in spooling if I stepped down to .62? Seems like it would restrict the engine to about 400hp
  • Like 1
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to it's full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so damn hot in there, that made it all the more easy to remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. I was standing there looking at the car and said 'f**k it'. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
    • Also playing with fire if they start to flow more air down low than what the stock twins can. It's not even up top you need to worry, it can be at 3000rpm and part throttle and it's getting way more flow than it should.
    • Any G40/1000 or G40/1250 results out there?
    • You still want a proper tune on the stock ECU though. Stock tune + stock ECU with GT-SS/-9s is probably playing with fire if you're running more than stock airflow/power.
