Stagea Parts List
Lone
Breake Light Switch
Repco Part Number: CSL43
About $15
S1 4WD Turbo Auto
Antony
Repco Part is shit Don't bother with it... I fitted 2 and thay both lasted a few days only.
Nissan Genuine Part 25320-75AOE (about $25)
Antony
Edited by ant0ny
  • 3 months later...
Hey there,
I was wondering if anybody had compiled a list of standard service parts for the M35 that were obtainable in Aus? Or is it a case of buying from either NZ or Japan?
Thanks very much,
Brendan
  • 2 months later...
Hey there,
Thanks very much,
Brendan
Would be useful, but;
1) How much time do you have?
2) Isn't that what FAST is for? - if you don't have it, just give a Nissan service guy your VIN & he can look the part number up.
and then there are still conflicts, such as spark plugs
Edited by iamhe77
  • 4 weeks later...
Has anyone had to replace a sunroof rubber on an M35?
I've been giving the windows a workout over the past week and a bit and the rear rubber appears to have broken slightly :D
Anyone have a code/price on this one?
Hopefully it can be replaced with a cheap after market job, not sure how universal that size of sunroof is tho.
Any assistance would be greatly appreciated.
  • 4 weeks later...
WGNC34 Stagea Series 2 R34 Engine
Idle Control Valve Gasket (AAC Valve Gasket).
FAST Nissan part no. 23785-AA000
FAST Alternative Nissan part no. 23785-AA001 (This is what part the dealership supplied me with). Cost Under $9
Also fits R34 Turbo engine in Skyline.
Does not fit earlier R33 engine according to FAST.
  • 1 month later...
May be supplied but here i go shift solenoids for an s2 . There are 2 shift solenoids this is the problem . Please do yourself a favor do the self diagnosis on your car . But the part numbers for shift soleniod A & B are . A = 31940-4ax02 . B = 31940-4ax05 . Be sure which one you need A=$350 incl trade B=$415 incl trade . So ther goes my ruddy check .
Can anyone give me definate part numbers for front and rear brake pads for M35 Stagea ARX.
2003 build in Bendix Or RDA
RDA Listings;
Front Pad: RDB 1232 Listed as Maxima Front
Rear Pad; RDB 1509 Listed as X-Trail Rear
Price; $35.00 Per Set from Specialised Brake & Clutch in Penrith.
Hope this helps, Dale
anyone done the cabin air filter on M35 Stagea. Went in to repco here, no listings, que too long at nissan dealership. Took some rough measurements was about 195mmx215mmx30mm. Would like to think it would be same size or part as one of the other more commen models???? forgot to ask them for one to measure up against DOH!
Also what is the standard battery fitment for M35 stagea??? Dealer put new one in when purchased 1 month ago (holler for a marshall), looks bit small and sounds slow to crank engine over. Had to get a jump start other day after a 60km non stop trip, no lights on etc. Have since charged it up and recovered, seems ok but that battery looks way to small (will put size up later). Seems plenty of room in box to put something bigger in. Thanks
Edited by Shopping Trolley
I always think standard batteries are too small. I generally get the biggest one I can fit in, even if it means changing the tray, terminals and the fitting for holding it down ( get universal ones from any auto parts place).
M35 air con filter is HERE
Standard battery is a small one.
I had mine replaced nearly 2 years ago with the same size one from RACV.
Been working perfectly since.
Edited by iamhe77
mines the original factory one from japan, hasnt missed a beat since i got the car
I would probably still have mine as well, if not for flicking the "fog" lights on one arvo and ignoring the beeeeeeepppppp (I was in one hell of a hurry).
Got back to the car in the morning with a dead battery.
....Idiot :)
/smacks you in head lol
it happens mate. i had a turbo timer in my S15 (bought it like that, personally i think they are useless) and used to drive with my lights on a lot. got to work, removed key, locked car. walked away. came back with a flat battery. happened a few times before i disabled the TT lol
