Im looking for new tyres for my R33 GTST. Its completely stock but has some Lenso Muse 19" rims. Had Nexen N6000 before, looking at getting Pirelli P1's as theyre ment to be decent tyres and are very well priced form everything else Ive found. ($250 each including fitting and balancing, in Adelaide, SA). Thoughts?
Edit: Car is purely used on street, some spirited hills driving once in a while.
Edited by shubby0901
Thought I'd post up a review of the front tyres I've been running
Brand - Dayton DT-30
Size - 225/40/18 on 8.5" rim
Kms so far - 20,000 - about 30% left
Excellent daily tyre that performs good when pushed. Pretty good in the wet too
For 130 bucks a tyre they are excellent. Would buy them again
Car - R33 GTR.
Tyres - Nitto invo 245/45/17
Use - Fairly new, driven maybe 500km or so.
Power/Mods - Stock turbos, Boost Restrictor removed (14 PSI?), Upgraded midpipes and exhaust.
100% Grip in all gears.
In the wet grips extremely well under power.
Handles good but hard to say as I have not driven other GTR's to compare.
Edited by RB335
Car - R33 GTR.
  • 3 weeks later...
So federal have just released a new version of the RSR... the RSRR
My tyre dude says they are a better version yet again in the dry over the RSR. Has anyone had a chance to test these yet?
http://www.federaltire.com/en/products_detail.php?products_detail_sn=36
  • Like 2
DUNLOP DIREZZA STAR SPEC V2
CAR-R32 GTR
use these for auto-x days only, great cheater R compound tire. increased my times 3 seconds over my daily dunlop sr sports.
havent had the chance to use them in the wet yet but dry grip is incredible for the price and the fact that it will keep you in the stock class if you want to.
paid 650 for all 4.
no grip issues in any gear, car just has straight pipes and athe restrictor pill pulled. used on stock wheels as well.
held the fastest time of the day for 3 months straight, class includes multiple STI's, john cooper works minis, 240sx, etc.
all in all i highly reccomend the tire for racing and some people claim 20k miles out of them for daily duty as well
  • Like 1
Ill be trying these then for my next set
Kumho KU39
R32 GTS-t
205, 55, 16 (stock size)
DOM 43 week of 2011
Date fitted 02_11_2-12
Cost $560 Delivered (Temp Tyre's)
Fitting $80 Local Mechanic
Distance traveled 24 000 Km
Have about 1mm before the minimum tread depth indicators show.
Dry Grip 7.5 / 10
Wet Grip 8.5 / 10
Road Noise 8 / 10
Longevity / Wear 6 / 10
Only real complaint is sidewall flex, which affects change of direction precision, if you have a lower profile this may not be a issue.
Lovely tyre in the wet and road noise is minimal, excellent value for money, will probably put these on again as their price seems to have dropped.
Overall highly recommend for a daily driver.
Mike.
R34GTT Manual RWD
My reviews are based on grip for Drag racing and Launching. FYI, I'm not pro at launching, especially with my lightened flywheel. I can't really rate the tyres on the wet because I drive like a granny in the rain. I've been upgrading mods every now and then; hence the increased rwkw.
Front Tyres were always Nitto Invo 225/45/17 (UTQG 260)
1. Nitto Invo 245/40/17 (UTQG 260)
  • 185 rwkw - 13.9s ...Was OK for 185 rwkw. Second gear initially chirps but holds well after. Launching at 4000 rpm
2. Nitto NT05 255/40/17 (UTQG 200)
  • 185 rwkw - 13.7s ...Better than INVO. Second gear didn't chirp at all. Launching at 5500 rpm
  • 220 rwkw - 13.4s ...Started chirping on second gear due to increase of rwkw. Still performed well. Launching at 5000 rpm
3. Toyo Proxes R1R 255/40/17 (UTQG 140) - best so far
  • 220 rwkw - 13.2s ...60 foot time was better. First gear grips hard. Launching at 5500 rpm.
  • 220 rwkw - 14.0s ...MCM drag day - Hot weather. Maybe engine heatsoak. Too much grip. 7000 rpm bogging launches.
  • 251 rwkw - 13.1s ...Laggy turbo upgrade. Made me realise how slow I shift. Could of cracked into 12s for sure. Launching at 5500 rpm
I liked these tyres the best. No spinning issues because they grip hard!
4. Mickey Thompson Street Comp 245/40/17 (UTQG 300)
  • 257 rwkw - 13.2s ...Terribad for 257 rwkw. Spin all throughout 2nd gear. Screeching on third. Can't hold the power down. Spins at red lights when not even giving it. Launching at 3500 rpm
5. Federal 595 RSR 255/40/17 (UTQG 140) (PENDING... Not sure if getting these next...)
  • 295 RWKW - PENDING DRAG TIME ... Have not tested yet. Similar to Toyo R1R. Interesting....
IMO:
RWKW _____ TYRE
~200 _______ Mickey Thompson Street Comp (300 UTQG)
~220_______ Nitto INVO (260 UTQG)
220~250 ____ Nitto NT05 (200 UTQG)
250~300____ Toyo Proxes R1R (140 UTQG) Mates RWD 270~280rwkw hit 12.3s
300~ _______ Nitto NT01 (100 UTQG) Other RWD at Drags hit 11.7s
I would love to try:
Nitto NT05R (UTQG 0) - but $420 each delivered - tyre shop also said they dont sell them in Australia
Toyo Proxes TQ (UTQG 0) - not sold in australia - type shop
Yokohama Advan AD048 (UTQG 60) - Hmmm interesting. Saw it on a R32GTR in sydney
Federal 595 RSR (UTQG 140) - Hmmm.. Similar to Toyo R1R and cheaper
  • Like 2
Update! Replaced tyres yesterday. Couldn't get RSR or NT01 due to ordering delays. Tyre shop had R1R in stock.
Mickey Thompson Street Comp 245/40/17 vs Toyo Proxes R1R 255/40/17
295 RWKW R34GTT Manual
245/40/17 Mickey Thompson Street Comp
From 0, not launching: first gear spins as it reaches 3k/4k rpm on WOT.
Second gear spins before it reaches full boost. Starts spinning at 17 psi according to EBC
Third gear holds abit, but it screeches during high RPM- sounds like someone braking hard.
Launching at 3k and will spin as RPM rises.
255/40/17 Toyo Proxes R1-R
From 0, not launching: first gear does not spin, all the way to redline, reaches 20 psi
Second gear does not spin at all and reaches full boost 22 psi on WOT. Amazing pull.
Third gear no issues.
Launched at 5k rpm on street. Tyres chirped.. Good pull.. did not Bog down.. Very happy with these tyres at 295 rwkw.. 4.X seconds 0-100
I'm ready for Eastern Creek R4R ;)
  • Like 1
I just put some cheap rotala tyres on the front. The noise is horrible. Every bump sounds like someone is bouncing a tennis ball and they transmit a shit ton of road noise. Hankook evo s1 or something or rather i had on the fronts were much better but these were just a cheap option. I will be getting some rsrr for the rear.
I got Pirelli P1's installed due to availability and cost. They are really quiet and have tonsss of grip in the dry. Have not tested the wet weather performance yet though
Ive got pilot sport 3 on my 2012 sti and they were amazing on the SMSP south circuit in the wet at the last track day. Ran a 1.13 when it was still quite wet. Still good in the dry but best tyre i have ever seen in the wet.
You were quickest when it was raining. The amount of wet grip those PS3s have is amazing. I'm definitely getting a set for my Liberty.
  • Like 1
  • 3 weeks later...
you don't value your life much do you? the front tyres do all the steering and braking :)
I would rather good tyres up front and rat shit at the back.
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
