Skyline model = R32 GT-R
Wheel diameter = 18"
Wheel width = 9.5"
Wheel offset = +22
Tyre size = 255/35/18 all round
Modifications to fit = none!
they are sparco racing wheels with a nice bit of dish...just thought id add that
Edited by Turbz_13
Still nobody has answered this question. Can you fit R32 GTR rims on a R33 gtst??
Cheers
id also like to know this....atleast will they fit on rears? plus whats the widest tread you can fit on a r32 gtr rim?
to the above.. yes..
now for my new rims
Skyline model = R32 GTS-T lowered to guard 345mm front/rear
Wheel type = V35 standard rims (non track)
Wheel diameter = 17"
Wheel width =7.5" front/8" rear
Wheel offset =33(F), 30®
Tyre size = 215/55R17
Modifications to fit = front tyres scrub control arms.. requires lower profile tyres to fit fronts.
Ended up going for 235/45R17's for the fronts.. clearance is fine, however can scrub plastic guards on heavy bumps
Skyline model = BNR32
Wheel Brand = O.E.M R33 GT-R
Wheel diameter = 17
Wheel width = 9
Wheel offset = 30
Tyre size = 235/45
Modifications to fit = None (naturally)
These wheels give really good clearance around the brake callipers, for anyone looking to go up in brake rotor size without having to use adaptors.
Skyline model = SII R33 GTS-25t Sedan
Wheel Brand = Lenso GT-05
Wheel diameter = 18
Wheel width = 8(f), 8®
Wheel offset = +38
Tyre size = 225/40/R18, 235/40/R18 - Nankang NSII
Modifications to fit - Larger front rotors to increase space between caliper and spokes. Plus fill up that large gap between wheel and calipers :D.
These wheels will not fit over the front caliper without spacer or grinding the caliper. Ive gone to a 32GTR V-Spec disc (324mm x 30mm, a 28 mm increase in disc diameter) to clear the spokes.
Also i think people should be posting up brand and model of wheel so that others can see if their wheel of choice will fit over the front calipers.
cheers
Evil
Edited by EvilINGT
Hi guys i am looking at getting a set 19X10 racing hart cr wheels for my R33 GTR.
I wont the wheels to sit as close to the side guards as possible or even if they stick out just alittle, wondering if +20 is the offset i am looking for?
Thanks
Adam.
First of all, please forgive my ignorance. I am new to this site and found it to be a great Forum and has great people!
This is a great thread and i've just gone through to read all the pages. Lots of info in there. However, not many people have posted offsets on a R34 GTT. I've got a question as per the person posted before me. Can a 18x9.5 +30 wheel fit onto my R34 GTT seriesII? My car is stock with standard wheels and suspension. I am looking at changing my wheels to one of the BEE-R/Nismo LM types.
With this settings, will I have any clearance/rubbing problems? even with full turns?
Lastly, has anyone heard about Rota wheels and where to get them in Australia? Thank you all in advance! Keep it coming! Cheers,Michael
  • 3 weeks later...
model = Cefiro A31
Wheel Brand = Work meisters S1's
Wheel diameter = 17
Wheel width = 8(f), 9®
Wheel offset = +30(f), +35®
Tyre size = 215/45/R17, 235/45/R17 -
Modifications to fit - chop a tiny bit of the right hand plastic guard. The fronts stick out about 4 mm.
  • 4 weeks later...
I have asked this before and got a "probably not answer"
But will ask again to see if anyone has tried...an R32 GTSt with 17x9 +22 offset rims. Guards are rolled and car is not that low. Im thining even if i put narrow and lower profile rubber on them????? Say 225/40 front and 255/40 rears etc.
Or am i simply no chance. Unfortunately the rims are interstate so cant trial fit before buying
Skyline model = R32 gts-t 4dr
Wheel width = F:8 R:9
Wheel offset = +30 all round
Tyre size = 235/40/18 all round
Modifications to fit = none on the back, lipped the guards on the front
ROY:
you should fit them on the front. ive got about 35mm of clearence to the guard with 18x8 +30, and you need an extra 20mm to fit 17x9 +22. so with the steering wheel straight they should fit.
the rears will fit cos they will stick out 8mm more than mine and ive got about 20mm clearance from the guard with 235/40R18s.
if your lip is gone, then 255/40R17 should fit, if not stretch 235/45R17
and you want 225/45R17 for the front, not 225/40R17
Edited by salad
I'm looking at a set of 18x9.5" rims with a +12 offset will these fit with out and mods to fit (r32 GT-R)? I know the +12 offset is getting a bit boarderline for 9.5" wide rims
Can anyone confirm this?
I've got 18x9.5's with a +13 offset front and rear. The rears on mine don't seem to be a problem, and the fronts only lightly rub on one of the tabs for the guard liner when under heaps of load, or with more than 1 person in the car. A lot of that probably has to do with my suspension having HEAPS of travel, so with some stiff coilovers, the problems should disappear.
Incidently, tyres are 245/45/18's.
Skyline model = 1989 R32 GT-R
Wheel Brand = Work Emotion XT7
Wheel width = 9.5"
Wheel offset = 20
Tyre size = 245/40/18
Modifications to fit = None.
Car is quite low, as low as a set of super low springs if you had them. ( I have Teins)
Skyline model = 1996 R33 GT-R V-Spec
Wheel Brand = Work Emotion XD9
Wheel width = 10"
Wheel offset = +18
Tyre size = 265/35/18
They sure do fill out the guards now :banana:
    • Given you're running a 2.8 and my 2.5 is not really like for like, I suspect there could be a bit more timing you could give it. What is the kW yield per degree you're putting through it? Here's my E85 map to give you an idea, where it was I could still get another 3~4kW per degree thrown at it.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
