are all you guys that roll/flare your guards getting cracks in your paint or is it all good?
i had mine rolled and flared about 10mm and i only got a tiny little bit of cracking in the guard, i know plenty of people that have had there gaurds rolled 20+mm and had no paint cracking. It all depends on ya paint condition and the experience of the flarer!
Hey guys and gals
yes I'm a newbie
got a 1993 R33 GTS NON TURBO
need to know what other nissan's have the same rims (offset) would like new ones to make it look sweet i know why bother on a non turbo (girlfriends car and learning) not crashing mine hehe
what do you suggest because it only has a 4 stud pattern and having issues in wa getting rims out of like 10 manufactures can only get two different type limited sucks balls
anyone got any suggestions
thanks :P:D
  • 3 weeks later...
Hi Guys
I was offered a set of SSR Professor SP1, wonder does it fit a 34GTT? Anyone know how heavy this rims compare to the original 34GTR OEM rims also?
Size : Front 19"x8.5JJ+35 PCD114.3/5
Rear 19"x9.5JJ+43 PCD114.3/5
Skyline model = R33 GTST
Wheel type = No idea got with car
Fronts:
Wheel diameter = 17 Inch
Wheel width = 8.5 Inch
Wheel offset = +38mm
Tyre size = 235/45/17
Modifications to fit = None, that I know of.
Rears:
Wheel width = 9.5 Inch
Tyre size = 255/40/17
Skyline model = 1994 R33 GTST
Wheel Brand = Work Equip
Wheel diameter = 17
Wheel width = 9
Wheel offset = +32 25mm Spacers All Round
Tyre size = 215/45/17
Modifications to fit = Rolled front guards, Pumped/flared rear guards by 40mm
Smallest tire ive had on a 10 inch rim was a 215/45/18. Smallest tire ive had on a 9 inch rim was a 205/45/17 all @ 40+psi.
Will these wheels fit my Skyline?
Thanks for you help.
Skyline model = 1996 R33 GTST SII
Wheel Brand = Enkei Equip, RPF1 Type RC
Wheel diameter = 18
Wheel width = 8.5 & 9
Wheel offset = +42
Tyre size = 245/35/18; 265/30/18
Skyline model = R32 GTS-T
Front -
Wheel type - Koya 'Race Tek'
Wheel diameter = 19"
Wheel width = 8.5"
Wheel offset = +35
Tyre size = 235/35/19 Falken FK 452
Modifications to fit = Rolled guards, if you want it looking right height wise.
Rear -
Wheel width = 9.5"
Wheel offset = +38
Tyre size = 265/30/19 Falken FK 452
Rears.
Skyline model = R32 GT-R
Front -
Wheel type - Blitz 10 spoke (No idea what they are called)
Wheel diameter = 17"
Wheel width = 9"
Wheel offset = +22
Tyre size = 255/40/17 RE55's
Modifications to fit = Nil
Rear -
Wheel width = 9"
Wheel offset = +22
Tyre size =255/40/17 RE55's
Modifications to fit = Rolled guards.
Question: I want to upgrade to an 18" rim, but am unsure as to whether a 9" or a 9.5" would be more appropriate & which tyre they would go with. Tyre selection is either245/40/18 or 265/35/18.
So choice is 1 of three.
1 9 inch rim with 245 bag tyre.
2 9.5 inch rim with 245 bag tyre.
3 9.5 inch rim with 265 bag tyre.
Will the last of these fit given my 255's are marginal as best.
Rims;
17" URAS NS-01
Skyline model = R32 Gtst
Wheel diameter = 17
Wheel width = 8
Wheel offset = +30
Tyre size = 235/45/r17
- Scrubbing on lowered (340mm) on the front
- Removing inner guard lining fixes some scrubbing
- Still scrubs on lip, might have to roll
- Decided to put on some 225/45's to see if they will not scrub
Wheel diameter = 17
Wheel width = 9
Wheel offset = +30
Modifications to fit = Dont seem to have any problems with my lowered height (340mm) but may cause scrubbing later
Hi Guys
yeap they will fit. not sure what they weight but im guessing between 6-8kg per rim (guess they will be the same if not similar to the r34 gtr rim)
CAR MODEL = Nissan R33 Skyline Sedan
WHEEL DIAMETER = 17" Front, 17" Rear
WHEEL WIDTH = 8" Front, 9" Rear
WHEEL OFFSET = +12 Front, +12 Rear
TYRE SIZE = 235/45 Front soon to be 225/45 for stretched goodness, 235/45 Rear
SPACERS = None
MODIFICATIONS TO FIT = None at the moment but plans are Fronts to be rolled
Rears: Roll and Flare 15mm VIP style FTW,
RIM TYPE = Works Revax Meshies
Pic:
Edited by phillb
SPACERS = None
Pic:
Hate to tell you buddy, but a 225 on a 8" rims won't be even CLOSE to being stretched, it will still be bulging. I've got a 205/50 on my 16x8 Volk rim and it barely looks stretched. If you put a 215 on the rear rims you won't need to flare the guards, maybe just a light roll
Edited by ~Hypnotik~
Just copy and fill in the table;
Skyline model = R32 GTS4
Wheel diameter = 20
Wheel width = 8.5
Wheel offset = ????
Tyre size = f/225,r/245
Modifications to fit = none atm maybe have to roll rear guards a little bit
IMO the 225/45 will sit better than the 235/45 I have on my 17's as they have large lips so it helps to give a more stretched appearance, with lots of Dish on a +12 rim it will give a bit of extra camber and clearance inside the guard!
I'm not looking for super stretch with 215's, just enough to give more definition to my rims!
    • Nice, thanks for sharing your progress....that's a pretty long list you are putting into it!
    • Decided to upgrade my pressurised plastic coolant expansion tank for a fancy pants alloy version The OEM versions can get brittle, even the new plastic one I got when I first got the car is a starting to show signs of "stress" I wasn't cheap, but it is basically unbreakable
    • Morning all, I have an RB25DET Neo that's in need of a rebuild. Will need new pistons etc due to detonation damage. Would anyone be able to recommend a shop in Southeast Queensland who I could bring my long motor to for a rebuild? Just want someone who knows RBs and whos built a bunch of them before. TLDR - recommended engine shops for RB rebuild.
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
    • Losses have to be less with DC coupling. Provided the battery inverter has decent MPP tracking ability - which really shouldn't be a problem. It's not 2005 any more.
