1999 Nissan Skyline R34 GTR Vspec
Forged bottom end
R34 turbos rebuilt with gt2860-7 cores
660cc injectors
Weldina NE-1 Exhaust
Link g4 plug in ecu
19psi
BP 98
332kws atw
516nms atw
332kw on 98 with -7's? I call shenanigans.
  • Like 1
  • 3 weeks later...
Hi all just got my R33 GT-R le mans tuned.
Unopened r33 rb26 done just under 100,000 (whether it is legit or not lol)
Mods:
r34 n1 turbos
Ported stock manifolds
Split dump pipes
Xforce front pipes
100cel cat 3"
3.5" cat back
Apexi pods
Trust fmic
Hks evc-5
Link g4+ ecu (no afm's)
Siemens 660cc injectors
Nismo fuel reg
Walbro 255
OS Giken twin plat clutch
Probably more i missed.
Made 300hp on 14psi
365hp on 20psi
Was hoping for abit more after seeing some of the results here, but tuner said to do cams/gears/springs and should get near the 400hp mark.
You should only need cam gears, the cams and springs are more then fine to support over 300kw(400hp)
Might want to get rid of the split dumps and maybe check the fuel is good (i.e. The servo put the correct stuff in their pump)
  • Like 1
Thanks for your input,
will probably change cam gears next time i service it, dumps i probably should have changed when the turbos got replaced last week lol :(
and the fuel has been sitting in the tank for around 4 weeks so shouldn't be foul and i used caltex 98, but yeah possibilty of shit fuel maybe.
Depends what split dumps they are, I have split dumps on both my cars, 32 on stock turbs makes 291rwkw at 19psi and the 34 with GT-RSs on a 3.0 made 435awkw on 24psi
Does this seem low/laggy?
34R
Haltech Platinum Pro
N1 manifolds
-9s
HPI dumps and 3" front pipes
Full 3.5" exhaust after merge, catless
Stock airbox with apexi panel
E85 with 1000cc Injextors and 460lph walbro
22psi despite what graph says.
Cam gears, intake 3deg advance, exhaust 3deg retard.
Twin turbo pipe mod
Torque is oddly high also.
Rpm jumo was explained as tacho pickup on the injector wire because he can't get to the coils
I have a second graph that's fine.
Edited by ActionDan
34R
N1 manifolds
-9s
Twin turbo pipe mod
You would need to find out exactly what the revs are for us to know but going off the speed it looks like it was dynoed in 3rd or maybe 4th
My 4th goes 205@7000 but then it is a little bit longer the factory
Dropping off at 160kph seems like 3rd if it was revving around or over 7000 rpm?
4th apparently
I just liked to drive them and when they do not do what I want, i changed it until I was happy. So I guess it is up to you, if you feel the car runs great, it is great :)
Going off the Dyno I think yours looks really good and should drive great on the road and track. "Can only guess about the track, lol"
How do you like it ?
Post the 2nd graph
Twin GTX2860R 0.72 rear housings
Precision 46mm ext gates
Custom stainless steam pipe equal length high mount manifolds
Tomei oversize oil pump
ID 1000's
Twin Walbro 255's
2.5″ stainless dumps, 3" dump back
CNC Steel adjustable cam gears
Twin 6″ K&N pods
PWR Aero2 cooler with 3″ outlets
PWR twin pass X-flow 55mm radiator
PWR 21 row oil cooler
SPAL 16″ skew blade 2000CFM thermo fan
3 Quart Accusump
Custom RWD R33 GTR sump
Stock cams
Stock bottom end
Stock head
373.2kw @17psi on E85
Compression test prior to the dyno came up with 185-190 across all 6, not sure why it was so high. Tried wounding out some power but caused misfires, so wouldn't make any less.
New cams, ECU and valves coming in the next few months, no idea what it will make when retune happens.
  • Like 2
  • 3 weeks later...
    • HyperGear. Just get a high flow of the stocker. Good, reliable, and should bolt on. Yes it will want things like a retune once done, so you need to factor this in to your spend too.
    • Hi. Iam looking for some "cheaper" bolt on turbo on RB25DET NEO. I do not want "big" power just better reliability than the stock turbo which is "fot now" good but is old and i do not think it has "easy" life. One the Skyline here running some "temu" china Turbo but i dont trust those... Thanks!
    • Hi guys, Making some space/cleaning up. A whole heap of random OEM R33 GTR parts and other random bits and bobs. I will update this thread as I go. Parts are located in Moorebank NSW 2170. Pickup preferred but will post at buyers expense. Prices are negotiable. If they don’t sell it will go in the bin. Item 1: BOV return pipe. $40 Item 2: RB26 cam gears. $20 Item 3: R33 GTR torque split, oil temp, boost centre gauge. $100 Item 4: RB26 fuel rail x 2. $20 each Item 5: RB26 Recirc valves. $50 Item 6: OEM upper front arms. $20 Item 7: Royal Purple Max Gear 75w-140 1 quart/946 ml x 5. $50 each or 5 for $200. Item 8: OS Giken 80w-250 diff oil 1 litre. $25 Item 9 Eibach springs. ers-11-140-60-0140. $100 https://www.streetfx.com.au/eib140-60-0060-eibach-ers-140mm-length-x-60mm-id-coil-over-spring?_ga_campaignid=22235933977&_ga_adgroupid=180146800292&_ga_keyword=&_ga_device=m&_ga_target=pla-295238231169&_ga_locint=&_ga_locphy=9071723&_ga_matchtype=&_ga_network=g&_ga_device=m&_ga_placement=&_gcl_id=CjwKCAjwlt7GBhAvEiwAKal0cvkVE_hstv24cDiaICsIk1oznH9zAoJf3By6vR3Tpe7jmByqM6JFHBoCZYAQAvD_BwE&gad_source=1&gad_campaignid=22235933977&gbraid=0AAAAADPiTbo1xAuvnjIWWYnezivf-BUSY&gclid=CjwKCAjwlt7GBhAvEiwAKal0cvkVE_hstv24cDiaICsIk1oznH9zAoJf3By6vR3Tpe7jmByqM6JFHBoCZYAQAvD_BwE
    • That's kind of what I was getting at saying you'd be here soon regarding length etc being able to add additional restriction.  My assumption (possible donkeys of you and mption) is that the length of hose to an oil cooler, and back, isn't going to be that huge of a loss. Typically you're talking about 1.5m of total length. And so far everyone in our world hasn't had issues with oil not being able to get to a cooler and back, it's more been, how the heck do we get the oil out of the head and back down to the bottom? I'd nearly hazard a guess the biggest issue people have with oil cooling and oil supply, is being able to get the heat out at the cooler itself (not enough air flow, too small of a cooler etc) Also, when people mount them wrong and make really awesome air traps so they've dramatically diminished the cooling capacity.
    • I will rebutt this and the preceding point from Dose....but without doing any calcs to demonstrate anything and without knowing that I am right or wrong. But... The flow capacity of a fluid transfer system is not limited by the smallest orifice or section of conduit in that system, unless it is drastically smaller than the rest of the system. OK, I use the word drastically perhaps with too much emphasis, but let's drill down on what I really mean. The flow capacity of the system is the result of the sum of the restrictions of the entire system. So, to make an extreme example, if you have a network with 3" pipe everywhere (and let's say a total length of only a few metres) and that 12mm ID restriction of the oil filter connection being the obvious restriction, then for any given amount of pressure available, the vast majority of all the pressure drop in the system is going to occur in the 12mm restriction. But.... increase the length of the 3" pipeline to, say 1000m, and suddenly the pipe pressure loss will likely add up to either be in the same order of magnitude, possibly even exceeding that of the 12mm restriction. Now the 12mm restriction starts to matter less. Translate this to the actual engine, actual oil cooler hose sizing, etc etc, and perhaps: The pressure loss caused by flowing through the narrow section (being the 12mm oil filter port, and perhaps any internal engine oil flow pathways associated with it) is a certain number. The pressure loss through, say, -12 hoses out to the cooler and back is negligible, but The pressure loss through -10 hoses out to the cooler, at the exact same length as the above, starts to become a decent fraction of the loss through the 12mm stuff at the filter port. Maybe even it starts to exceed it. I could actually do these calcs if I knew 1) how much oil was actually flowing in the line, 2) gave enough of a f**k to do things that I hate doing for work, voluntarily for a hypothetical discussion. Anyway - I reiterate. It's not the narrowest port that necessarily determines how much it can all flow. It is the sum. A long enough length of seemingly fat enough pipe can still cause more loss than a semmingly dominant small bore restriction.
