Sorry, Forgot to post specs
Rhemac RB29 - destroked RB30 crank
Eagle H beam rods
CP forged pistons and rings
ACL race series bearings
CNC ported head
Ferrea 1mm stainless valves
HKS 264 10.2mm step 2 intake cam
HKS 272 10.2mm step 2 exhaust cam
Bronze valve guides
ACL 1.2mm MLS head gasket
Gates adjustable timing gears
Tomei oil restrictor
Greddy Oil pump
ATI balancer
HKS 25/30 with HKS actuators
HKS pod filters
Xspurtz 1550cc injectors on factory fuel rail
Turbosmart Fuel regulator
Twin Walbro 460LHP pumps
OS Giken triple plate clutch
100mm Blitz intercooler
custom 4" exhaust
Tech edge 2J9 wideband O2 sensor
Haltech Eflex fuel sensor
Vipec V88 ECU
Trent @ Chequered Tuning E85 and 98 Octane tuned
E85 - 481rwKW; 775Nm @4900 rpm
98 Octane - 431 rwKW; 662Nm@5404
Responsive?
Eagle H beam rods
CNC ported head
Bronze valve guides
Greddy Oil pump
ATI balancer
HKS pod filters
custom 4" exhaust
Vipec V88 ECU
Responsive?
Did this car used to belong to Mark from Rhemac?
The Borg Warner thread got shut down so I'll post here for those interested.
BW EFR 8374
Stock bottom end rb26
256 cams
E85
504kw - 30psi around 4600rpm.
Has another 30-40kw in it. I told him to stop at 30psi due to standard bottom end.
  • Like 5
BW EFR 8374
256 cams
E85
got any plans to race it?
r34nur
stock engine
gtx3576 0.82a/r
walbro 450
id1300
260kw@18psi n1 turbo 98 fuel
310kw@18psi gtx3576 ( same boost response as n1s) 98 fuel
287kw@14psi gtx3576 e85
346kw@20psi gtx3576 e85 (tuned boost build a bit slower then 98 tune, cause I don't want boost spike)
Model/Make: 2002 R34 GT-R M-Spec
Mileage: 110,000 kms
Output
320rwkw / 430rwhp
Head / Turbo
- Garrett 2860-9s - fitted with HKS oil feed restrictor banjo bolts
- Garrett 1bar actuators
- Tomei dump pipes
- Standard cast manifold - Port matched to turbos
- Tomei Poncam Type A - lifter shim clearance within OE spec
- Jun adjustable cam gears (OR gears modified to be adjustable) - set to 0deg/0deg
ECU/AFMs
- Apexi Power FC
- Nismo AFMs
Cooling
- Plazmaman Pro Series 76mm intercooler
- Koyorad 48mm aluminium radiator
- Trust 13 row oil cooler with filer relocation kit
Exhaust / Intake
- Amuse R1 Titan Extra cat-back exhaust 90mm
- Apexi Super Catalyzer Cat - 80mm
- Mines Pro front pipe (2 x 70mm into 80mm)
- Nismo inlet piping
- OE Airbox with Nismo panel filter and snorkel
Ignition / Fuel
- Sard 650cc top-feed Injectors
- Splitfire coilpacks
- Wiring specialties coilpack harness
- Nismo 255L fuel pump
- Denso iridium spark plugs
Edited by squareznboxez
  • Like 4
  • 4 weeks later...
I've posted this in a separate thread earlier this year. I do have to go back and retune again as brand new power FC boost controller did not work again so we ended up running it on manual boost controller. I will probably dump PFC altogether and try "Link G4 ECU"  plus play with cams/gears--currently set at zero. My main question is, what are some general boost levels that many of you run on your cars? I plan on running this motor regularly at 22-25psi.. car will only be used for couple of monthly coffee meets and occasional evening night rider passes.. along with few drift events each year.
Most importantly, I'm thinking of dumping the brand new GTX3582 for an EFR8374 rear 1/05 a/r divided housing in hopes for quicker spool and more power at the same boost level. Can anyone share their experience with 8374 in comparison to my set up? I hear 700whp should be no problem and that's my ultimate target goal.
Any feedback is greatly appreciated!
Set up is as follows in S13 chassis:
Mildly built R33 (pistons, rods, upgraded oil pump, HG, head studs, tomei poncams type B
ID1000cc injectors running power FC d-jetro
e85 race gas
all the misc bolt-on's you can think off
running GTX3582R, .82 rear T4 undivided with two 50mm gates
Here is what it made at 22-23psi..
    • Block bump. $400. As above cyl 6 needs bore or sleeve.
    • I would think making the argument that the travel is limited by a spring flexing against a spring perch as "the same method". Later on in the document they do state that the spring can't bind on full bump travel and cannot come loose in full rebound travel as well. (which is all very sensible). The laws are actually pretty sensible and reasonable. It's just that the people who enforce and check them don't actually read them or know them accurately. "Oh, coilovers? Instant fail mate. Don't even need to look at it." - Guy who will be instantly reported by me. There is probably merit to people who do get defected for height also get defected for the suspension in that state that allows it. I did never consider the people who are complaining about coilovers being picked on are also running around at 50mm off the floor.
    • I think given SAU's knowledge of E85 we can strongly conclude that 10% ethanol in almost any situation is entirely fine. Almost all of the myths against E85 were overblown, let alone E10.
    • From your link See bold text, is this referring to damper settings, if so that may a issue for "some" inspectors, I cannot see aftermarket coilovers having the evidence that "must be available that its functional performance is equivalent to the original" Maybe just remove the adjustment knows and hope for the best???? Meh 5.2 Suspension travel In all instances, modifications to a vehicle’s suspension must ensure the integrity of the system and not compromise the ride quality. At least two thirds of the original suspension travel should be maintained in both directions (rebound (i.e. extension) and bump (i.e. compression)), and rebound must be limited by the same method used by the vehicle manufacturer or if this is not practicable due to the nature of the modification, an equivalent method. If an alternative method is used, evidence must be available that its functional performance is equivalent to the original.
    • They actually don't - They adhere to VSB14 rules just like Victoria. The rules are against CABIN adjustable height, and it quite clearly states that the height has to be within parameters. I asked the VASS engineer to confirm this when I got my car engineered and they refused to engineer the coilovers because they didn't meet the requirements for requiring engineering. (mine are height adjustable.) People "Not wanting to bother" with "Actually reading/knowing/adhering to the rules" should result in fines and immediately losing the ability to issue blue slips and/or RWC's in Vic.
