HKS 2.8 (86.5mm), Tomei Pon Cams
Precision GEN2 6266 Twinscroll, 1.5bar/22psi
98RON Shell VPower, 660cc injectors, HKS in tank pump
611hp/455kw at the rear hubs at 6600rpm , 510lbft at 5200rpm
Before we built the 2.8 this turbo made 577hp at 1.2bar/18psi on a 2.6 with 87.5mm pistons (basically 2.7) with similar response.
  • Like 3
  • 3 weeks later...
1991 GTR
- stock RB26DETT (shows signs of a refresh but can't confirm)
- gt2860-5 twin turbos
- stock injectors
- HKS green mushroom intake
- 3in exhaust line
- HKS down pipe
Safe tuned at 356rwhp at 15psi.
(i will eventually upload the dyno curve once I get it by email)
  • 4 weeks later...
On 2/2/2017 at 11:10 AM, Darmanin10 said:
R32 GTR
gtx3576r with 0.83 rear housing
Tomei poncams & cam gears
1000cc xspurts injectors
3.5 inch exhaust
344kw @ 22psi
Same setup, but now forged engine setup for track abuse.
Needs bigger injectors for more power, as they are maxed out at this level.
1102422031_20180913_PaulDarmaninNissanGTRR32kWVsbOOst.thumb.JPG.29497fe2725a22d23aa8ee61468f9ff4.JPG
The RED line is cam timing before
BLUE  line is cam timing after
ORANGE line is high boost.
  • Like 1
1991 R32 GTR
Stock motor, headstuds
Rebuild JDS Performance R32 Turbos, N1 exhaust wheel, billet compressor wheel
Midori 3" outlets
2.75" to 3.5" twin pipe
3.5" exhaust
Modded twin turbo pipe
HKS hard piping kit
Blitz front mount, size big
Radium fuel rail, 1050x injectors, walbro 450
Full AEM sensors w/Infinity
Custom intakes since MAFs aren't required anymore
505AWHP 398TQ @21 PSI, 5280 elevation
Really happy with the power for the small turbos!
  • 1 month later...
  • 4 weeks later...
1992 R32 GTR
HKS GT-LC low mount twins (Unknown specs. Would love more info on these but can't find it!!!)
Haltech PNP on stock MAP sensor
Stock Intake
Stock Dump Pipes, Blitz Front Pipe, 3" Test Pipe, Fujitsubo 3" Catback
DYNO GRAPH
(Red Line: 408HP, 356 lbft; 16-18psi, 91 octane) [Blue line is Jap tuned ECU on 101 octane]
Next Steps (advice welcomed):
Greddy MAFless pod filter and pipe intake kit
HKS Cam Gears
Tomei turbo outlet pipes
ID1050x injectors
External MAP sensor
Walboro 450 fuel pump and rewire
Greddy 12 row Oil cooler and Filter Relo
HKS SSQV BOV kit
Twin Plate Clutch (Nismo Super coppermix or alternative)
ARP head studs
Metal head gasket
Possibly E85
Shooting for 550hp before i run out of puff from the snails.
Edited by UMZenki
N1 RB26
Poncams
-7s
Haltech elite 2500
427hp on 98
507hp on e85, somewhere around the 21 psi mark. Boost solenoid was on max duty.
Will be back with a high mounted GTX35.
Edited by sleptema
  • Like 1
  • 1 month later...
On 12/20/2018 at 7:17 PM, sleptema said:
N1 RB26
Poncams
-7s
Haltech elite 2500
427hp on 98
What version of Poncam's are on this? -7's seem to be on quite late. 20 psi at 5000rpm?
  • 2 months later...
Engine - Stock Rb26 Bottom end
Head - Tomeii type b poncams & tomeii adjustable cam gears. Brian Crower springs, supertec valves and guides
Turbo's - Twin factory mounted TD05-18g's, billet wheels with billet actuators
Brain - Nistune, turbosmart eboost street
Exhaust - Stock ex manifolds and dumps, Nismo front pipes then high-flow cat to 3.5 inch exhaust straight through to cannon
Fuel and supply - 98 PULP, 1170 xspurt injectors, nismo fpr, 450lt/hr pump
Intake/Cold side - Nismo AFM's, stock everything else stock including airbox, intercooler, blow off valves, piping and inlet mani
352kw's at the tyres on 19psi. Quite laggy but not as bad as expected, full boost hits just under 5k, 5 degrees adv on inlet cam, 2 on exhaust picked up heaps of mid-range. Very happy with the result, Mark from MRC worked his magic again, I was very nervous about those turbos, the stock airbox and exhaust manis/dumps but all and all it's great! I'll post a graph up shortly.
  • Like 1
On an intertia dyno I could see this being the case. -7 are significantly later on threshold and lag compared directly to 8374 efr single FYI all
Very similar, they are Mamba turbos. So non bb cartridges wich would be the only real downside other than the size for the 2.6. Be interesting to see them on a 3.0+
Are these t517z turbos?
  • 3 weeks later...
R33 GTR
Clicked 100,000kms on a budget built 2.6 on an old Power FC with 255rwkw so decided it's finally run in and went single turbo. [emoji23]
-proboost gtx35
-ETM manifold
-50mm turbosmart wastegate (18psi spring)
-1000cc Bosch injectors
-walbro 460
-standard cams
-adaptronic ecu
E85 of course
Manual boost tee maxed out, one slight turn and it just overboosts,
Needs a proper boost controller.
376.4kw on 23psi
Tuned by Jez
13 hours ago, JDM33R said:
R33 GTR
Clicked 100,000kms on a budget built 2.6 on an old Power FC with 255rwkw so decided it's finally run in and went single turbo. emoji23.png
-proboost gtx35
-ETM manifold
-walbro 460
-standard cams
-adaptronic ecu
E85 of course
376.4kw on 23psi
Tuned by Jez
Any chance you ran a 98 tune also?
  • 1 month later...
Forged RB26 (Sleeved block, 87mm Pistons, rods, rod bolts, head studs, N1 oil pump with billet gears, Tomei sump baffle, Tomei metal head gasket etc...)
-7 turbos rebuilt with larger billet wheels
Nistune ECU (Latest update - Flex Fuel, Boost control etc)
Standard Exhaust manifolds and intake piping (Port-matched to suit bigger wheeled turbos)
1250cc Injectors
460LP/h fuel pump
Nismo AFM's
Standard Air-box with CAI and K&N panel filter
Splitfire Coil packs
Kelford L182a cams
Greddy cam gears
Plazmaman 76mm intercooler
391rwkws @ 24psi (how it's driven) E85
417rwkws @ 26psi (airbox just cracked open) E85
335rwkws @ 20psi (how it's driven) 98RON
RB 28 with GTX3584RS used as Track car
HKS step 2 2.8 full counter rank rods and pistons
HKS 272 exhaust cam
HKS VCAM Pro with 10.2 lift
Ported head - ferrera valves etc
Peterson dry sump running vacuum
N1 block
Nismo Plenum
Modified ITB's
6 Boost stainless steel Promod manifold (Small runner)
GTX3584RS
1.21 rear housing
E85
Runing through Sachs carbon carbon clutch and flywheel (3kg)- Albins straight cut transmission and Nismo diff
stopped at 26 PSI 562 RWKW  was 420 KW at 13psi   705 ftlb torque.
Have posted so anyone thinking of using this turbo can see the results.
Probably a better choice would be the precision PT6870 or 6875  with a large runner manifold
Edited by Paul T
1
  • Like 10
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
