  • 1 month later...
PMC race engines built 2.8
High compression build
N1 block, billet main caps, braced + 1/2” main studs
I beem rods 625+ bolts
Custom pistons
full house head cnc + hand porting shimless setup with full supertech catalogue 625+ studs etc
7675 gt42 gen1 turbo 1.12 rear
twin gate true twin scroll setup with egts etc
made 800kw at 37ish psi
turned it down to 770kw at 33ish psi
thats with full 4” exhaust and mufflers no dump/cut out valves
  • Like 10
So I take it the goal would be in the 8s then ? 770kw at wheels is what, at least 160+mph ? I'd like to see the curve for the delivery and results of that much top end mumbo. Keep us updated with a time 👍
  • Like 1
  • 3 weeks later...
Racepace built RB28
9:5:1 compression ratio spool pistons
Nitto I beam rods
Spool billit 2.8 stroker crankshaft
PRP engine brace
HKS step 2 valve springs
6 boost manifold
Borg Warner EFR 8374 1.05 A/R
Turbosmart 60mm wastegate
Nitto oil pump
Racepace custom 3.5” dump pipe + screamer + high flow cat
Tomei extreme titanium cat back
Plazmaman 100mm intercooler
PRP trigger kit
PRP R35 coil kit
ARP main and head studs
Tomei cam gears
Haltech elite 2500 + WB1 + Flex fuel sensor
Bosch 1650cc injectors
Turbosmart fuel pressure regulator
BPP fuel rail
Nismo front LSD
Racepace transfer case upgrade
Aftermarket industries surge tank with 3 walbro 460lph pumps
Racepace extended circuit sump
Direct clutches custom twin plate cushioned button clutch
Racepace catch can
Made 504.9kw @ 25psi on E85
  • Like 3
  • 1 month later...
Custom pistons
Do you have a dyno graph? Interested in response
R34 GTR Stock twins RB26dett stock 2.6L engine
Nismo FMIC
Trust 3 inches turbo back exhaust
PS2000
P98 fuel
272awkws at 16psi.
With APR head studs
HKS Cam gears +9" inlet, 0 exhaust.
R35 GTR coil packs
Trigger kit
ID 1650cc injectors
Twin 540 Walbro pumps+11m fuel line
Nismo Front mount cooler
T4 high mount exhaust manifold
HyperGear 50mm External gate
HyperGear ATR45SS1 T4 .86 rear
3 inches front pipe with cutout
Final result so far 425awkw @ 28psi E85 fuel
Edited by hypergear
  • Like 3
  • 3 weeks later...
R32 GTR
CP Pistons 86.5mm 9:0:1
N1 Oil Pump w/ SPOOL Spline Driven Billet Gears
Manley H-Beam Rod w/ 2/8" ARP 2000
ACL Main Bearings
ARP Head/Main Studs
SuperTech 70lbs Single Valve Spring w/ Titanium Retainers
ECU Masters EMU Black
HKS 2530s rebuilt with billet wheels
Radium Fuel Rail
ID 1050 Injectors (Resistor Box Deleted)
Aeromotive FPR
Frenchy's (FPG) Fuel Pump Assembly w/ Baffles
Walbro 455
Uni-Group 260/260 10.9mm lift
 Tomei Adjustable Cam Gears
512 WHP at 15 PSI 357 ft lb TQ(E85)
569 WHP at 20 PSI 396 ft lb TQ(E85)
  • Like 2
  • 1 month later...
Stock Rb26 with APR head studs
R35 GTR coil packs
Trigger kit
ID 1650cc injectors
Apexi FMIC
PS2000
HyperGear ATR45SS Prototype T4 Vband rear
Final result so far 377awkw @ 25psi E85 fuel. 220AWKS @ 4000RPM. 20PSI @ 3500RPM
  • Like 2
unopened rb26
precision 6266 1.15 a/r
1200cc fic
twin intank 450 walbros
platinum pro
prp trigger(installed after another cas failed on us had a crushed cherry sensor from the set screw so got a new one and good to go now as this was a on going issue for me as some may know)
r35 coils prp
plazmaman intercooler
4" exhaust and dp
kelford cam gears stock cams
god have mercy on my stock gearbox.
450whp on pump at 17 psi
570whp E85 23psi
throwing studs in today going to go up for 25 psi for a final tune and numbers. cheers mate thanks again SAU members for helping finish the car. built motor hopefully done soon on a 6466 BB for the winter, 900hp dreams.
dynocom hub dyno is what we use. mainline hubs would be nice they have a u joint in them so you dont have to line them up so deadly and doesnt shake as much during a pull. oh well we got what we got and they work. so for living in the middle of no where we are blessed to even have a dyno option. cheers
  • Like 2
On 06/05/2021 at 4:36 AM, MoMnDadGTR said:
unopened rb26
1200cc fic
platinum pro
r35 coils prp
4" exhaust and dp
570whp E85 23psi
Here’s the 580whp pull. Did a couple at 620whp but the head lifted. So gunna fix that up this weekend then I will get hopefully get the races that have been waiting for me on video and upload them. Lots of jz and ls guys talking shit so throwing the r888’s on and gunna Make em put there money where there mouth is. Cheers mates thanks for the support and help throughout
Stock R34 GTR Rb26 with APR head studs
HKS Cam gears 0 inlet, 0 exhaust.
R35 GTR coil packs
Trigger kit
ID 1650cc injectors
Apexi FMIC
PS2000
Final result so far 443awkw / 594awhp @ 27psi E85 fuel. 20psi / 200AWKS @ 4000RPM.
  • 5 weeks later...
R33 GTR Rb26 with:
APR head studs
Nitto bottom end
Cam gears at 0 inlet, 0 exhaust.
R35 GTR coil packs
Trigger kit
ID 1650cc injectors
Apexi FMIC
Trust 3.5 inches turbo back exhaust
Haltech ECU
High mount exhaust manifold
TurboSmart 50mm External gate
HyperGear ATR45SS2 Turbocharger in 1.0 rear
Final result of 625rwkws @ 38Psi, E85 fuel.
Engine built by CPG, Tuned by CPG using Chequered dyno
  • Like 1
R35 GTR coil packs
Trigger kit
ID 1650cc injectors
Apexi FMIC
PS2000
Final result so far 485awkw / 650awhp @ 32psi E85 fuel. All in by 4200RPM.
  • Like 1
  • 1 month later...
R32 GTR
Nitto 2.8 stroker
Precision 6466 T4 divided 1.0 a/r
Haltech Elite 2500
BP ultimate 98 RON unleaded
456kw / 611hp at 22psi
A bit more on United E85 at 32psi
Full specs on build thread
  • Like 7
On 27/08/2021 at 10:54 AM, hattori hanzo said:
nice work mate, similar setup to mine, any plans to take it down the 1/4 and clock a mph?
Absolutely !
Red centre nats 07 is in 7 days time and is entered in the Drag racing and motorkhana. No dyno event this year which is disappointing...
I haven't been out at the drags in a while so I'm hoping this cars history has been forgotten as its previous best was 10.6 @ 130mph.
I used to have a group 3 ANDRA license and the car has been previously log booked, so let's see if they actually let me on the track as its an ANDRA sanctioned event for the drag racing component.
...and if I remember how to drag race properly !
  • Like 2
  • 6 months later...
Tomei Type B Pon cams
R35 GTR coil packs
Trigger kit
ID 1650cc injectors
Apexi FMIC
PS2000
Final result so far 444awkw @ 23psi E85 fuel.
RB26 Tommykaira build, aftermarket cams and pistons that i have no details on.
N1 block
N1 turbos
id 1050cc injectors
walbro 350lph
TK fmic
TK 3in exhaust with cat (in US I can remove cats, have not)
link g4+
shitty west coast US 91aki fuel
420awhp
Edited by Kanaric
  • 4 weeks later...
On 12/6/2020 at 7:11 AM, cliptonz1 said:
1994 R32 GTR
Engine:
HKS 2.8 stroker step 1 86.5mm
ATI 1000hp balancer
Platinum Racing rb26 brace
Garage101 extended sump
N1 water pump
Nitto oil pump
Head:
Kelford Cams 274in/274exh 10.55mm (182-S)
Kelford Cams CNC’d ported head
+1mm oversized valves
Kelford Cams beehive springs
Kelford Cams titanium retainers
HKS Cam gears
Nitto 1.2mm headgasket
ARP ca625+ headstuds
Nitto gaskets inlet/exhaust
Spool head drain
Hi octane direct cam baffles
Turbo/manifold:
6boost vband manifold
Turbosmart progate 50mm wastegate
4” dump pipe to 3.5” system
AES resonator and muffler
Garrett GTX3584RS 1.01 rear
Fuel system:
Turbosmart fpr 1200
Frenchys performance garage twin intank
Walbro 460 fuel pumps x2
-6 feed speedflow 200 series hose
-6 return speedflow 200 series hose
Ignition:
Platinum Racing r35 coil kit
Platinum Racing trigger kit
NGK Copper spark plugs
made 472hp on BP98 18psi by 4500
Will be going e85 when I sort out my getrag and will turn it up.
trying to figure out why it nosed over up top
Updated setup.
Garrett G42-1200 1.01
  • Like 3
    • Thank you GTSBoy and MBS206 I have done the compression test with the motor out of the vehicle, reason for the test was to see if I needed to remove the head and do rings etc while its out. I'm in the process of respraying the vehicle and tidying up a few things. Story behind it all is I've just purchased the skyline and it was running when I got it, never drove it on the street though as I wanted to pull it down and do it all up again before registering it. the gentleman I purchased it from told me the motor has a forged bottom end and has a decent tune through it but I was going to pull the sump off anyway to see if it is a forged bottom end. that's why I thought id do a compression test beforehand.
    • Man, I'm kind of amazed that the price of the turbo has not changed in 7 years. Everything else is inflating beyond reason, but not this? Good on Tao / hypergear I guess? Anyways, good luck with the sale!
    • I'm selling my brand new, in the box, never used Hypergear ATR45 - and I had some additions I paid for a few yrs back when I purchased it. Never ended up having the rest of the money to add all the mods at once, so I just ended up slowly selling each part. I originally had it internally gated, with the dump pipe, however I found it was incompatible with what I was going to use it for, so I contacted (I think Ken) from Hypergear, and he and I messaged back and forth & he got me to ship the turbo back, where they modified it & made it externally gated, and gave me the 5 bolt dump pipe attachment for custom welding. (Photos below) This turbo like I said has never touched the inside of an engine bay, it's completely brand new, never used, been sitting in the same box it arrived in, covered in plastic & all. Below are the photos of it: And while the guys at Hypergear were making it in-shop, they sent me some photos of the process: I'm looking at selling this just because I'm in need of the money right now, and don't have plans on modifying the 34 anytime soon - and from reviews & peformance sheets, this turbo had amazing results back when I was researching. The turbo was purchased in 2018 for $1.9k, with the mods I got added on. Looking at the website now, for the same turbo they sell (ATR45SAT), with the current addons it adds up to $1830 for the turbo Current addons included: - Bolted dump adaptor - Ball bearing CHRA - Braided oil feeding line So I'm looking to possibly sell it for around $1800, with shipping included in that 1.8k, It cost me around $120 to ship - so yeah thought I'd throw it out there and see if anyone was interested in purchasing. Cheers!
    • Turn up your speakers https://youtu.be/5_GK5ChNjOs?feature=shared
