What I have figured out from the other side of the world is. Is this thread needs to be more foused. People on this topic should face couple of facts even though they may not like it. For circuit racing there is just nothing better than a dry sump setup and you can sit here and talk all ya want about taking long left hand turns or rights for that matter. At the end of the day if this thread was to advise people in prioritizing there results based on there investments and time spent on there motors as well as how they use it, it would help 90 % of the people that read this thread and stop at page 30, and under. Prioritize the info and save time and money. It reminds me of the 90 -10 rule in life 90 % of the people making 10% of the money and 10% of the people making 90% of the money. It relates to almost everything in life. It even goes for hp goals. Wow. Funny how people react to just opions here. Im one of them.
Everyone knows that dry sump is the best and that modifying RBs to produce twice to four times their design power brings a range of problems - this thread is dedicated to overcoming the oiling problems for those who can't afford/don't need a dry sump and as far as I am concerned it has succeeded.
  • Like 2
  • 4 weeks later...
The more I read the more confused I get. And I can't seem to find what I'm looking for.
I have stripped down my RB26 now and it is being buildt as we speak. Parts I have is:
-Late model R32 crank with long nose
-JUN oil pump
-JUN oilpan baffle
-1.2mm oil restrictor
If I do this:
-Drill the return galleries to 10mm both in the head and the block
-Make the entry to the galleries smoother
-Mine's or Hi-Octane rocker baffles
And as for the catch can:
-AN10/12 from rocker cover to top of catch can
-AN10 from top of catch can to oil pan. (ABOVE OR UNDER OIL LEVEL?)
-AN10 from bottom of catch can to oil pan. ABOVE OR UNDER OIL LEVEL?
Have I gotten everything correct then for building a RB26 that will last?
I'm driving the car manly on the road, but when I'm on the track I drive pretty fast. So I'm building it as a trackcar.
EDIT: Spec will be stock rebuild bottom end with all balanced internals. 6Boost manifold, BorgWarned 7064 EFR .92AR turbo and stand alone engine management system. Aiming for around 340kw at the flywheel.
Edited by SSM
^^^what he said...and you need to vent your catch can preferably to the turbo intake. if you find you are getting oil in that line (I didn't) you can insert another catch can or a Nismo type oil/air separator in that line.
Well, im willing to do some stuff I've never tried before as well. I just finished up a head i did myself. I am now thinking of drilling out/open up the oil return hole out for better flow. And the ones at the rear of the head will be cleaned up. Any suggestions here. Nothing was wrong with this motor. Im doing a full stock rebuild. But will push the motor with single turbo, 550cc injectors power FC. the bottom end will be all stock but have ACL race bearings new rings restrictor stock new oil pump, n1 water pump. MLS head gasket.
I have made up my mind to fix my gts4 chassis that i crash. I have attched a photos of the head and the chassis im fixing myself. Sorry if im of topic a bit here but this is an opportunity to see if all of us can collectively make some decisions to control the oil issues in a rb26. I have also repaired my damage Racefab oil pan. Photo attached as well.
Suggestions.
Use a fairly blunt drill bit.
Different returns may need different size bits - I cant remember one of the rear ones gets awful close to the spring seat.
Clean, clean and clean it afterwards.
Don't bother with the Mines baffles.
Put some dash fittings in the sump for breathing/oil returns.
does anyone have any pictures of the inside of their catch can? it would be good to see what chambers and fillings people have used when doing their catch cans.
Build it like a cyclone.
https://www.google.com.au/search?q=cyclone+oil+air+separator&safe=active&sa=X&biw=1600&bih=719&tbm=isch&tbo=u&source=univ&ei=iZNSVYb-NMi3oQTsvICYAQ&ved=0CDQQsAQ
I've been researching catch cans for a while and you have now convinced me to try the E39 M5 oil catch cans. I am buying a right and left one to try out of the valve covers with returns to the pan for my car. They are cheap enough to try at $40 USD shipped and seem well designed.
I'll keep everyone updated.
Here is what they look like.
http://www.realoem.com/bmw/enUS/showparts?id=DE93-USA---E39-BMW-M5&diagId=11_2653
Edited by HarrisRacing
Looks nice but no idea where you are going to find the room to fit two of them.
They are relatively small. http://imagizer.imageshack.us/a/img19/5919/oilug.jpg
I will start with just one of them. It will be returned to one of my oil pan fittings (I welded 2 -10 AN fittings into the left side of the oil pan) and will catch any "slugs" of oil that may come out of the valve covers and drain the oil back to the oil pan. I will then pipe the vapor outlets to a standard catch can and have my turbo piping pull off of that. The other oil pan AN fitting will be routed to the top of the catch can as well for imporved breathing. I'll start with just one of these, but we will see how it flows first. The second will be added later should I decide to change.
This is basically a cheaper replacement to the NISMO oil separator. I will still use a catch can, but this should knock out the majority of any oil slugging issues and return to the pan.
As far as leaks, it's plastic and has only one joint at the top of it. I am not installing a BMW engine ;)
Be very interested to see what is inside the thing if at all possible. If it is straight forward would be easy enough to knock one up out of aluminium and fit it in the place of the Nismo can - the inside of which is just a deflector plate, basically.
http://i1095.photobucket.com/albums/i467/mach-schnell/M5OS.jpg
http://billpentz.com/woodworking/cyclone/cyclone_plan.cfm
Basic cyclonic separator design. Seen them used and designed in the oilfield as well.
Marcus check out my build thread, this should show you what you need to do to your block and head to improve your oil return- http://www.sau.com.au/forums/topic/414784-shootas-r33-gt-r-rb3026/page-4 get a long shank die grinder bit, makes it a lot easier to get right in there.
  • 4 weeks later...
updating my twin tank arangement
just a bigger second tank located where the washer bottle is
same drain and same breather setup
will be turning on the scavenge pump as well
also opted for a accusump as i have noticed drops in oil pressure on left handers at 1.3-5g
    • Here's a boring history lesson on number plates People want illegal spacing to make their plate more readable, if mine was J2X BK, anyone who knows about the car would see that its spelling JZX. Years ago third party plate manufacturers could alter the text to make it look like something else, nowadays the computer software is locks that ability (well, ours does at work) Up until 2001 the first letter of a number plate represented the year of the vehicle, for example A would be 1983. (pre 1983, the format was backwards, so the year letter was on the end). Followed by 3 random numbers and 3 random letters. Things started to get complicated at the end of the 90s where T and V were 1999, W and X were 2000 and Y was early 2001. From 2001 they introduced a new 'layout' where the first two characters are letters, this represented where that vehicle was first registered in the country. The letters corrosponded to a region in the country. Some regions had a large number of codes, where as some only had a couple (despite being large in physical land size) Next are 2 numbers to indicate 2000s. So it went from: Y (March 1999 > Aug 2000) 51 (Sept 2001 > Feb 2002) 02 (March 2002 > Aug 2002) 52 (Sept 2002 > Feb 2003) etc etc When the 2010s got here, the numbers changed again, going up by tens 10 (March 2010 > Aug 2010) 60 (Sept 2010 > Feb 2011) When the 2020s arrived it went to 20 (March 2020 > Aug 2020) 70 (Sept 2020 > Feb 2021) etc As for personalised plates, you're not allowed a registration that makes the vehicle look newer. Take my 110 for example, its a 2004 car so I can have any available plate upto 04. I can't have a 54 because it was manufactured in August 2004. Which allows me to have a J plate, because its older (if that makes sense)
    • Mount some of these on your dash? https://www.greddy.com/products/16001720
    • Given you're running a 2.8 and my 2.5 is not really like for like, I suspect there could be a bit more timing you could give it. What is the kW yield per degree you're putting through it? Here's my E85 map to give you an idea, where it was I could still get another 3~4kW per degree thrown at it.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
