  • Replies 351
4. Friday 10th November - Eastern Creek
Cost - $120
Require - CAMS L2S
Limit: - 30 places (first in best dressed)
Please fill out the following disclaimer before coming to the event.
http://www.eastern-creek-raceway.com/pdf/I..._Disclaimer.pdf
Guys, feel free to download the form, but please do not send to ARDC. PM me for a fax number to send it to and i will compile them all and forward to the ARDC in one go. This will ensure a central point of contact and i will be responsible for ensuring your entry is confirmed. I would rather avoid the situation where individuals are calling them and seeking confirmation of entry.
We are also looking to perhaps get payment before the day so that in the morning all we have to do is check off names and get wrist bands. Anyway, plenty of time to sort out the detial, but for the time being please dont be sending anything direct to the ARDC.
I "may" be interested in going on track depending on what is required. Could someone put up a summary of what is needed in the first post please. Is it an L2S licence and if so costs for it please?
Thanks in advance people :wave:
lol @ long ass straight at wakefield :thumbsup: Holy shiiit... good thing I upgraded my brakes :)
Umm, thats Eastern Creek, and turn 1 is 180-200km/h, so you only have to wah off 40-50kmh/h, its turn 2 thats a worry, and even that is nothing compared to the stops at Calder and Sandown...basically Sydney tracks are easy on brakes :yes:
Thanks in advance people :thumbsup:
*sigh* - why don't you read everything in the first post again.....
Eastern creek looks like lots of fun!!
Wonder whether the car will survive all this before the new engine goes in... mmmmm....
oh, and did I read somewhere that you were contemplating getting rid of all your parts for your big build Troy?? If so, PM me...
*double sighs* I can see that Wakefield offer their own type of licencing so no Cams required and I see an LS2 is required for Eastern Creek. However I dont see where I get an L2S from nor how much as per original post.
Great work Snows & Troy - this is shaping up to look like a fantastic event :)
Hell - even I might venture trackside!
BTW: Alan - once you have a CAMS L2S you need not worry about other forms of annual licence.
Yeh its on the way from Wakefield to Sydney...kind of. Stop at Stanwell Park for a bbq and swim, then drive up the new coast road and through the National Park to outskirts of Sydney southern suburbs. Should be fun :(
NOW THATS PLANNING :P
the nasho run is one of my all time favs :O well worth it ;)
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
