You are missing the fact that in victoria you are guilty untill you prove you are innocent, might sound a little sceptical but when you look at things like an epa notice for noise and emissions, they make you prove your innocence, if you dont prove it your automatically guilty (if you dont get it tested and cleared you get fined), the cops do what ever they like and its up to you to prove they are wrong.
And if you prove them wrong, you will most likely still have to pay $$ lol.
$43 for a noise test........
And if you get a major the dollars and time pile up............
How else do you think the government makes any money? considering they have sold all of our utilities to private companies now. The government doesn't have any assets! So what do they do? Charge us more!
Anyway, perhaps we need to go back on topic? :D
cheers for that,
Q:
reinforce, bit of 1mm scrap with same hole drilled on tacked/ stitched welded on underneath or exhaust tube type reinforce ?
wondering if this would be a common thing cops would defect and rwc would pass in the same state....
thanks
1mm won't be enough. Some small steel reo bar type thing will be fine.
Once you get defected, then get it engineered. I see no value in spending $600 on engineers for a hole like that until you get caught... BUT... if you reinforce it, show the cops, you might be left alone and never have to worry about it. IF you do, you've already done it and it's a simple fix (engineers).
I asked Nissan what the clearance should be and they said "100mm". So I'm not sure where this adage/myth of 'height of a Coke can' comes from?
Standard Coke cans are 130mm unless they are referring to mini Coke cans.
A rule of thumb is to check every thing you read on forums, a lot of it will be right but if it is wrong it's your arse in the line, I have seen lots of wrong advice handed out as a fact, really makes me wanna kick those people in the nuts!
hey guys got defected today :( thats all good .......... just he took pictures of catchcan (aftermarket drift brand) and didnt like how i attatched a breather to the end of the hose. and my pod filter......so my question is when they take photos...what is the purpose? are they going to investigate it? decide to epa me? just curious it was a highway patrol and he knew a lot of things....
Catch cans must be recirculating, properly made catch cans, or oil/air separators (which is what they are there for) will do the job fine when plumbed back.
Edited by W0rp3D
Take photo's as evidence of the mods.
You will get an EPA in the mail most likely.
well i got a epa in the mail today emmissions and noise.. fml..
gonna go test it see if i pass with upgraded turbo(gt2876r), r32 gtr injectors, z32, dr drift remap.. everything else is stock ....not worth it?
lol definitely won't pass.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
