  • 1 month later...
  • 1 year later...
  • 5 months later...
  • 6 months later...
Almost 8 years on plain cheapo $20 (when on special) Gulf Western Synx 3000 10w40 oil.
Still drives fine and no noticable oil consumption inbetween servicing (every 5k to 10k km or 6 month)
Since owning a modified BMW, that's amazing lol.
Edited by Mayuri Krab
Insert oil brand
  • 5 months later...
  • 3 weeks later...
hey guys whats the preferable oil filter to use on hp rb, i have been using genuine nissan for years but wondering if theres anything better ? i also use penrite ten tenths 15 w 50  and e85 which seems to work well with e85 fuel.
  • 10 months later...
Just bought me a r34 gtt, owner uses Fuchs 20w50 dino here (whaaat) however, pressure and temps are all fine, never exceeds 110c picture is attached.
So might change to 15w50 fully synthetic or whatever synthetic, whats the thought?
OMG fuchs just bought out NULON AUSSIES  should only buy Penrite...pass it on   f*kc the germans!!!!!!!!!!!11
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
