My requested for a 400R build with a big fark orf BW9180 turbo has already been declined :(
Seems the single turbo conversion is ok'd on a case by case situation.
The 13B twin turbo RX7's are allowed a control turbo and manifold, good for 300 KillerWasps on E85.... that'd be fun :D
^^^ Was just chatting to Snowy. We figured it might have been around the RX7's as the twin sequentials on them are a bit ghey apparently.. ie unreliable. Could make an FD a pretty good thing for EM I reckon. Who do we know who has an FD?? :)
An bris, thats twice this morning I have been bashed by a big brown monster with a stick... I'll try it neat next time chased with an invalid. :)
Looks like benson wanted to make his rental more compdeditive :P
I thought the 102 would be for the na cars that don't get a power gain from e85 (lambos), I recon the rx8 will still run e85, and still be unreliable
Lambo's can't run 102 though (and they have also been banned from running E85 now. Well - the R35's have. And I'm pretty sure that 2 of the podium getters were running E85 last year as well).
Its only LMS and MS cars that can run either Elf or E85. SS are limited to 98RON.
But I'd be willing to bet a can of coke that Mazda will run the Elf.
how long till a r31 gts-r becomes a classic?
LOL, yeh when are people going to run cool cars. By cool I mean old, unreliable, slow but loud cars. :whistling:
If someone wants to build a Sierra I know the perfect car to build up as it already has all the good parts from either RS500, Grp A or aftermarket :)
Serial, I reckon the 31 rear suspension setup is just too shit to be any good on a Tarmac rally. On circuits you can set them up stiff to alleviate the appalling camber changes, but a rally car, esp a two wheel drive one, really needs to be pretty supple.
    • Reading through the engine service manual their advice is do a cylinder balance test. Unplug one injector at a time and see if the idle drops a consistent RPM. You can also do this using a Consult cable which is easier. They also call for unplugging the power transistor, then with the engine off and the fuel rail unhooked from the manifold verifying that you have good fuel flow (even injection, no dripping/leaks, etc) when you twist the CAS by hand. Also verify the spark by pulling the spark plugs and allowing the plugs to ground and turning the CAS by hand. I would also start doing the sensor checks and idle valve checks in service manual. Make sure the MAF tests reasonably, the intake air regulator is sane, etc. You may have to get new spark plugs.
    • This sounds very old of me, however since buying the Tiguan shit box, my view on shit boxes have changed.
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
    • This coupled with 6-9 speed autos with ridiculously short gearing is why these modern shitbox cars always seem so fast off the line. If it wasn't for those things, Raptors would not seem fast. The problem we have is there is a driveability gap between a more gentle take off and a wheelspinning sideways launch. The difference between ankle flex required to achieve one and ankle flex required to achieve the other is about 0.5°.
    • Yeah I think I'm also with the opposite here. It's 'hard to keep up with traffic' because in the real world I'm accelerating with 15% throttle and they are pinning it. It feels like I'm being an overt dickhead at anything above 15% throttle, so the car sounds like I'm being an overt dickhead to keep up with/get ahead of traffic when I'm really just trying to drive with traffic. There would be no issue 'keeping up with traffic' if we used the same level of throttle input/aggression to drive around. People really do just drive around with their foot nearly pinned in econoboxes.
