Rb25det owners are the back bone of this community as well as my workshop. I've purchased a better conditioned R34, it is fully stock, and I will be modifying it all over again. It is a good opportunity for members whom might have missed my previous build and hate to dig out pages.
I will sum up lists of parts I'm ordering and label prices and shop names.
For members inquiries about the Rb26dett, Using unopened engine, I don't think its possible to get much better response using the simultaneous twin system. For a single high mount, I can get you pretty close to the -9's response while getting -5's power.
For RB30det engines, It varies, I'm getting all sort of engine CPRs depending on whom its built by. Generally using a Rb25det head and a NA VL 3L Bottom you end up some thing like 8.3:1. You can use our ATR45, ATR45SAT or ATR45SS on those to get very good response and decent power output. I'm keen on Rb30det results also, PM if you need a turbo for it, I'll be more then happy to trade discount for results.
  • Like 3
As for shopping basket, list below contain prices and names of where they came from.
Car is fully standard. Goal is 400rwkws E85 using a single bolton internally gated turbocharger, Prices are quoted in RRP by perspective suppliers.
1. Xtreme Pull type Cushion button heavy duty clutch KNI25003-1C. from Race brakes : $891
2. Splitfire coil packs from Just Jap: $589
3. JJR's stainless steel R34 3inches turbo back exhaust system: $770
4. XSpurt 1000cc top feed injectors from Injectorsonline.com: $750
5: Walbro 470 L/H fuel pump from Injectorsonline.com: $200
6: Adaptronic R34 Plug in ecu: $1499
7: Havoc Fabrication Front mount cooler kit: $850
8: 4 inches metal induction pipe made by few silicon hoses and a pod: $100
9: Complete dyno tuning from Chequered Tuning $750
10: I will be using my own ATR43G4SAT internally gated bolt on Turbocharger. $1250.
Total spending: $7649 Plus about $500 in labor it works out to be $8150.
This will be a ball park figure and parts that you will be looking at when comes to performance mods. I will be updating as project progress.
4. XSpurt 1000cc top feed injectors from Scott Fisher: $750
5: Walbro 470 L/H fuel pump from Scott Fisher: $200
A 3 inch JJR exhaust is perfectly fine.
A bit of die grinding on the dump flange and its perfect.( if using standard 6 bolt )
3 inch for 400? Errr...
Golf ball and garden hose.
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
    • Yes it is ATF. I quote @Duncan "it takes a good synthentic auto trans fluid like Castrol Transmax Z" It's not a diff. It's a transfer case. Totally different thing. Yes, fluid will come out the sender hole. No you do not really need to drain it. Just pull the old, quickly poke the new, clean up and top up. But realistically, you should probably take the opportunity to change it anyway.
    • Hey all. I’m looking on replacing my speed sensor on my R33 GTR. Will the center differential need to be drained, and if so, the center diff uses ATF fluid D? I found information on the transmission, front diff and rear diff. Can’t find a for sure answer for the center diff. Any help will be greatly appreciated.
