Its been a while seeing the Greedy copies around with few good working examples. So we've imported few. The first one I'm interested to try is the TD06SL2 in 10cm with T3 flange turbine housing running our re-trimmed 20G Billet compressor wheel.
It has been pulled apart and rebalanced (tolerance is about twice higher then where I normally set them to, its now corrected). to make sure every thing can work accordingly.
Those turbos are externally gated only and available to every one for $850 including GST and 12 month local warranty. I will refer to it as the EXGBTD06SL2
Looking through the turbine design, it appears been able to make plenty of torque, but I'm not too sure about response. There is also room in FNT turbine upgrade. I might be able to adapt internal gate onto it with the Nissan 6 bolt flange.
Its been a while seeing the Greedy copies around with few good working examples. So we've imported few. The first one I'm interested to try is the TD06SL2 in 10cm with T3 flange turbine housing running 20G Billet compressor wheel.
Nice.. Why not call it HG TD06SL2 (Hypergear TD06SL2), thats less confusing..:teehee:
I take it you dont follow the kando thread cause this is what I have been saying for months... :thumbsup:
If you want a ride in my car just PM me man,...clutch is slipping a little atm but should be rectified soon..
Car is very nice smooth to drive
@ 1 bar boost, with 6 month old fuel that was still sitting in my tank.. :yes:
Yea I found it. It looks too linear thou, I pictured it would do some thing that. I should be able to add in lots of meat into the mid range with FNT turbine.
Where abouts are you based? I'm testing the ss1pu again Friday afternoon which we can swap cars for a test drive near status or unless if you are in the North side.
There is no midrange because its at one bar, lets wait and see what the 22psi graph looks like. Hurry up and get that clutch in Artz.
I'm interested to see the results with the stock 5 bolt housing. Get on to it Stao. :thumbsup:
An M35 Stagea rear may work well too... :whistling:
yeah cool, Im near dandy..I probably cant get there till about 6 though will you still be around?
I'll be there 7pm starting the tune on Friday. Its more of testing the wastegate actuator and a newer housing. Should all finish in an hour so its all good if you like to come in around 7pm and see how the tunning goes.
I will trail some externally gated ones including the SL2 and T67 combinations with billet wheels and do some modifications no housings from there.
At this stage we can supply SL2 units in 10cm T3 turbine with billet compressor wheel.
Anyone got ideas about what I should be saving for next to get a bit more put of the turbo
Also how do I get rid of the ping around 250kw
Do things like oil coolers keep the overal engine temp down to prevent this?
Water Meth Injection ;)
better (more efficient) intercooler
Freer flowing exhaust
there are a few things you can do to squeeze every last drop out, but $$$ per HP makes it rather expensive
Save for a plazaman cooler. Or a custome side mount manifold
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
