how ever I'm recently seening some 260rwkws results based on 15psi from Toshi's remaps using stock injectors, afm and ecu.
Sounds like a high number for stock injectors and afm.
I wouldnt trust a number like that
Magic. Trust in magic!
Never the less, injectors, AFM, ecu. Should see 240-250rwkw on 14-16PSI on a 21U.
I call high dyno reading @ 260rwkw on standard fuel system without a high pressure regulator or something...it'd be absolute knife edge. Back in the day it was always ~230rwkw max for the standard gear, what's changed?
nothing
just one guy claiming he can do more
Hello, ive got a r33 s2 and wondering what is your best hi-flow turbo for response, only looking to make 220-250rwkw, stock internals with associated mods. Its a daily and would be looking to run between 10-14psi max.
cheers
Agree with Tao, standard high flow would be best for that power, though I think you should consider going the extra step and getting a hybrid SS1PU...it won't be any laggier than the high flow and will give you some extra head room down the track should you want to run more boost. My R33 is a daily and the SS1PU is great in that role.
Toshi mentioned some thing to spool turbo without fuel to increase power. I don't deny or fully understand his concept but the results are extremely tempting. I guys it would be good of toshi can enter some input.
I dont fully understand anything Toshi says, anything he says appears in text boxes and my eyes get an error saying 'language not installed'.
FWIW though, I trully believe theres more to tuning then adding timing and pulling fuel. I know his theory is that the stock injectors are sensitive to pressure, getting choppy above 15psi, so i would say increasing rail pressure is also a shitty idea if hes right. The combo of stock FPR and stock injectors run at 15psi seem to be Toshi's 'sweet spot' for tuning.
Forgive me for thinking aloud here, but injector spray pattern would have a lot to do with the burn and in turn would change how effective the burn is. By 'rule of thumb' 370cc is 370hp on an RB25 = 277kw. With some deduction the ability to hit 260kw on a 'happier' dyno is definitely there.
Or we could just keep screwing boost into things coz thats all that makes power. T25 on 40psi runs 10s (till destruction).
That's 370 at the flywheel though...which is around 230-240 atw ..
I don't see how it is when i know of cars doing 400rwkw on 555cc injectors.
400kw=540hp. Allow 15% for "happy dyno fun times" and there's your drive train loss.
HEAVILY MODIFIED 300ZX
ENGINE BUILT BY UAS
  • Custom GT28RS turbo's.
  • Extrude honed exhaust housings.
  • Plenum and 55mm throttle bodies.
  • Custom UAS Cams
  • Adjustable cam gears.
  • Porting.
  • ACL pistons
  • Custom top fuel rail.
  • Nismo 555cc.
  • UAS Twin pass radiator.
  • UAS FMIC.
  • Microtech Computer.
    This is a car i looked at buying for some time but the price was just too high. It was at UAS a fair bit.
Its not happy dyno.
I tuned S15 on same dyno (MX5 mania dyno) and I made 198kw.
http://www.nissansilvia.com/forums/index.php?showtopic=497151&hl=toshi&st=0
He went to unigrup dyno day and he made 207kw on unigrup dyno.
You can ask him over PM.
ENGINE BUILT BY UAS
  • Custom UAS Cams
  • Porting.
  • ACL pistons
  • Nismo 555cc.
  • UAS FMIC.
ED"*"*
Ok I stand corrected, now show me one RB.... :glare:
Its not happy dyno.
Toshi it will he good if you can explain the method (doesn't have to he in great detail) about how you can make 260rwkws on a stocky high flow and factory injectors and why most other tuners are straggling to pass 230rwkws.
Just to clear things up i will run one of toshi's highflow r33s on the dyno for free. If it is possible it would be awesome.
Tao we will be trying the new nozzles(bolts) on elusivity's ss2 next thursday. Are there any tricks to this ?
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 😉. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 😍.
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 🙏 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 😉. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 😍 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
