3. Are aftermarket intake pipes needed for any of the above? Would prefer to stick with the stock rubber hoses.
Basically yes. Some people get away with it, most don't at those kinds of power levels (they warp/ or suck shut).
Beyond that is that you will get better flow/power with an intake pipe.
Edited by jjman
Are the standard rubber hose reinforced with a spring inside ?
If the hose collapse under load you can say goodbye to you turbo and possibly the engine as well.
The turbo will overspin dangerously to maintain target boost pressure, possibly getting in the surge zone, and it will leak really badly from the compressor seal leading to knock.
Hard pipe for the intake is always a good thing.
No, they collapse on a hot day with anything more than stock boost levels when using a factory airbox or a semi restrictive pod filter
I'm using a 3 inch metal induction pipe that is clamped onto the factory air box.
OP6 high flowed turbocharger. Standard turbo profile:
Here are all the results labeled:
I was unable to run any more boost beyond 22psi with internal gate. How ever had no issues doing 24psi external.
Power wise compare internal v external was 25kws. note the back to back run on 19psi.
I'm very confident that this high flowed turbocharger will do 385rwkws on the Brae high mount manifold externally gated.
Even tho this is a remarkable gain from modifying a factory exhaust manifold. How ever, running the same turbocharger with a proper high mount will gain bit more power and much better top end torque.
The gain over internal gate by fitting external gate on factory exhaust manifold in this case is: 7.24%
While the gain over internal gate by fitting external gate on turbine housing is: 1.5%
Reference of Internal gate V external gate on turbine housing:
Solid red = internal gate
Dotted red = external gate off turbine housing
And if any one wants their manifold to be done. The cost for doing so is $300 and our 50mm HPVA gates are $350 in additional.
Apart from the turbocharger and gate.
I have:
450L/H Fuel pump
1200 cc injectors
Adaptronic plug in ECU
3inch turbo back exhaust
600x300x75mm cooler kit
My engine is forged with CP 1:9 pistons, Super tech valve springs and valve sets.
Your stock engine is fine for up to 20psi mark which is about 350rwkws on paper.
To build this turbocharger I will need a donor turbo from a R34 with a OP6 rear housing.
Back to the high flowing topic. The current profiled OP6 turbocharger should be pretty close reaching 300rwkws on a internally gated setup with pump 98 Fuel. And good enough for 350rwkws working with a proper high mount externally gated setup running E85.
Are these silicone intake pipes any better than stock? or will they still suck shut on a highflow @ 200rwkw
http://www.ebay.com.au/itm/261146335739?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649
At 200rwkw I doubt the standard one would suck shut. That silicone one wouldn't be much better than standard I bet. Possibly a bit better but if you want to run higher boost I'd like the piece of mind of a solid intake
Edited by Marcus89
Stock induction pipe will suck shut.
You can make a hard induction pipe out of couple of silicon joiners like:
http://www.skylinesaustralia.com/forums/topic/261613-hypergear-hiflow-service-continued/page-89
or you can pm M35scotty for his induction pipe which allow factory bov and breather plumbings.
http://www.skylinesaustralia.com/forums/topic/261613-hypergear-hiflow-service-continued/page-288
I had no trouble whatsoever with the R34 OEM rubber intake pipe @ 199rwkw. Then again, I think a highflow should take you beyond 200rwkw fairly easily?
I'm now running Scotty's intake pipe @ 257rwkw, it looks good and works great.
Thanks guys.
The stock one can start to collapse not much over 200kw, but it only happens when the manifold is glowing. The lower section of the intake isn't protected well from the radiated heat and it softens the rubber/silicone. You can slide a piece of 3 inch stainless inside the corrugated section to help, but the lower bend will still suck in at around 250kw from my experience. Changing to an alloy intake solves most issues, but it would need the BOV return and breather fitting to remain legal.
Thanks guys.
yeah, similarly mine made it to 207rwkw. but then at 220rwkw it was sucking shut intermittently. Bitch of a thing not knowing when ur going to get power or if the power is going to nose over above 4500rpm...
just the replacement alloy intake pipe alone freed up another 8rwhp.
I looked at compound system few years ago. The original compound Diesel system for a truck which is by turbocharging a smaller turbo with a large turbo, Not sure if it would work on a high performance petrol system.
There are two things doesn't look right for petrol.
1. Exhaust side
Exhaust manifold mounts to the exhaust housing of the smaller turbocharger.
The outlet of the smaller turbocharger's turbine housing goes to the inlet of the large turbocharger.
2. Induction side
Outlet of the large turbocharger force feed smaller turbocharger's inlet,
out let of the smaller turbocharger goes to the intercooler.
Put them together we have:
Big compressor of turbocharger two, with small turbine end of turbocharger one.
Unless there is a way which turbocharger one can increase its flow capacity to suit turbocharger two's compressor when needed. I think its going to make the engine pin.
Also if photo above is based on a RB25det using a Compound turbo system, then I think the SS2 Alpha have made better power band.
Other alternative for huge power with stock response is by using a welly tuned sequential twin system. I do have drawings to make that work and is probably the next thing on the trail list. Its going to get very expansive how ever, and I'm not sure how things might be fitted under the bonnet.
I looked at compound system few years ago. The original compound Diesel system for a truck which is by turbocharging a smaller turbo with a large turbo, Not sure if it k on a high performance petrol system.
1. Exhaust side
2. Induction side
Thats because the picture I posted was of a ebay t70 with a s15 t28 as the small turbo vs just the ebay t70. Went from 1 bar at 4500 to 1 bar at 3000. With better turbos it would be a lot better. Ofcourse the results arent earth shattering but what do you expect from a build made from bits lying around the workshop.
Compound turbo has been done many times on petrol engines and workes very well. Just ask kevin jewer how his 8 second dsm was spooling a 80mm BW Turbo by 4500rpm on a 2l four banger. An ss2 with an atr46 would be awesome. I will be going forward with mine as soon as my new engine is in.
Apologies in advance for bad spelling etc im on my phone :-p
Edited by Super Drager
I thought the 'best" way would be to have a turbo outlet force feed into a roots/screw type charger inlet, then the charger outlet into the intercooler.
At least in my crazy fantasy world
Not crazy at all. A guy on PF did it to an RB2530 in a VL. Absolute torque monster and massive power everywhere, even with relatively low boost setting on each of the blower and the wastegate. Large turbine housing means low backpressure, but blower means boost from idle, so response is stilll good.
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
