Brae Auto Fabs, Cost $1100. It is custom made to suit this turbocharger, and fitted every thing perfectly. You can find more details about this manifold in page 513.
  • Like 1
Stao can you tell me abit more about the new single you are testing? Since the N1 GTRs already has pretty decent turbos from factory, What are the advantages compare to the factory twins? Cheers
Well, I would like to reach optimum performance levels based on a particular type of engine that I'm working on. The goal of this project would be trying to maintain the factory N1's response while making alot more power. I have spent few more hours today making an custom spring holder for my external gate that packed 4 springs, the lathe have made this job so much easier :P :
Its now hitting boost cut without BC, which is either 17psi or 30psi depending on what Trent set it on :turned: .
I have also made some little changes on the turbine housing and made it run on oil cooled Ceramic balls. Drive ability wise, this is probably the best single any one's ever made for a GTR in its HP range. I rate it better then the stock twins.
Little footage of CBB turbocharger shutting down:
  • Like 1
the 76mm turbine, is that the one you where using in 21U hi flows or something ?, not op6/.82 hi flow?
did you fit that to my ss3 thing you did for me?
cheers
darren
Edited by jet_r31
The internally gated ATRSS2 (0.82a/r hotside) we ordered arrived late last week, is a nice looking unit and Stao supplied a few bits to make installation a bit easier. Busy times at the moment so it now looks like we're not likely to have it running until roughly mid November, but I will update with results. I'm quite looking forward to seeing how it performs :)
  • Like 2
cheers
darren
Yes the prototype is running the Steam peddle turbine, same as yours. :D
The Rb26dett engine has a long rev range so the turbocharger must be able to flow that extra bit of air. Evaluating using 60mm turbine, I've notice a huge surge of torque once the external gate opens, this is usually an indication of undersized exhaust end . The turbocharger will not last if left to be, and the engine will not be able to take much timing up top.
The steam peddle turbine worked nicely in mid top end, but I felt a short period of flat spot down low. With VNT nozzle ring and CBB cartridge in place, that flat spot is gone. The car comes on positive boost with a lite touch of throttle,and its pretty much driven on boost all times. I'm very positive with the up coming dyno test.
  • Like 2
this may have been covered already.
is there an option for a bolt on internal gate td06sl20.5g?
I love the progressivness of it on my 1j
so would like one on the rb25. but without the cost of another 1400 buck exhaust manifold....as much as I would like too..
TD06L2 range doesn't work very well internally gated on Rb25det. Std high flow performed better. SS2 is a better one that is engineered to perform internally gated on Rb25det.
I'm looking onto different turbo options for my rb20,
I would like to get 230-240rwkw and wondered if you are able to have a t3 8cm rear housing onto one of your td05 18.5's
or would and rb20 or 25 hiflow be better suited?
On pump fuel with reasonable response on an rb20
also do your turbochargers response change much between an rb20 and sr20?
If I remember correctly Stao already stated that a RB20 have the same boost threshold than a non VCT SR20.
ATR43 SS1 result @18psi :
rb20det225rwkw.jpgThe result is available in this exact same topic, you just need to go to page 1 and search in the summary, or search on Stao website, or search on the RB20 dyno thread. Plenty of information everywhere. :)
What do you call reasonable response ?
For some full boost @5000 rpm is fine, others begin complaining when they have to wait for 2000rpm for the torque to come.
Thanks for answering that romain, I have read the rb20 dyno thread. Also ive followed the this hypergear thread for a few years.
At the moment my 32 has only boltons and stock turbo at 1bar and the amount of useable torque this has makes it a very brisk car, but out on the open road 80-100km plus it feels (relatively) slow.
I really want more up top without losing too much down low
The ATR43SS-1, and 1.5 are great turbos for the Rb20det, as it is actually running a T3x turbine housing that has been modified from a T2x. That we can run them with our 55mm turbine wheel using either a 68mm billet compressor or a 71mm cast compressor. We usually see 20psi around 4200RPM that makes any where from 220~250rwkws. If better response is preferred we can also build it in 2860-5 specifications that would be making 20psi around 3900RPM that makes around the 210rwkws mark.
To high flow factory RB20det turbocharger, for best response it will has to be a G1 profile. and that will be making 20psi around 4000RPM with around the 200~230rwkws mark depending on how much boost is pumped.
You can compare response using the reference from our SR20det evaluation based on the runs that has VCT turned off. Alternatively, if comparing to a RB25det result, the difference in response is about 1000RPM.
Some updates. This is the twin turbocharged LS1 VK from Chequrered Tuning that I've recently built the turbochargers for:
Final result of 523rwkws @ 3.8psi. Wondering whats 400rwkws by 4000RPM like? :D
Its heading for WTAC comming. will upload videos once available.
  • Like 2
    • Yeah pretty impressive hey, good to see quality products not over-shooting their prices. That's what drew me to buy the hypergear turbo, just a shame I've never got the chance to see it in action
    • Thank you GTSBoy and MBS206 I have done the compression test with the motor out of the vehicle, reason for the test was to see if I needed to remove the head and do rings etc while its out. I'm in the process of respraying the vehicle and tidying up a few things. Story behind it all is I've just purchased the skyline and it was running when I got it, never drove it on the street though as I wanted to pull it down and do it all up again before registering it. the gentleman I purchased it from told me the motor has a forged bottom end and has a decent tune through it but I was going to pull the sump off anyway to see if it is a forged bottom end. that's why I thought id do a compression test beforehand.
    • Man, I'm kind of amazed that the price of the turbo has not changed in 7 years. Everything else is inflating beyond reason, but not this? Good on Tao / hypergear I guess? Anyways, good luck with the sale!
    • I'm selling my brand new, in the box, never used Hypergear ATR45 - and I had some additions I paid for a few yrs back when I purchased it. Never ended up having the rest of the money to add all the mods at once, so I just ended up slowly selling each part. I originally had it internally gated, with the dump pipe, however I found it was incompatible with what I was going to use it for, so I contacted (I think Ken) from Hypergear, and he and I messaged back and forth & he got me to ship the turbo back, where they modified it & made it externally gated, and gave me the 5 bolt dump pipe attachment for custom welding. (Photos below) This turbo like I said has never touched the inside of an engine bay, it's completely brand new, never used, been sitting in the same box it arrived in, covered in plastic & all. Below are the photos of it: And while the guys at Hypergear were making it in-shop, they sent me some photos of the process: I'm looking at selling this just because I'm in need of the money right now, and don't have plans on modifying the 34 anytime soon - and from reviews & peformance sheets, this turbo had amazing results back when I was researching. The turbo was purchased in 2018 for $1.9k, with the mods I got added on. Looking at the website now, for the same turbo they sell (ATR45SAT), with the current addons it adds up to $1830 for the turbo Current addons included: - Bolted dump adaptor - Ball bearing CHRA - Braided oil feeding line So I'm looking to possibly sell it for around $1800, with shipping included in that 1.8k, It cost me around $120 to ship - so yeah thought I'd throw it out there and see if anyone was interested in purchasing. Cheers!
