My Hypergear SS2 external version in action at Wakefield Park just this Tuesday.
Track was pretty wet and I was one of two cars on the track at the time - thought I would have a little fun :)
  • Like 1
Looks like you had some fun out there. You ran the 1/4 yet johnny? Be interested yo see how the ss2 went :)
Need to sort out my voltage drop at high RPMs, it's causing the miss fire (I'm lead to believe).. been only running 1.3bar instead of 1.6bar
Haha I see granny shifting
not doubling clutching LOL...
  • Like 1
Okay so after going to WTAC and FD Asia on the weekend and hearing the RX7 running 13B+T51R I am in love!
Thought you would be the best person to ask stao, what exactly makes the massive turbo spool/whistle sound that the T51R is known for? It sounds so good haha, you should make a one off SS2 for me that sounds like that!
ex gate sounds good johnny!
  • Like 1
T51R, the maximum I've seen is 646rwkws on E85 Fuel, that was on a LS1 V8 motor. Our ATR46 is actually an larger turbo but not suitable for any thing smaller then a 4L.
I can drill some holes on the comp housing and make a SS2 sound much louder :D
It will becomes laggier, So you are trading turbo response to turbo Noise. lol
I can make some plug to go with it that you can rise or lower the vacuum cleaner volume, and adjust the amount of response for the amount of noise.
It should be super responsive on your 3L now, So I guess it doesn't hurt turn on full volume.
TAKE MY MONEY TAKE MY MONEY!!!!!!!
I want :)
A turbo that makes poofy noises? :/
lol.. and?
I know you hate my flutters/the sphincter of the universe t u r k e y noises & gate... but it's delivering an experience :)
  • Like 1
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
