Yes that would be the anti surge slots that are plug able if you don't like the sound or lag. usually be seeing 300RPM of differences in lag.
Congratulations to John Rico taking 1st in Sprint class of WTAC Rear wheel drive. Fastest lap of 1.41.44
310rwkws on Standard 21U high flow with high pressure actuator on E85 fuel 19psi.
  • Like 3
also keen to see how an ss2 made to sound like a t51r coming onto boost goes.. could consider getting it done to mine i could deal with the extra lag... man that things just pure ear porn!
you guys realize that a T51R sounds the way it does because....
well its a T51R and not an ss2
maybe tao can build you an exact replica and you can have gay as rainbow noises
If you actually read my initial post my question was why does it sound the way it does. I asked as I thought that stao would know seeing as he builds turbos for a living.
Also it's beyond me how anyone can not love that sound haha. If I can use my SS2 (which I love) and also get it to sound more aggressive then what's the issue? As stao said I'm running an RB30 bottom end with what most people would consider and undersized turbo, and I don't really give a f**k about extra lag (within reason)
Please understand that different people enjoy different things and not everyone has to share your viewpoint
"that sound' is always going to sound bigger and better on a bigger and better turbo for sure.
The HKS 3037 Pro also makes that sound but in a less powerful way than the T51R because, well, it is a less powerful turbo.
If you get the surge slots in your turbo it will probably be like this. Decent and what you are after, but it is never going to have that 'end of days' sound like a T51R spooling up.
eg this vs this
3037 https://www.youtube.com/watch?v=PzN5uolGKII (0:24)
T51R https://www.youtube.com/watch?v=sU5YT2jqcmA (1:18)
  • Like 1
1000 CC Injectors
450 LPH E85 Fuel Pump
Hypergear CT15B high flowed turbocharger internally gated
Tuned on E85
Standard Automatic
309rwkws on 20psi
Read more: http://www.jzx100.com/forum/topic/15403-about-high-flowed-ct15b-turbochargers-293rwkws-20psi-p98/page-12#ixzz3HjLIog9K
I'll try and find a video of my HKS GT2835KAI, it had a surge slotted front cover and whistled like crazy without ever going terribly fast. Would even whistle going around car parks. Sounded pretty cool, just a shame it never lived up to the old Pro S
The KAI had a removable 'snout' with the surge slots, I ended up getting another one made without the surge slots to see if it improved anything, think it may have improved torque slightly, noise was still there because the bolt holes for the snout were still in the front of the snout, had just lost the surge slots between them. Odd little turbo that one. They should have stuck with the Pro S
Some photos of a pair of our high flowed Greedy T517Z in 10cm Rear for a GTR. Now fitted with our SL20.5 CHRAs and enlarged 36mm internal wastegate. They should be now good enough to reach 500rwkws+. Will update results once tuned.
  • Like 1
SS15 is in 68mm. For those high flows, one of them would be good enough for 380rwkws on a Rb25det externally gated E85. They would be similar to having two TD06L2-20Gs with alot more power.
    • @GTSBoy Ok so that was the shops problem...they showed R33 rotors on R34 page and i did not know 296 do not fit(and are for R33) Yes i bought "kit" with rotors and pads. Pads are ok(i have GTT calipers front and rear). They have some 324mm but no 310mm. So i dont know if they would fit. I have 17inch LMGT4s So another question. Can i fit those in the rear or they are just "too" big for that?
    • I started removing the tank a while back with the intent to give it a proper clean. Got to a bolt that I couldn't undo completely due to a diff being in the way, so just said f**k it and siphoned the gluggy old fuel out and called it a day. Looking it the tank it looks less corroded than the one in the pics for that billet hanger from Frenchy's anyway. Isn't it the fuel filters job to worry about this stuff? I scraped off most the crusty shit of the hanger but will give it another go before reinstall coz maybe the fuel and return pipes are also full of gunk
    • Pretty sure it is a common fault. I believe this is the only part you need, but don't quote me as I don't have a V36.  I also believe it is a bit of a pain to change and the device needs to be encoded to the car once it is replaced, so may need someone with the right tools. Buy Genuine Nissan 48700JF00D (48700-JF00D) Lock Set-Steering. Prices, fast shipping, photos, weight - Amayama
    • Pads for R32 GTS-t, R32 GT-R non V-Spec (Sumitomo), R33 GTS-t and R34 GT-t are all interchangeable. R34 GT uses a 2x piston caliper, hence it didn't fit.
    • Checked with amayama and nope, the full S2 manual set is not available anymore. Unsurprising, but still disappointing as the ? on availability gave a glimmer of hope.
