From what I read of Stao's plans the idea isn't to build the fastest car in the world, but rather build a turbo to suit the common bolt on mods that most people do.
Lets face it, when most people chuck their first exhaust system on, they're aren't expecting to one day make 400kw, but we all know that the power bug does bite. Most people won't then want to swap their exhaust and intercooler and whatever else, they will just want to max what they have. And I think that's the idea of using the JJR 3' and the return flow cooler
  • Like 1
Thats right staos plan is to use the "common boltons" that people use and see what sort of figures these mods can potentially make if pushed as hard as they can go. Which i think is a great idea. But i stick to what piggas said.. but then money comes into the picture so yeah its a two side story
3 inch for 400? Errr...
Golf ball and garden hose.
I read what was said as being the JJR dump was a bad item to use in general.
I thought zebra was saying the JJR is not "Good".
Of course going bigger is better, getting a mild steel system made up is by far the cheapest if you are on a budget.
What i was saying is the JJR dump is perfectly fine piece, the only issue people seem to have is sometimes they don't line up to the 6 bolt stock flange.
But if you want you can look at the dyno thread and see some people with 3 inch exhausts up in the >370kw range.
Stao himself has results with 3 inch exhaust in upwards of >370kw
Even one of his later ones is upwards of 430kw with 3 inch..
Edited by jay-rod
Mine fit perfectly fine, but that's just one person i guess.
Since then the flange has been chopped off, so fitment/gasket issues are nill.
And if the average person has the choice between a 199 dollar stainless dump and a 400+ brand name 3inch.
You know what most people would choose.
But i do agree, 4 inch would be better way to go, but not exactly necessary.
Its not really possible to get off the shelf 4 inch or even 3.5 inch for a reasonable price unless you get it made up for you.
Especially the r34.
I think stao's main market is the bolt on people here, and those people are not really in it for the "max dyno" number.
The best exhaust is no exhaust. Some of the cheap and loud exhausts actually makes the highest power. Due to the size of turbo compressor, the whole turbo has to be spaced 15mms towards chassis side. 3.5inches would be making it hit the chassis rail. well I see how it goes first.
or run an external with a screamer pipe, ain't nobody got time for a big exhaust :)
My car is now more quiet than a stock SS, until I crack ze gate
Lol, not everyone has 4k for an exhaust.
Tao is trying to make 400kw with the smallest of budgets, which I am all for. I agree a 4 inch may give you another 30kw, but bang for buck that's a riporf.
  • Like 2
Not sure whether to start a new thread or continue in this monster anyway..
Looking at a high flow for an r34gtt. Spoke to toshi and he reckons for the street go the r33 rear housing but for the track the r34 housing.
I am keen on response so thinking of going an r33 housing and the basic high flow. Is that the best one for response and factory look?
Anyone with comparison to the stock turbo? I had a gcg on an r33 and that was really good. I see these HG turbos have more development so hoping they are atleast as responsive as the gcg.
Anyone got a basic HG r33 high flow on an r34 and able to provide the following
At what rpm do you get 18psi in :
2nd gear
3rd gear
4th gear
What power are you getting?
The stock r34 turbo is pretty responsive. I'm able to hit about 8psi by about 2300 in 4th I think. Would the highflow with the smaller housing be about the same (I.e would have bigger wheels but smaller housing so spool up rpm would be similar?)
Toshi reckons the high flow would be full boost by about 4k rpm but on the r33 with the gcg I had full boost by about 3.5rpm so still deciding if I should go gcg or HG.
Many thanks
Try the search function mate, here's a couple I was able to dig up pretty quick
Further updates:
John Reco's R33 skyline. standard engine with cooler, exhaust, fuel and ecu mods. 310rwkws @ 20psi E85 fuel.
I also got a print of John reco's R33, thats the first time I had a proper look at his result. It is running our standard 21U high flow on E85 fuel, and I'm amazed of how responsive it is.
Result sent in by another member that is currently using our 21U high flow running E85 fuel making a super responsive 311rwkws on 20psi internally gated. That is on a R33 Rb25det stock engine.
As you can see they make a little over 300rwkw on E85 and the are pretty responsive
Current state my ss2 makes 18psi at 4100
but its under the knife atm and should make 20 by 4000 on flex fuel and external gate... my mates r34 gtt has the u21 (r33 highflow from hypergear) makes full boost at 3700ish on e85 19psi
any of the highflows will be brilliant and the ss is a whole another level of aggressive boosting
if you want response the u21(33 highflow) is your best bet, its not as responsive as stock but its as good as itl get. The op6 (34 highflow) is a tad laggyer (300ish rpm give or take depending on suporting) but has a higher power output. but If you look at going for the op6 i would highly recommend concidering spending a bit more and go for an ss2 Its an unreal street turbo and bolts straight onto the r34 turbo mani and lines up with stock dumps
My 2 cents cheers!
I've had both the OP6 and 21U turbine housings on my R33, look up my results in this thread and make a decision.
If you're used to full boost by 3.5k, going for the 21U version is a no-brainer, especially for a street car. 500rpm difference in response doesn't sound like much, but it's a big difference.
The 21U should be well and truly on full boost by 3,500rpm, mine hits it by 3,400 and is running PULP.
Edited by colourclassic
Hi, I've been MIA for few weeks due to an small operation and now back on business. I'm catching up with every one's jobs, they will be all out this week, I apologise for the delay
The R34 test rig is in progress and will be tuned with the latest SS2 prototype this friday, hopping for 300rwkws+ with 20psi by 3500RPM.
Dyno reading from a high flowed OP6 turbocharger, making 275rwkws internally gated @17psi, pump fuel:
And posting a small video from twin ATR43SS2.5 powered LS1 V8 maxing out the dyno at 12psi, its apparently making over 1000Mn of torque. Their dyno is getting upgraded, hopefully seeing over 1000HP+ on a full run.
    • If it dies, then bypass. The task isn't difficult. I have one running on a standard R32 FPCM. That's after nearly 20 years of it running an 040, which pull substantially more current than the Walbro. They're not the same module, but I'd hope it indicates that the R33 one should be man enough for the job. I think people kill them when putting proper sized pumps on them, not these little toy pumps we're talking about here.
    • Silicone spray won't hurt anything. And if it does, that's an opportunity to put some solid steel spherical bushings in, so you can really learn what suspension noise sounds like, If you're going to try it, just spray one bush at a time, so you can work out which one is actually noisy. My best guess is that if the noise started only since putting the coilovers in, then it is just noise being transmitted up through the top mounts of the struts, and not necessarily "new" noise from bushes. But it's almost impossible to know.
    • Are you saying the 34 is SUV height, and not that we're talking about an SUV here? (because if we're talking about an SUV, you don't fix them. You just replace them when something breaks. Not worth establishing sufficient emotional connection with an SUV to warrant doing any work on one). I wouldn't jack my car up on a short little loop of 10mm steel rod poking out through a hole in the bumper bar, front or rear end. I realise that we're probably not talking about that type of loop at the front, being the one under/behind the bar on a Skyline.... but even for that one, trying to jack up on what amounts to a thin piece of steel, designed purely for withstanding a horizontal tension force, not a vertical compressive force (and so would be prone to buckling/crushing) and, my most particular bitch about it - located RIGHT AT THE EXTREME FRONT OF THE CAR, applying a load up through the radiator support panel, etc, with almost the entire mass of the car cantilevered between there and the rear wheels? Nope. Not doing that. Not on the regular. That structure out there in front of the front crossmember is not designed to carry load in the vertical direction. Not really designed to carry any load at all, really. The chassis rail that the tow point is connected to would be fine loaded in tension, as per towing. Not intended to carry the mass of the whole car, especially loaded all on one rail, with twisting and all sorts of shitty load distribution going on. No, I will happily drive up on some pieces of wood, thanks. That can only happen on driven wheels, and they are at the other end of the car, and this problem does not exist at that end of the car. And even then, I have been known to drive up on at least 1x piece of 2x8 each side at the rear, simply to reduce the amount of jack pumping necessary to get the car up high enough for the jack stands. What really really shits me about Skylines is the lack of decent places for chassis stands at either end of the car. You'd think they'd be designed into the crossmembers.
    • I've got MCA Blues on my V36 Skyline, and while I've managed to sort out issues with scrubbing/bottoming out by raising it a smidge and increasing the damping hardness, the rear end still sounds *super* noisy when driving on anything other than the flattest surface imaginable. It sounds like a small party of flamingos are just chatting away in the back, which makes me think there are several link points in the suspension contributing to the noise. Am I hearing dried out/worn bushings? None of it sounds like metal-on-metal, it sounds more like hard rubber squeaking on metal. It's been suggested that a bit of silicon spray on each bushing might quiet them down, but I'm not sure what material the current bushings are made of (probably factory, I imagine) and whether silicon spray will degrade that material.
    • The obvious answer here is get a ND2/3 RF with the Targa top. The red is nicer, too!
