The R34 test rig is in progress and will be tuned with the latest SS2 prototype this friday, hopping for 300rwkws+ with 20psi by 3500RPM.
Just saw that and my pants tightned slightly lol
  • Like 1
Hey Tao I saw the ATR45SAT results on the standard rb26. 400kw 24psi e85. Boost comes on barely behind the standard twins! Did you have adjustable cam gears at all?
I look forward to fitting that
turbo to the 2630. I'm picking up the short block in the next few weeks so I should organise the turbo + 50mm gate asap
With the new SS2, the original print is based on the 21U high flow, except I have the freedom of using larger internal gate and different types of wheels, it is very promising.
The Rb26 ATR45SAT result, is from a unopened Rb26 engine using factory cams and cam gears. It drives extremely well on road, picks up boost nice and early in low gears and respond extremely well to throttle just like stock turbos. This turbo is designed for standard RB26 engines. By adjusting cams gears, responds should be improved that could possibly match the standard T25s.
Edited by hyper-gear
  • Like 1
Right, I've got fuel pump, clutch and injectors, all I need now is the turbo.
I was originally going for 300ish rwkw so was looking at the SS2, however the car is not a daily so why not shoot for something higher? That would be the G3 I believe?
Is there a guide on what's required to fit the G3, Stao? I will be taking it to one of the local guys for fitting so want to make sure they have everything required to get it on.
Also, what's the best way to go about making said purchase?
If its for a Neo motor, I will recommend our ATR43G4SAT model. That turbo wold be good enough to hit close to 350rwkws pump internally gated. Cost same as the G3, you can find it on our site under the ATR43 page. cheers
Hey cowboy, if its not your daily. Might i reccomend instead of doing that. Why not just go for say the 21u or the op6 On full e85? Both have seen over 300 fair easy on e95 with basic bolt ons? Just a thought :)
I've put a lot of thought into E85, and really want to go down that path, but I think that'll have to come with a flex tune one day. For now I'm going to stay pump. I sized my injectors to give me the capacity to go E85 one day.
It is for a Neo.
Is it basically bolt on?
Yes, Check my last result from a month ago. made 311rwkws on 20psi with a cooler restriction with pump fuel. It can be made as a bolton turbo. Cost $1250 inc oil line.
Is this what I need to order?
OMFG, finally, it is done.
After talking about it for what seems like years I've finally put down some cash.
ATR43G4 Ordered!
Now just need to get it all fitted.
I have the following:
Walbro 460
Id1000s
Split fires
Car already has fitted:
Exhaust
Front mount
PFC
CAI
EBC2
Iridiums - will gap down to 0.8mm
Anyone see anything I've missed?
I'm shooting for 320+ on pump.
ATR43G4 Ordered!
Walbro 460
Id1000s
Split fires
Exhaust
Front mount
PFC
CAI
EBC2
ditch the iridiums and get bcpr7es plugs.
  • Like 1
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
