Some good figures out or a R33 AUTO, P98 fuel using our 21U STD high flow making 262rwkws @17psi. Usual bolton mods, Tuned By Boosted brothers in SA.
If it got 262kW out of a 21U at 17psi, what do you think a SS2 at 18psi with usual bolt ons would achieve ?
My ss2 on an unopened 186k/km neo made 265kw at 18 psi with boost leaks and top end restrictions using basic boltons
That result isnt a 21u housing...
its a Auto C34 Rb25 Neo RWD.
Its a 0p6 housing.
But it still is a GREAT result...as the car has a stock plastic turbo intake pipe haha .... , a stock op6 turbo actuator.. and a just jap return flow cooler....and a bleed tap..
if it was manual.. it would be 280rwkw on 17psi..
cheers
darren
Ok, cool. Here's some thing quite extraordinary. I found my previous run using the ATR45SAT int gated prototype had a collapsed rear muffler.
Had that replaced and, it went up to 380rwkws then run out of fuel. My Walbro fuel pump played up shortly after as it started to run lean and leaner after each dyno run.
Without the extra back pressure boost creeped to 23psi up top, its not perfect at this stage. More development will be conducted. But 380rwkws out of internally gated bolt on turbo is a pretty good result. With the extra fuel I'm pretty certain it will reach very close to 400rwkws.
  • Like 1
This is getting beyond ridiculous. 380kw out of a literally 'bolt on' turbo with very minimal supporting mods. I can't believe some of the stuff you are putting out recently stao, incredible work mate.
  • Like 2
What's up with the Walbro mate? Should be good for 450ish. Better check the hose intank, was the relief valve between the pump and lid removed? I bet if you replace the dodgy fuel filter the 34's run you will find extra flow, did Trent try bypassing the filter on the dyno?
I removed the fuel filter and replaced it with a straight piece of metal pipe, made no difference. It started to run lean, and leaner. The voltage to it was fine, the pump has now been replaced, I'm hopping to see this issue solved on my next dyno run. similar scenario happened to my R33 two years ago, except that pump just stopped, left me on roadside for a few hours.
Don't get another
That's great advice, I have sold hundreds without issue. Best intank on the market, but most cheap out on the wiring. These need a 70amp relay and decent wiring like anything that draws 25+ amps.
The chances the pump is at fault are pretty slim. Most likely your relay is flogged Tao, try a direct power feed.
Stao, is that the same turbo I have? The ATR45SAT?
Oh, and is that on pump or E85?
Hi, I'm not sure. This is probably the only internally gated prototype ever built. Yours could be an externally gated model or a SS2 internally gated, best refer to order list. It managed 353rwkws on pump before running out fuel. But at 23psi of boost the car was pretty happy with timing and happier to take on more boost. With every thing working it should be maxing out towards 400rwkws E85 or about 370rwkws on pump.
On top of that the turbo it still makes 20psi by 3800RPM and over 200rwkws on either P98 or E85 @ 4000RPM, it makes a pretty good daily.
Just checked, it's the ATR43 G4.
    • Yes the gear for the R33/34 is different, it is red and has a different number of teeth. My part didn't come with that gear though, so I don't know how many teeth are on the red one. You'd have to reuse the 260RS/R33 gear, as long as it's not destroyed.   Haha, as unfortunate as that might be it was working fine for about the first 1500km I've had the car for now.
    • Update all   thanks to the workshop manual, it lead me back to checking fuses as mentioned central locking and door open lights worked when acc was switched on. diagram attached shows two points of power 1. ACC and 2.  Batt with the later being fused (#28) I did check the fuses using a multimeter but I must have stuffed that up also. Went back and checked the batt fuse in interior fuse box and you wouldn’t believe it… a blown fuse. replaced fuse and everything is now working as it should including the climate control   thank you all with your positive insight and knowledge.
    • Where is the warning "That this thread is super old"   I just went into a 5 year old thread, went to do a reply, and couldn't see anywhere obvious a warning of it being super old
    • Duncan is correct. Pitwork (and Toyota's own cheap brand "Drive Joy") were primarily created as brands to sell other manufacturers car parts. It would be weird if Nissan sold parts for Toyota vehicles with a Nissan logo on it, so they created Pitwork to sell parts for other brans Toyota, Honda etc. They are not the same as Nissan genuine parts, although they *do* meet Nissan's standards for replacement parts. They aren't supposed to be a substitute for genuine parts, but a cheaper alternative that is better than Ebay fake parts from you-know-where.
    • Thanks GTSBoy, much easier to work with it now it's free!
