Just now, vxsr33 said:
Where's the best place to pick up one of these venom 100cell cats?
I've been looking into it also - Their website says it's under construction and you can purchase from their eBay if you want to order something.
  • Like 1
A decent CAT really make that much difference :O??????? How would that compare to decat?
Yes I was very surprised too, turns out it can be a significant restriction. Don't know about decat it's a street car :)
Ebay mate
With the OP6 High flow, Just check to make sure the actuator is preloaded and shut, leaks and active VCT. Alternatively you can send it back and swap the turbine housing to smaller 21U. The op6 should be making 20psi at 4100RPM on a R33 Rb25det engine and maxing towards 290rwkws.
The 18psi actuator was opening at 13psi instead. Why would this happen? Had to use a bleed valve to bring the boost up. Also had my car checked for boost leaks recently and it didnt have any (ill do another boost leak test though).
Dont want to go to the 21u, i feel like that would be masking the problem.
Tension up the actuator further, also is your flange fully seated with the turbo? I had a S15 come to me before for a tune and the turbo was held on by 2x nuts and the owner said it was laggy... well, when there's no exhaust going into the turbo then yes...
Will tensioning the actuator further mess up the tune at all?
And yeah the flange is is held on with all 4 nuts and they are tight
Well if the tuner/shop has considered the surrounding cells then it will be fine, however if it's like the tune I saw from the said workshop then no..
When car's running and there are pressure variances it will be different, you need use a boost controller regardless. Turbo run 18psi with no EBC using this actuator on test car which has a very free flow setup. You can also preload actuator to increase minimum boost level, but it will not do much working with that Return flow intercooler.
Blue is Blitz return flow pressure checked before and after cooler kit.
atr45sat311rwkwnewcoolerboost.jpg&key=dedbbe8f1a374a921c5a15417ca6728345145d2fd23f1ad059f864bf949b6c12
Ah ok.
I was thinking of getting the suggested 100cell cat, getting an EBC and getting the car retuned by chequered instead (this will be a while away). Do you think this will solve the issue? As i said im happy with the power just want it to come on full boost earlier.
When comes to problem solving its hard to pin point. Like my self is in the middle of figuring out and fixing what looks like endless problems with a newly purchased R32 GTS4. Well, you can start with checking boost leaks, actuator preloading and VCT activation. for a 100 cell cat, if its not collapsed its not too bad.
Got mine back from DVS this weekend.
R34 GTT 2000 Model.
E85 - 287rwkw
Pump 98 - 256rwkw
-ATR45SAT
-Adaptronic ECU
-Bosch 1000cc Injectors
-Bosch E85 Fuel Pump
-3" Exhaust
-Highflow Cat
-Stock Intake with highflow filter (This is a problem)
-Blitz Return Flow (This is a problem)
-Stock coils (Potential problem)
The actuator was only holding 10psi before opening, had to use the boost controller to keep it shut to 20psi
We tested the pressure before the intercooler and it was hitting 20psi and dropping to around 19psi.
So looks like as always, the return flow is a problem as after cooler it was dropping to 16psi
I'm also guessing the stock intake isn't helping with the flow either.
Plan down the track is to swap out the intercooler with something better flowing and able to hold pressure.
The stock intake will be replaced with a nice big intake and a pod, all enclosed and bracketed to make it legal.
R34 GTT 2000 Model.
E85 - 287rwkw
Pump 98 - 256rwkw
-ATR45SAT
-Adaptronic ECU
-3" Exhaust
-Highflow Cat
Interesting
I got the 1st Gen ATR45's
And i got all 3 of your "issues"
Difference is my cooler is a normal FMIC but with return flow piping.
Made 380rwkw on Trent's dyno and ~355 rwkw on racepace dyno. From memory mine was about 23psi bleeding down to 18~19 or something
1 minute ago, blah_blah said:
Interesting
Yeah that is interesting, you wouldn't think changing the cooler from blitz to a normal cooler would make it jump up an extra 60-70kw.
What exhaust are you running?
Mine is 3inch all the way through with only cat, resonator and the cannon at the end.
I'm thinking of swapping the cannon out for a good muffler to help with drone and noise, not sure if that's a step back or not though.
No idea sorry, some people have massive restrictions but then there is also Greg who runs one with 400rwkw
My exhaust is a 3inch just jump dump, decat and some jap brand 3 to 3.5 inch cat back
Seems like your setup is pretty much exact same as me, only difference is the intercooler.
I purchased some splitfire coils today because I'm having misfire issues from what I can tell.
Will look into a cooler in a few months once I save the coin up.
If you're using the Adaptronic ECU.. make sure you set up the variable dwell table... by default it runs fixed dwell
Greg also has a built 2.9L engine. GTX3582 .82 externally gated on E85. Tuned at Trents. I'm pretty sure he will pickup more HP going to a big PWR with normal cooler piping kit.
Also any one know how to bring back that HTML coding button in the reply box as we used to have?
I remember at least two cars reporting just a smidge under 300rwkw on pulp with a Blitz so doubt that it's the sole restriction. Maybe search the 'all dyno results' thread for the full supporting mods?
Also like I think I mentioned the other day, my car went from 257 to 275 rwkw by swapping from an Xforce to a Venom cat, decent difference. Which cat are you running?
  • Like 1
R34 GTT 2000 Model.
E85 - 287rwkw
Pump 98 - 256rwkw
-ATR45SAT
-Adaptronic ECU
-3" Exhaust
-Highflow Cat
Mine was tuned at about 289KW on BP 98 by JEM - Same turbo, Same cooler, 3" JJR exhaust with an unknown dump and unknown highflow cat, Splitfires with the stock airbox and snorkel. Interesting to see the differences between them.
I'll also be changing my cooler in the near future and going to a venom cat as recommended by V28VX37.
Similar to you my IWG actuator was opening at 10PSI which I changed after getting it tuned. The tuner mentioned that he had to have my AVCR settings cranked right up to get it to hold boost, since changing it to a Turbosmart variant I have the settings at 1/3 what it used to be.
Inbox me if you want more details
    • Yeah I've had too many issues with knock off's on the BMW's. I don't want to do a job twice or more because the parts are shit.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
