Did you happen to weigh the rear cradles? With the alloy hubs is the GTR rear end any lighter? Alsowhat Ti exhaust have you scored Marlin? My twin mufflerTi Trust exhuast is the street one which i am told is more expensive then the single muffler race exhausts...i am waiting for some dyno time to see if it makes the power i am after
Nothing new mate, mine is a stainless one from Just Jap. Outstanding value, including dump pipe (which just needed a small tidy up internally) and X-Force cat was around 650 bucks!
GTS-t's a budget racers bra! The cat alone retails around 300!
I couldn't be happier with it, great finish, and is holding up without issue :P
Edited by Marlin
looking good battered sav.
I like the ABS new mounting. it'll be interesting to see what the pedal's like without the booster but with the new pedal ratio. it's certainly nice to get some space back in the engine bay and save a bit of weight too. :P very good idea.
Baron, I did it to mine and the feel is chalk and cheese (read: FAR better!). I'm constantly trying to convince Berry to change his because as it is now I think it's terrible. Impossible to modulate worth a damn.
JJ often list stuff on ebay under an alternate marketing name, and just so happens I was the only bidder :)
Also, all Targa folks get a great discount there regardless, talk to Darron if you need anything as Steve is rarely avaialble :P
you get a deal? listed as $899 on just jap + postage
http://justjap.com/store/product.php?produ...=273&page=2
That's not the one I have mate. Mine is the ovoid style dump (I prefer anyway) and doesn't have a resinator (bonus to me ::P. It may have been a runout special?
Just found the email and I paid the freight as I'm on a good rate with TNT;
JDM Performance Turbo Back Exhaust System- R32 GTST 1 AU $699.00
so your saying your stainless system weighs around 7kg? because we weighed my 3" mild steel exhaust. dump pipe back with no mufflers and pretty much only one bend and it was 10Kg. the stainless one must be super thin walled. which is probably the case.
It weighed 11kg including front/dump pipe and cat convertor on my certified freight scales. Whatever it is made from, it's still going strong and it didn't scream "crap" when I received it or I simply wouldn't have installed it. :P
Edited by Marlin
The removal of the booster was under Ben's advice, and it's just one less thing to go wrong. If a one way valvle fails, your assisted bedal can turn into a 16psi pedal stopper.
The ABS is a commo unit (Bosh), the R32 gtr abs is bad enough, i can't imagine what the gtst one is like. i've seen alot of people mount them on the passengers side, which i thought is pretty dumb, considering the piping hot exhaust runs right under it (which is where the lines would go with a nav in the car)
Edited by sav man
I haven't really detected any difference between the GTST and GTR stock ABS. neither are super fast but thankfully they are quite lazy (ie quite a high threshold) so on the circuit you will almost never have it cut in at all. on uneven or broken surfaces though (which I'm sure you get plenty of in tarmac rally) they are shithouse. can't cope well at all with low grip tarmac and then you find the sampling rate/pulse speed etc become a problem. for tarmac rally I can see for sure a better unit is a good idea. I'm not sure how much is in the valve body or how much is in the programming and processor power of the ECU. I suspect most of the gain comes in smarter/faster ECUs.
master cylinder is 1/2 mounted, just need to drill and tap the holes for the studs. Some new brake lines run
Some lines to the abs unit, need to tidy them up before they are flared.
I have wasted the last two weekends being dicked around by the std Nissan brake lines...have to ge the car farking towed in the morning because of them :) So looking forward to farking them off again and having fresh lines with banjos and not those shitty, alloy swaged fittings :(
Got my abs hubs back from getting the bearings replaced. old ones needed a 60t press to get them out (after they were tried in a 12t, then a 30t)
Roy: i was given the advice to put anti seize on all the brake fittings, from the local hydrolic place, as it stops you rounding them. I rounded the rear fitting in my gtr, and dremmeled it down to a 9mm head
I never had much luck doing the double flares myself ben, how did u go with them? I ended up just taking them down to tas brakes to get done.
Its coming along well though, looking forward to seeing it on the road!
What are the advantages of getting rid of the booster? Wouldnt it require more pedal effort without one?
It does require more effort, but you quickly get used to it. Done properly, it feels much lighter pressure than if you simply experiment and disconnect your booster.
You need to alter the pedal ratio from approx 4:1 to 6:1 by moving the master cyliner up approx 27mm, and re-drilling the top of the brake pedal inside the same amount. That gives you more leverage, and ends up about 6:1.
The benefit is much better brake feel. I found after putting Brembos on mine that I couldn't modulate the pedal as well as I needed, so having non assisted brakes was a massive improvement.
    • That's probably OK. That's a face to face compression joint between two surfaces with the clamping load provided by those bolts. So.... it's unlikely that the bolts will end up feeling that load in shear, unless the clamping surfaces are not large enough, bolts not got enough tension on them, etc etc to prevent the two faces from moving wrt each other. Which... I would hope the designers have considered, seeing as it's probably one of the most important things the upright has to do apart from resist collapsing in its own right. But yes, it would definitely be worth asking them what their safety factor on that part of the design was. I tend to think that the casting, being a casting, is not necessarily the strongest bit of material in the world. It's about an inch square, and when you think about the loads that are being put into it, you have to wonder what safety factor the Nissan boys (and every other OEM engineer who has designed all the millions of other uprights that look essentially the same) used to account for defective casting, aging, severe impacts on the wheel, etc etc.
    • Those bolts would be orders of magnitude stronger that cast aluminium though.  And its mainly clamping force, not shear they are dealing with?
    • Except all that twisting force that is breaking a cast piece, appears to be going through 4 bolts in the picture Johnny posted of the BryPar one...
    • The smart approach is to use the gearbox loom from the manual car. Makes it a lot easier - just plugs into the switches on the box and plugs into the main loom up near the fusebox. Then you only need to deal with bypassing the inhibit switch. The other approach requires you to use the wiring diagram to identify those wires by colour and location, perhaps even indulging in a little multimeter action to trace them end to end to make sure, and then.... you will have the answers you need. The R34 wiring diagram is available on-line (no, I do not have a link to it myself - I would have to do a search if I wasn't able to go to the copy I have at home).
    • Hi, i’m converted my r34 4dr auto to manual but need help with gearbox wiring. There are bunch of wires no idea which one for speedo drive, neutral, reverse can anyone help me. IMG_6860.mov
