I had a damaged wastegate line, which gave the engine some being boost spikes (went off the scale of the map sensor) on Friday, and the overheating problems started and got worse from there.
It's a tomie super grommet, but I won't be using that again as they warp the deck of the block
  • 3 months later...
Been a while since an update. The engine is stripped down and I got a replacement block which is at the machine shop. The old block has had it's day.
I had been noticing a pool a silicone under the car whenever is was parked for a length of time. Turns out one of of the rear subframe bushes was leaking it out. So I've dropped the subframe out to put new bushes in it.
97111D63-D5EF-47E5-8FA5-F0C6E9458D8F_zps
2DDE1BD3-08F7-4B22-B512-B3528A60FAFE_zps
C9732C32-C72A-4679-A713-1136B1D53959_zps
Subframe is all good. Must be the protective oil coating that it got in the early years.
Block will be back from the machine shop by the end of the week, so I will be able to start assembling that on the weekend.
I am ditching the Nissan optical CAS and going to a High Octane trigger kit. The RPM trace is pretty rough and wouldn't of been helping with reliability.
I did look into that option. But from a reliability point of view, the 20+ year old Nissan optical sensor is still used and likely to fail.
For a road car I'd run the replacement CAS disk.
  • 1 year later...
It’s been a while, but it’s time for an update.
I entered the Sports GT support race for the V8 Supercars at Phillip Island for Nov 2015
I installed new sealing rings instead of a head gasket. They require the block to machined similar to o ringing, they are able to grow and follow the head and have a copper gasket with 3bond for the water galleries.
I also started building a new winged sump
2 weeks before I was due to leave for Phillip Island Dad was diagnosed with pancreatic cancer and went in to hospital.  So I parked the new sump and continued to put the car together.  The car was ready a couple of days before I was due to leave, or so I thought.  I got the car tuned and found my Chinese 1zzfe coils were good for 1 dyno pull before dying, so I ran down the road and got some VDO ones (which are still fine) finished the tune and took the car home to find oil under the car.
I cracked the oil filter mount that bolts to the block  as the gasket was damaged and not giving an even surface.  The crack was almost invisible to the eye, but it was opening up under pressure.
The day I was due to leave, the doctor called us in and said Dad only had days left to live and advised me not to go, but Dad insisted that I go.  My mate got hold of a filter mount at 1pm and dropped it to me, I fitted it and found it didn't leak after 30 secs of running so I drove back to the hospital to have a beer with dad and drove to the boat.
The first session at Phillip Island my rear tierod came loose, giving me 4mm toe in on the drivers side.  As the weekend went on I found the car wash pushing coolant out for the first couple of laps of each race, and the coolant pressure was spiking.  But I continued on and finished the weekend and got some good wheel to wheel racing in.
https://www.youtube.com/watch?v=vL3z9rH06g0
https://www.youtube.com/watch?v=UeeVfNx6w3c
In hindsight I realised that I hadn't retentioned the head studs, so the head was lifting, but the sealing rings filled the gap once the cylinder temp raised.
I returned home and Dad died 1 week later.  Shortly after the funeral I decided to run Dad's Subie in Targa instead of the Skyline, as the GT4 class is far more prominent.  I also pulled the head of the Skyline to fix it in case I had to fall back on it.
Once I got the head off, I could see that the cylinders were leaking everywhere and retentioning headstuds is done for a reason.  As it turned out that's all I did on the Skyline for 12 months, it just sat in the corner of the shed feeling sad.
The Subie took far more work than I thought to convert to the GT4 regs from the Modern regs so it was all very last minute.  I got to the even with high expectations wanting to do well for Dad and it was the first big rally for me and my girlfriend together.  She had done another event 2 months before Targa with another competitor as a warm up, as I didn't have a car ready, but she was different when she came back.
We started the event well, and lead for 2 days, but I blew 3 tyres because I'd put too much camber on the car (only worked out after the event), had a couple of offs, and as the event went on I was continually having to fetch the mrs out of the other competitors room.  After the after party she stayed the night 'on the couch'.  After some witness statements of her actions/drunken confessions I kicked her out of home for cheating (turns out it was a few over the years...all racers).  After that I didn't look at the cars for a long time and considered selling them and not going racing again.
Late in 2016 I got back into the Skyline.  I found I had valve float on the inlet valves, so I replaced all the inlet valves and put extra spacers under the springs for more preload.  I put all the engine back together again and hit the starter..... 0 compression on any cylinder.  A few days later I pulled the head back off, everything looked fine, so I put it all back together again.  This time it had compression on 3 then 4 then 5 cylinders, but not 6.  I pulled the engine out and the head off again and found a bent valve.  After talking to some people I worked out that the lifters got gunked up, as they were sitting in a box for 12 months.  I replaced the valve and pulled all the lifters apart and cleaned them.  I also completed my new sump and installed that  while the engine was out.
So this time when I put it all back together the car started and ran on 6 cylinders.  I've done some road testing and haven't pushed and coolant plus the coolant pressures seem fine.  I've event retentioned the head studs.  So the car is now ready for it's first event in a long time, the Ross Auto Corsa.  After that I will be using it for Circuit and AASA tarmac rallies
Edited by sav man
  • Like 4
I gave the car it's first shakedown on the weekend and the Ross Auto Corsa.  Played with the setup and boost a bit, the below run is at 10psi boost (usually run 20)
17310129_10154403095355036_6254584094565
17158925_10154403095470036_8776063729511
Edited by sav man
  • Like 3
Hi Ben,
Can you eleborate a bit more on the issues that you had with the 1zz coils?
I've just bought the 1NZ coil kit for my R32 tarmac rally car, now you have me worried. The coils that I have are Denso coils according to the manufacturing stamps, but as you know these days things are not always as they seem.
Great work on the car with amazing attention to detail, thanks for taking the time to document the build. Are you planning on doing any tarmac stuff in Victoria?
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
