Just now, FedBpy2018 said:
So you'd take a drag car built to go in a straight line out to drift it or track race it? If so then your crazy
I took my circuit built R33 to a skid pan, and I quickly realised I needed a smaller turbo so I bought a new smaller turbo lol
2 minutes ago, BakemonoRicer said:
Sydney roads are absolutely horrible for driving.
However Newcastle on the other hand is awesome for driving...plenty of epic roads for a blast.
R33 GTRs still rock, though, right? lol
  • Like 1
2 minutes ago, Dose Pipe Sutututu said:
and doesn't make DSG farts lol
Now here's something I can get on board HATING!! it seems every wanker in Sydney has their DSG farts modified to be louder? (not really sure nor care how that works)
Watch out for Kangaroos! I've hit 3 driving Hunter Valley roads, but yes they are very nice for driving.
  • Like 1
9 minutes ago, Dose Pipe Sutututu said:
doesn't have launch control though, and doesn't make DSG farts lol
This one had a built turbo. Any other questions?
Edited by Robocop2310
what a useless video.. no engine shot, no tech details...all turbos are built one way or another lol... please elaborate... but seriously... post this in the TRD Camry thread, as a testament to TRD being more than just a trim level. mind you as "concept" it's really not even worth discussing until it's actually produced.
Ha ha ha...I was joking...TRD or or not...my wife drives this to pick up our kids...it's like a good looking boat.
I work for toyota :)
Yes, they delete their resonators and retard heaps of timing on gear shifts to increase the farts... however they are there for a reason, to cut torque between gear shifts so the box doesn't go bang. The farts are a byproduct of timing retard between gear changes
33 minutes ago, BakemonoRicer said:
I think most people are spooked by GT-R's because the natural reaction is to lift-off when the tail kicks.
Keep that throttle on lads, and enjoy HICAS :)
Yeah you can work with it, sort of. If it starts malfunctioning, good luck. Functioning HICAS is fine for the road, but on the track it's annoying.
Anyone claiming that HICAS only improves their car control on a (let's assume fast country or hills) drive is not driving hard enough to understand the point.  Those (above) who have backed me up and described how HICAS is frightening when you are really, really up it can do so because they have experienced it.
Bakemono.....when you say "and enjoy HICAS", you really mean "enjoy ATESSA".  Using the GTR's RWD biased AWD  to conquer oversteer is not the same as having HICAS wiggle the rear wheels around because it's got no idea what it is doing.
Skylines (GT-R, GTS-5t, GTS-4) that have ended their lives in trees or poles or armcos or walls generally have HICAS.
The system is too slow to react and instead of aiding, it actually degrades handling.
  • Like 1
3 minutes ago, GTofuS-T said:
I've had the delete kit for ages, just too lazy to get under and do it.
lazy bastard lol.. the lock bar is a piece of piss.. the full eliminiator kit takes a bit of time, but worth it..  I wrote a guide too
here it is for anyone interesting in deleting the bullshit Nissan put in:
http://www.trak-life.com/diy-hicas-delete-hicas-eliminator-kit/
On 11/27/2018 at 1:37 PM, GTofuS-T said:
Well the rise in R32 price was arguably due to the US demand, so it would be fairly safe to say if they're interested in them, the same rise will occur, unless, and I've heard some people doing this with R34's too, they're buying them already and storing them until they can be legally imported, smoothing the demand rather than a big influx.
here you go... 19,000 USD for an R33 GTS-T...
Image may contain: car and text
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
